Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 09-12-2012, 06:47 AM
  #11431
CJ RC's Avatar
Originally Posted by Soapy
Has anyone got the 93 HD driveshafts yet?? I heard a rumour kyosho had made them??
Yes Kyle and I run them in front and rear
CJ RC is offline
Old 09-12-2012, 09:00 AM
  #11432
pointforward's Avatar
Nitrohouse has them. I just ordered mine. Or had.
pointforward is offline
Old 09-12-2012, 09:02 AM
  #11433
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Default 91 vs 93
New to Kyosho, and I bought a used tki3 with 93's up front and 91's in the rear. It also came with extra sets of 93's if I wanted to use them all around.
Were the 93 universals created so you can tune the amount of plunge, or were people actually having issues with them popping out?
SEF is offline
Old 09-12-2012, 09:56 AM
  #11434
ATMHOBBY's Avatar
Hey guys,
Can you guys tell me a good set of bladders to run? the stock ones are not so good.
ATMHOBBY is offline
Old 09-12-2012, 12:07 PM
  #11435
jwcobra03's Avatar
Trader Rating: 69 (100%+)
Originally Posted by ATMHOBBY
Hey guys,
KYOIF346-03
jwcobra03 is offline
Old 09-12-2012, 12:19 PM
  #11436
Coach Townsend's Avatar
yes
Coach Townsend is offline
Old 09-12-2012, 01:36 PM
  #11437
SEF
SEF's Avatar
Originally Posted by Coach Townsend
yes
Yes to both? No need to try to tune plunge if the universals are popping out
SEF is offline
Old 09-12-2012, 02:30 PM
  #11438
Jammin57's Avatar
Trader Rating: 120 (100%+)
The 93mm universals were built because people were having problems with them coming out of the outdrives in the rear when running a lot of rear toe and then people started running them up front
Jammin57 is offline
Old 09-12-2012, 03:28 PM
  #11439
ATMHOBBY's Avatar
Originally Posted by jwcobra03
KYOIF346-03
Thanks! Ordered!
ATMHOBBY is offline
Old 09-12-2012, 05:57 PM
  #11440
seth556's Avatar
Trader Rating: 43 (100%+)
I had an issue with the fronts popping out. I had the front pop out and jam against the outdrive when the suspension was under full compression (or the driveshaft caused it to fully compressed). First time I'd ever seen it happen.
seth556 is offline
Old 09-12-2012, 06:35 PM
  #11441
305M3's Avatar
i had that happen to my STRR EVO. Same concept, under full compression, the left side (as it drives) drive shaft popped out. Had a Kyosho guy tell me to shim my diff more to the left. Looking at it from the front, or from the top, i could tell the diff was shifted more to the right. Very weird, but I've done his fixes and we'll see if it works...
305M3 is offline
Old 09-12-2012, 06:41 PM
  #11442
foampervert's Avatar
Default try dual rates...
I had it happen to me once during a race and the marshals weren't keen to help disentangle the axle/cup. Lost several laps whilst my mechanic (who is +cough+overweight+cough) retrieved the buggy and resolved it in 2 seconds.
In the end, we realized that the mp9 didn't actually need full lock steering to get the turning effect i wanted. I dialed in about 20-30% (depending on track) dual rate and am still able to drive it comfortably and have it turning on a dime (try other adjustments). Never had a front axle lock up again. Also, full lock steering just causes a lot of tire scrub... Not great if you use super soft tires.
On the other had, if you are still using (and here, I'm not mocking, cos the stock item is ace) the stock plastic front c-hub, check to see if it's bent or worn. if it is, replace it (with the Alu part?). a worn front c-hub does tend to cause the front axles to bind.
foampervert is offline
Old 09-12-2012, 09:12 PM
  #11443
Xyzzy's Avatar
Trader Rating: 32 (100%+)
New to the MP9 here. In every Kyosho 1/10 kit I have built I replace the flanged washer in the steering rack with a flanged bearing. Is this an option for the TKI3? (See pic.)
Thanks!
Xyzzy is offline
Old 09-12-2012, 09:37 PM
  #11444
Registered User
Trader Rating: 2 (75%+)
Thanks!
Yes it is. Sorry I dont remember the size. Just take the collar with you to buy the bearing.
JColeman is offline
Old 09-13-2012, 12:39 AM
  #11445
Thanks!
I am not trying to stop you to buy the bearing, but do you really think bearing is necessary there? Without bearing it's already the most free steering rack I ever built...
Uwiikz is offline
