Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 10-24-2012, 03:57 PM
  #11746
305M3's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Eivind E
I believe those are limited special edition yellow waterballoons.
Comes in a pack of 100 units for $2, but only very few are yellow, so you'll have to sift threw the bag and sort them by color
Waterballoons last about 10x longer than stock rubbers and cost infinately much less. We're talking $0.02 per unit
Hahaha... Very well played sir...
305M3 is offline
Old 10-25-2012, 12:32 AM
  #11747
pointforward's Avatar
Originally Posted by SLIM6971
Has anyone tried the CSI pistons in their MP9's yet? I have ordered a set due to some local guys and there opinions about them. If you have tried which ones did you use and what fluid.
Thanks Chris
I used the blues on my front with 700cst oil and gray springs and the blacks in the rear with 400cst oil and light blue springs at the recent C-Netic challenge. The car handled great. It's just my engines that kept stalling and my drivin was crap.
Track was large, lots of jumps, surface felt like terra cotta with lots of dust getting blown over it.
pointforward is offline
Old 10-25-2012, 04:37 AM
  #11748
mrbusta's Avatar
Trader Rating: 20 (100%+)
hey guys id like to put this out there do the hyper 9 brake ceramic pad fit the mp9 tki3 by any chance thanks for any help
mrbusta is offline
Old 10-25-2012, 05:05 AM
  #11749
tak4's Avatar
Damn you got to run at C-Netic. I'm so envious. It's the most amazing track I've ever seen. And watching Savoya attacking the jumps... crazy. If only McBride had not run into problems.
tak4 is offline
Old 10-25-2012, 11:00 AM
  #11750
Hi everyone,
Just asking a question to you guys. Any recommendation for a shock piston brand? Really make me confused when i have to choose between Fioroni, CSI and Kyosho (1.3x6) (1.3x8) (1.4x8).
grimaldi3 is offline
Old 10-25-2012, 12:01 PM
  #11751
McD44's Avatar
Trader Rating: 16 (100%+)
Quick question about the plastic spacers that go under the diff uprights. I have a 13t losi clutch on my Werks B5 and If I run the spacers the clutch bell rubs against the upright and binds. If I move the pinion away from the spur the mesh is way, way too loose. Are the spacers necessary?
Finally got to run my new to me MP9 TKI2 WC and I am so happy I decided on this platform. I also just put all of the TKi3 upgrade parts on it which makes things a bit more tidy on the electronics side. It is a great car to drive, does exactly what I want it to.
McD44 is offline
Old 10-25-2012, 01:23 PM
  #11752
jpz_67's Avatar
Trader Rating: 57 (100%+)
Originally Posted by grimaldi3
Hi everyone,
I am pretty new to the tki3 but the car is really good out of the box. I swapped the kit pistons for 8 x 1.3 tapers and felt the car was even better. I would stick with the kyosho pistons unless you are just wanting to try something different. If thats the case and you can find them I would get the fioroni.
jpz_67 is offline
Old 10-25-2012, 02:52 PM
  #11753
setanborneo's Avatar
Kanai testing new Alm Front C-Hub?
setanborneo is offline
Old 10-25-2012, 05:44 PM
  #11754
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Maybe a bit more caster than the current ones?
hookem34 is offline
Old 10-26-2012, 01:25 AM
  #11755
Ohhhh Yes...C-Netic was awesome. The track is like nothing else, and the organizers did a banging job. My only disappointment (apart from sucking mightily) was not seeing Kyle in the final -- who I think would have made the A even more exciting.
Reno's style is something to behold as well. Very aggressive with his car, and doing crazy things with his car in the air. Most amazing is that there was little difference in his driving from start to finish, considering the tires he was on. After the race they looked like racing slicks! For a pic of that, check out my twitter (@denislucindo).
No doubt that the stock pistons are very good. But it's also clear that the pistons are the part of rc cars which have changed little over the decades. Compare full-scale shocks and motocross shocks with ours, and you'll see the huge disparity.
One reason we don't see the big names running these option shocks is that they're often constrained by their kit sponsors from doing so.
I've tried the stock, CSI and Fioroni on my k car and Serpent, and have found that I like the CSI's best. With the fioronis, you have to run them with thin oils, and in the hot weather we have here, the oils thin considerably between start and finish.
Next up I'll be trying C2 pistons made by a former motorcycle rider in Italy named Tiziano.
Old 10-26-2012, 04:19 AM
  #11756
I notice there are 3 different bodies you can get for the car. What are differences ?
bkuff-losi is offline
Old 10-27-2012, 08:38 AM
  #11757
nacho_gas's Avatar
Kyosho MP9 TKI Original Body 2008 ref. KYOIFB002
Kyosho Inferno MP9 "Shift" Proline 2008 Ref. PRO3295-40
Kyosho MP9 "Hi-Flow" Illuzion JConcepts 2009 Ref. JCI0077
Kyosho MP9 "Fighter" Bitty Design 2009 Ref. BDFGT-K003
Kyosho MP9 TKI2 Original 2010 Ref. KYOIFB005 0,7mm ó KYOIFB005H 1,0mm
Kyosho MP9 "Finnisher" JConcepts 2012 Ref. JCI0229
Kyosho MP9 "Force" Body Bitty Design 2012 Ref. BDFRC-K003
Kyosho MP9 TKI BullDog Pro-Line 2012 Ref. PRO3383-00
Kyosho MP9 TKI3 Original New 2012 Ref. Aśn no disponible
nacho_gas is offline
Old 10-28-2012, 10:31 AM
  #11758
Guest
Default breaking the cherry
Me an my friend went to FRC FLOWOOD RC TRACK IN FLOWOOD MS. to break the cherry on our new tki3s. I came from racing losi 8ights. O MY GOD, WE LOVE THE KYOSHO TKI3! THIS BUGGY TURNS AND HANDLES LIKE NO OTHER!!!!!!!!. I JUST WASTED MONEY BUYING TOY LOSI 8IGHTS, RACE ROLLERS AND GOT SPOILED WITH THEM. NOW I GOT A BIG BOY 1/8 buggy, a real race car!!!!! This buggy turns,handles,flies.
FRC, had a jconcepts clash race there back in july i think, but the track still has that layout from the big race. So I don't feel bad about getting 2nd place to a guy that races there every weekend, and I have not had my hands on a nitro sence march and have not raced for 3 months. My tki3 was stock book setup with 1.3 x 810 pistons and aluminum spindles. 45 wt ft,30 in the rear. We took some droop? 27mm ft ride height 29mm rear. The buggy wasI great. The end!!!!!!
LOSIRACER77 is offline
Old 10-28-2012, 11:22 AM
  #11759
houston's Avatar
Trader Rating: 96 (100%+)
guess you gotta change your screen name now huh?
mp9 is an awesome buggy , they have all been great throughout the years , kyosho has been a true pioneer in radio control model RACE cars
wow nacho , some serious in depth body info , great job bro
houston is offline
Old 10-28-2012, 03:50 PM
  #11760
Ok I skimmed thru as many of the almost 800 pages as I can handle lol. Just a quick question. I have a tki2 converted to brushless. I'm new to R/C. Was parts should I keep on hand in case of breakage?
AnotherNewb is offline
