Inferno MP9 thread
shim the axles further in put the shims on the end of outdrive then slide it throught the carrier. I would say at least 2 shims
Hi i'm thinking of buying the mp9tki2 kit. firstly does it take hump receiver packs? Secondly are there common issues that i need to be aware of and what spares are necessary.
cheers
cheers
Does anyone run the MP9 in the new york area?
Do most people run normal wheel hubs front and rear for the tki3?
Or do you use the narrow wheel hubs in the rear as shown in the exploded view in the manual.
I'll probably end up testing several combinations, but wanted to see what the majority of people run. Thanks.
We have had some issues with the Narrow hubs on the rear with the wheel stripping and having to be cut-off. No problems since replacing hte rear norrow with the normal ones...
I was thinking of playing with the hub offset as a tuning option, but it is good to know that some people have had issues with them in the past.
Anyone please answer.
i guess i am not smart enough the sign in a new account at http://www.the-kyosho-store.com/page-accueil-144.htmlt
i need a little help guys
Click the british flag in the top right corner and it will change almost everything to English and you can set up a account and order anything off the site
the kit set up is a good starting point, what i have been told is to run the narrow all round for low grip and normal all round for high speed high grip tracks, not had any issues with the narrow hubs so far but time with them on has been limited, a good tip is to make sure you apply some of the ring gear grease over the threads to stop them from binding up causing issues
hey guys can the 34 mm flywheel be used on mp9 tki2 ie the m2c style
thanks for any help
thanks for any help
