Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 09-07-2012, 10:59 AM
  #11356
Coach Townsend's Avatar
Originally Posted by Stardust
I am waiting for the Worlds Edition TKI3 Kanai was testing some much bigger shocks seen a spy pic don't remember what link? .. It will be interesting to see what new parts will show up at this year's world event.
Thats all i do in st. louis is test. I've been running the truggy shock bodies with the medium shafts and flat shock caps. With the shocks on the outside holes on are and middle on the tower.
Up front no big change but i might test the medium shock bodies and small shaft on the outside on the arms with flat cpas. OR use the small shocks with old caps
Coach Townsend is offline
Old 09-07-2012, 09:42 PM
  #11357
Stardust's Avatar
Originally Posted by Jammin57
I think the Pic you are talking about was the rear shocks on the front with the eu tower, I don't think there will be any parts at the worlds that are much different from the stock tki3
No that wasn't it, the shock bodies were bigger in size than the current Big bore shocks.. Kanai is always testing new parts and new ideas so I would be surprised if we do not see anything new? Will see.
Stardust is offline
Old 09-07-2012, 09:50 PM
  #11358
Stardust's Avatar
Nice Coach.. Notice any performance advantages with your testing?
Stardust is offline
Old 09-07-2012, 10:28 PM
  #11359
Guest
Originally Posted by trazom
You use droop gauge support blocks 30mm to adjust ?
no, i use a pair of calipers to measure the droop.
i set my droop
then ride height
then camber.
then i recheck ride height again.
LOSIRACER77 is offline
Old 09-07-2012, 10:30 PM
  #11360
Guest
one of these days i will make this 4 hour trip to run with u sir. i want to learn more, about this great buggy.
Old 09-08-2012, 07:30 AM
  #11361
Default more steering please
hi All,
Had a maiden track day with the K today, it definitely a crazy nice car to drive, unbelievable stability both on ground and air, lands like a cat, bery very forgiving and fast... I NEVER try a car that drive this nice out of the box....full stop....However, i can use more steering as i always got beaten on tight 180 or chicanes. I also drive well sorted serpent and team c and both crave corner like flipping a book, off course both are well sorted already as i have owned both for months and today was only my first day with the K.
The setup of the K car is box stock except FRONT orange spring, 1.3x6 piston, 500 cst, REAR stock blue spring, 1.3 x8 piston, 475 cst. Everything else box stock.
Any advice to get more steering? Both on and off power... Thanks in advance folks....
Uwiikz is offline
Old 09-08-2012, 08:10 AM
  #11362
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Default ride height
Recently when resetting my ride height (29/29) I am almost running out of threads on the shock bodies to move the collars down. I recently replaced all my front and rear plastics and my droop is set to 99/118.
I don't notice any adverse affects from this, but it sure looks strange compared to other's K cars. Thoughts?
hookem34 is offline
Old 09-08-2012, 08:25 AM
  #11363
CaptainHowdyt13's Avatar
Trader Rating: 33 (97%+)
I presume Kyosho France is the cheapest place to order a TKI3? It doesn't give me the option to fill out my billing/shipping address properly. I can only choose from French cities.
Anyone order from them before, or know of a place domestically that sells them a little cheaper?
CaptainHowdyt13 is offline
Old 09-08-2012, 08:29 AM
  #11364
Originally Posted by Uwiikz
hi All,
Why the difference in the front to standard setup?Have you tried 1.3 x 8 and blue springs at front?
30Tooth is offline
Old 09-08-2012, 09:18 AM
  #11365
This might sounds stupid, but i rUn that (soft spring upfront 1.3x6) on my serpent and i get crazy steering just thinkin to give it a try Initially i wanted to run 1.3x8 straight hole all around but lhs have only a pair on stock, so i run 1.3x8 rear and 1.3x6 front. I tried blue spring upfront with 1.3x6, but i definitely get more steering with orange spring upfront.....should i try stock tappered hole 1.3x8 or what? Thanks for any advice.
Other than the need for more steering, this car kick ass in any other aspects....
Uwiikz is offline
Old 09-08-2012, 09:30 AM
  #11366
I do not know the price sell by Kyosho France but the store "Wartelle Shop" sells them 599 euros.
trazom is offline
Old 09-08-2012, 12:09 PM
  #11367
KarBro's Avatar
I have a little problem, Im running the stock clutch on an Alpha A852 and after a few tanks (runs) the clutch ends up stuck/engaged so it is driving the whole time, this happened last weekend so I re-shimmed it, Im using three thin shims not the 132 one, I guess Im doing something wrong the way Im shimming it or is it caused by that the clutch hitting the chassis, could this bee creating heat or problems to the clutch?
I used a dremmell, and dremmelld away some of the material on the chassis under the clutch bell, but I must take away more or just drill a hole, like Ive seen some have done here on RC Tech..
How are you all shimming the stock clutch? photos are always good
/K
KarBro is offline
Old 09-08-2012, 05:45 PM
  #11368
What rx batteries is everyone using in the tki3 and evo truggy.
flap jack is offline
Old 09-08-2012, 05:54 PM
  #11369
305M3's Avatar
Trader Rating: 43 (100%+)
Maxamps, 1700mAh Lipo. They are amazing!
305M3 is offline
Old 09-08-2012, 05:55 PM
  #11370
jmackani's Avatar
Trader Rating: 14 (100%+)
/K
Are you sure your clutch bearings may not be the issue?
jmackani is offline
