Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 10-19-2012, 10:38 PM
  #11701
Tyson72's Avatar
Can anyone tell me where u get those little plastic fuel tube joiners?
They join fuel tube together side by side.
Tyson72 is offline
Old 10-19-2012, 11:04 PM
  #11702
Guest
i got mine from losi.
LOSIRACER77 is offline
Old 10-19-2012, 11:40 PM
  #11703
Tyson72's Avatar
Ok yeah found the losi ones on amain might have to run them. Cheers
Tyson72 is offline
  #11704
HH
HH's Avatar
They are typically packaged along with another item such as this RB Exhaust Cooler or Fuel filter.
They are also included in the nitro kits from most manufacturers and you can locate them by typing it in the search box at A-Main or Tower Hobbies, etc. Like this.
There are a couple of aftermarket companies that offer some as well like Du-Bro or these from GMK or Go Technology.
That ought to get you started in the right direction anyhow..
HH is offline
Old 10-20-2012, 12:29 AM
  #11705
Tyson72's Avatar
Thanks a lot for that HH
Tyson72 is offline
Old 10-20-2012, 07:34 PM
  #11706
Tyson72's Avatar
Would someone like to give me a list of parts I need to upgrade a tki2 kit to tki3 please
Tyson72 is offline
Old 10-20-2012, 08:33 PM
  #11707
Guest
Look at www.infernosonly.com, and look at the tki3. They give a list of stuff between the buggy.
Old 10-21-2012, 10:39 AM
  #11708
nacho_gas's Avatar
KYOIF474B Kyosho Inferno MP9 TKI3 Side Guards
KYOIF478 Kyosho Inferno MP9 TKI3 Front Radio Box Set
KYOIF479 Kyosho Inferno MP9 TKI3 Receiver Box Set
KYOIF480 Kyosho Inferno MP9 TKI3 Aluminum Servo Plate
KYOIF481 Kyosho Inferno MP9 TKI3 Fuel Tank Stay and Servo Tray Parts
KYOIF477 Kyosho Inferno MP9 TKI3 Hard Front Shock Stay
KYOIF482 Kyosho Inferno HD Universal Drive Shafts 91mm - Package of 2
KYOIFD402KY Kyosho Inferno MP9 Yellow Decal Set
nacho_gas is offline
Old 10-21-2012, 03:44 PM
  #11709
Skycraft hobbies in Burlington Ontario, has TKI3's in stock
Yes
RAlmeida is offline
Old 10-21-2012, 05:06 PM
  #11710
jpz_67's Avatar
Trader Rating: 56 (100%+)
Anybody have any preferences on bodies for the tki3? My kit body has already cracked in the rear body mount area but I feel it was from me just rushing in cutting it out. I may try another but have been looking at the bitty force and the proline bulldog. Anyone have any feedback on these bodies? Thanks.
jpz_67 is offline
Old 10-21-2012, 06:32 PM
  #11711
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
I've been using the proline bulldog and i like it. The weak part is in the area of the front mount. Also, the nose rips off pretty easily. Just reinforce this area with shoe goo and duct tape.
I found a standard tki2 body (ifb005) for $22. I had no idea it was so flimsy and thin. I almost didn't need scissors to cut it How thick is the tki3 body (ifb006)? I see Kyosho has a thicker version of ifb005.
In any case after some searching, I see that most Kyosho bodies crack fairly easy, so I might stick with the proline bulldog from here on out.
SEF is offline
Old 10-21-2012, 06:42 PM
  #11712
Motorman007's Avatar
Trader Rating: 89 (100%+)
how did you like the buggy this weekend sir?
Motorman007 is offline
Old 10-21-2012, 07:29 PM
  #11713
Guest
ifb005h is the same as stock but thicker? 1.00mm?
ifb005 is like .08mm? stock
ifb006h is the hard body? 1.00mm? high down force body
ifb006 is just a high down force body
Old 10-21-2012, 08:06 PM
  #11714
Trader Rating: 17 (100%+)
When using the ko switch, do you have to make the hole in the batt box bigger ?
bkuff-losi is offline
Old 10-21-2012, 08:22 PM
  #11715
You can mount it with the transponder.
ratjayfala is offline
