Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 11-08-2012, 09:21 AM
  #11821
Ok i just wanted to make sure the holes were same because the servo tray and receiver box are a little different. If i didnt have this spare chassis i would get the fioroni. I hate keeping a watch on my droop because of the droop screws digging in the chassis. Where is a good place to get the fioroni chassis ?
evolution03 is offline
Old 11-08-2012, 05:37 PM
  #11822
+1 to AZRC4Me
dirtn is offline
Old 11-09-2012, 05:34 AM
  #11823
Just purchased a TK3 off of a friend Sunday night. Ran it for the first time today at local track, LOVING IT. Had a lot of faith in my Mugen but after many set ups and attempts to get it to work for me its just not the car I need to be driving.
MBX6-R_LEDFERD is offline
Old 11-09-2012, 06:11 AM
  #11824
Guest
Welcome to the the red flag club!!!!!!! Hehehe - hahahaha in a evil laugh!!!!!!!
LOSIRACER77 is offline
Old 11-09-2012, 10:01 AM
  #11825
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
I know of a few people that switched from a 6R to the tki3 and have gotten faster and just love the handling of the Kyosho. I'm one of those people
I see you're in LA. Which track is your local track?
SEF is offline
Old 11-09-2012, 02:23 PM
  #11826
rfleck's Avatar
Trader Rating: 58 (100%+)
Hard trigger to pull, but pulled it anyway. One on the way.
Which one of King's setups is the one you guys are using as a starting point?
rfleck is offline
Old 11-10-2012, 01:29 PM
  #11827
HH
HH's Avatar
As jpz_67 said... "you won't regret it."
Most guys around here are running Cody's IFMAR setup.
You're going to need these parts to complete:
1.3 x 8 hole white pistons on all four (not the kit pistons which have the tapered holes). You probably already have these for your XB9
The kit comes with the IF346-09 shock bladders which are real thin and flat. Cody, Sean and most others are running the IF346-03 bladders. I've tried them both and had good results. The kit bladders (-09's) were collapsing until Sean (AZRC4Me) told me to build them with 0% rebound then they worked great. I'm actually switching back to them for some track conditions as they seemed even more responsive than the -03's.
You may also consider the 93mm HD rear universal driveshafts. The kit comes with 91mm HD on all four but Cody's IFMAR setup above calls for a narrow track width in the rear and a wide track width in front, so we all run these 93mm HD shafts in the front as it reduces the risk of snapping off the outdrive cups due to the wider track width.
One last recommendation is the Proline MP9 Bulldog Body. It adds the downforce you'll need and the durability you'll want. At $20 a pop you can buy 3 of them for the price of the optional K body.
I'm just sayin...
HH is offline
Old 11-10-2012, 01:45 PM
  #11828
HH
HH's Avatar
Absolute Hobbyz has them in stock
-or-
Contact Garen at Fioroni-USA
HH is offline
Old 11-11-2012, 06:28 AM
  #11829
hi my name is Steven from Viet Nam. First time out with my MP9 TKI2 in this morning. i have the Tebo set up n i change a bit at the back. it was pretty good to take the jump land corner stable n i started to like the car. but guess what after for a few tanks the front left cvd keep come out whenever it land or fast into corner. PL....... any pro give me some advice n solution. i really appreciate n thank you so much
this is my email [email protected]
stevenchan is offline
Old 11-11-2012, 04:22 PM
  #11830
slow coach's Avatar
ditch the droop screws get the plastic rear hubs and use the wheelbase spacers, run the 2mm in the front and 1mm in the rear, before you ask it has to be these spacers its not specifically the thicknes but the thickness and diameter in unison which works, but once installed no more droop screws!
slow coach is offline
Old 11-11-2012, 06:52 PM
  #11831
Im not really following this
Old 11-11-2012, 07:09 PM
  #11832
Guest
you tn people are so slow!!! hahahahaha
Old 11-11-2012, 07:44 PM
  #11833
Jammin57's Avatar
Trader Rating: 120 (100%+)
I think he's talking about putting the spacers inside the shock body on the shaft to reduce down travel
Jammin57 is offline
Old 11-11-2012, 07:51 PM
  #11834
Guest
i really didnt understand him either
Old 11-11-2012, 08:46 PM
  #11835
Trader Rating: 25 (100%+)
There are spacers supplied with the plastic shock parts. Fit them to the shaft under the piston so they bottom out in the shock body. I think it's in the instructions somewhere.
smelly62 is offline
