Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 08-24-2012, 09:40 AM
  #11221
adrictan's Avatar
Originally Posted by Happy Meal
Hey, Sean
Do you know of another place to get this at a low price? A-main doesent seem to have it....only available with the c-hub....
Thanks!
http://www.nitrohouse.com/Front-Hub-...P9_p_3049.html
adrictan is offline
Old 08-26-2012, 06:17 AM
  #11222
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Default McBride on FIRE
Another K car victory!
FEMCA Champion
hookem34 is offline
Old 08-26-2012, 10:45 AM
  #11223
Happy Meal's Avatar
Thanks...
Happy Meal is offline
Old 08-26-2012, 11:04 AM
  #11224
Gentlemen, what's the bearing size of the Aluminum rear hubs? Thank you
Chicken talk is offline
Old 08-26-2012, 11:21 AM
  #11225
SteveP's Avatar
8 x 16mm
SteveP is offline
Old 08-26-2012, 03:03 PM
  #11226
thank you
Old 08-26-2012, 03:10 PM
  #11227
CaptainHowdyt13's Avatar
Trader Rating: 33 (97%+)
I'm coming from an MBX6 and am wanting to try an MP9. is the TIKI3 noticeably better than the TKI 2?
I'm trying to figure out if I'd be satisfied with the TKI2 or if I need to hold out for the updated car.
anyone gone from mugen to kyosho and can give me an idea of the difference in handling?
CaptainHowdyt13 is offline
Old 08-26-2012, 04:17 PM
  #11228
Jammin57's Avatar
Trader Rating: 120 (100%+)
Only difference is the radio tray, front shock tower and the thicker universals. The radio tray can be updated for about $50 but there isn't any changes that would make the car handle different except for the forward mount battery box
Jammin57 is offline
Old 08-26-2012, 05:13 PM
  #11229
so if I like the radio tray buy it. got it.
Old 08-26-2012, 06:17 PM
  #11230
eper's Avatar
Trader Rating: 14 (100%+)
Are you guys running the stock brake rotors or should i go in a aftermarket direction?
eper is offline
Old 08-26-2012, 06:30 PM
  #11231
setanborneo's Avatar
ive gone from mugen to kyosho, the difference is handling, mugen is smooth car entering and out corner, kyosho car is so fast to entering corner dan out corner.
you can more push your car with kyosho, its my opinion (sorry if my english is bad)
setanborneo is offline
Old 08-26-2012, 06:32 PM
  #11232
stock always best i think
Old 08-26-2012, 07:58 PM
  #11233
Xray XB8's Avatar
Hey guys I've got a question. I'm planning on switching from my XB9 and buying a TKI3 but what I am trying to find out is if there is anything special I need to do or buy so I can do it while building the kit. For instance I remember the older mp9's having outdrive problems and people were using agama ones to fix it or if there is any extra shimming or other extra build things that isn't in the manual but y'all have found needs to be done. Or has everything been pretty much fixed and is pretty much dead on when built. I've owned several cars in the past but this will be my first Kyosho so I'm anxious to see how it turns out. Thanks in advance for the info.
Xray XB8 is offline
Old 08-26-2012, 09:14 PM
  #11234
Jammin57's Avatar
Some of the first tki3 kits had over hardened out drives and some people used other out drives and if you bought the kit in the states kyosho would send you free replacements I have owned the tki1, 2 and 3 and have only broke one outdrive and a dog bone came out and I was trying to pop it back in with a screw driver in the middle of a race, nothing is need as upgrades in the kit and it comes with shims you may need for the diffs. The only thing you may want to switch is different shock pistons depending on what you prefer
Jammin57 is offline
Old 08-26-2012, 09:33 PM
  #11235
buchanan88's Avatar
I have a D8 hara, just wondering if anyone can compare the two...Im thinking of making the switch! Ive tried everything to get the buggy to handle and it just remains inconsistent, wanting something a little easier to drive and win some races!
buchanan88 is offline
