Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 11-07-2012, 11:35 AM
  #11806
AZRC4Me's Avatar
Originally Posted by Coach Townsend
PART# please
Not out yet, prototypes
But if I had to guess, they'd be IFW412-16.
AZRC4Me is offline
Old 11-07-2012, 11:55 AM
  #11807
Motorman007's Avatar
Trader Rating: 89 (100%+)
Originally Posted by rfleck
It's good, no doubt. Two laps and I was already comfortable and making zero mistakes with yours LOL.
Thank good? I may have to go back to my roots then. Jr it was that good? Nice to here.
Dibbs
Motorman007 is offline
Old 11-07-2012, 12:21 PM
  #11808
Coach Townsend's Avatar
OK whats happening Sean
Coach Townsend is offline
Old 11-07-2012, 01:21 PM
  #11809
AZRC4Me's Avatar
What up Coach. Just trying to pass the time at work lol. Just replied to your PM
AZRC4Me is offline
Old 11-07-2012, 02:39 PM
  #11810
Spur gear, will another manufactures spur gear fit on the mp9 based cars? I am sure I will have to use the old style diff case off the 777.
rob-d is offline
Old 11-07-2012, 03:40 PM
  #11811
jpz_67's Avatar
Trader Rating: 57 (100%+)
You wont regret buying one.
jpz_67 is offline
Old 11-07-2012, 03:45 PM
  #11812
jpz_67's Avatar
Dibbs
The tki3 is a great buggy. No real trickery involved in setup. My car isn't perfect but its pretty darn good. I just put on one of Cody Kings setups and made a few small changes. For me the car handles the rough stuff a lot better.
jpz_67 is offline
Old 11-07-2012, 05:27 PM
  #11813
Guest
the buggy it the bomb!!!!!!!!!!!!!!!!!!!
LOSIRACER77 is offline
Old 11-07-2012, 05:30 PM
  #11814
toyoter91's Avatar
Trader Rating: 47 (100%+)
I am thinking of making a switch in the near future, but have some questions about the TKI3:
Front and rear shafts - are the pins replaceable with 3mm pins such as on the xray and mugen?
How is the wear on drive cups and drivetrain in general?
What option parts does the car need from box stock? I already have tons of option pistons including the Kyosho 8-1.3 tapers (straight holes) and Kyosho springs for the car because I use them on the Xray XB9
Thanks,
The pins cannot be replaced with the 3mm pins like the xray, mugen, AE etc.
toyoter91 is offline
Old 11-07-2012, 05:39 PM
  #11815
Guest
Thanks,
this is all i put on my buggy,http://www.infernosonly.com/Kyosho_I.../kyoifw412.htm
Old 11-07-2012, 10:26 PM
  #11816
When you are converting a tki2 to a tki3. Do the holes on chassis line up for receiver box and servo tray ? I have the stuff for the conversion and a new tki3 chassis but im not wanting to swap chassis till the tki2 chassis is worn out .
evolution03 is offline
Old 11-08-2012, 02:21 AM
  #11817
Yeah the old chassis screws line up
Soapy is offline
Old 11-08-2012, 02:50 AM
  #11818
McD44's Avatar
Trader Rating: 16 (100%+)
I am also getting ready to replace my worn TKi2 chassis with a TKi3 or BCE. THe question is do I go with the BCE or the TKi3? What are the pros/cons of each?
McD44 is offline
Old 11-08-2012, 05:07 AM
  #11819
Have you considered the Fioroni one? (same as the TKI2/3, with hard coating like the tki 1, bulkhead seals and droop screws metal inserts)
RAlmeida is offline
Old 11-08-2012, 08:10 AM
  #11820
AZRC4Me's Avatar
There is no difference between the TKI2 and TKI3 chassis. In fact, there's no real "true" TKI3 chassis - the chassis in the TKI3 kit is identical to what was in the TKI2 kit.
Some like aftermarket chassis, some don't. It's been heavily discussed on here before, outrageous claims and all. If there was something to gain by running an aftermarket chassis, then every team driver heading to Argentina would be running one - they aren't.
AZRC4Me is offline
