Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 08-13-2012, 07:48 PM
  #11146
Jammin57's Avatar
Trader Rating: 120 (100%+)
Originally Posted by LOSIRACER77
how much is shipping to the usa????
With shipping to Arkansas it was $695 and a few others have bought it in the US and the price was the same
Jammin57 is offline
Old 08-13-2012, 07:59 PM
  #11147
houston's Avatar
Trader Rating: 96 (100%+)
Originally Posted by Nitronut3
Dont not run the CVDs in the front, they do not have the flexability of the Unis and break under full lock steering, ive broke two in the front and two in the back. i put the HD unis back it and no problems since. and i think the unis are a tick smoother too.
thats weird Nate i have ran them on one car for about 5 gallons and the only one cvd that wore was the front center , the rest were very tight still , i was very happy with them TIP: do not put a set screw in the barrel , this is part of the reason they are made the way they are with the aluminum covers over the rotating assembly
there really isnt a huge advantage to the cvd's but they have worked great on one of my mp9 cars , the one i have been running for a season and a half (its the decked out one )
btw, the front center driveaxle wears out no matter which you use
houston is offline
Old 08-13-2012, 08:17 PM
  #11148
305M3's Avatar
Trader Rating: 43 (100%+)
+1 - Same price to VA.
305M3 is offline
Old 08-14-2012, 06:44 AM
  #11149
jwood7's Avatar
Default shock rebound?
just wondering how guys are setting the shock rebound and why. i just started playing around with this.
thanks
jwood7 is offline
Old 08-14-2012, 12:11 PM
  #11150
Xyzzy's Avatar
Trader Rating: 32 (100%+)
I'm in Arkansas and when I went through the checkout it said $724.75 total.
How well was it boxed/shipped?
I think they are out of stock now. Even with the English button turned on it is a complicated web site.
$725 isn't a bad deal, though!
Xyzzy is offline
Old 08-14-2012, 12:44 PM
  #11151
Jammin57's Avatar
I live in hot springs so maybe they raised the price on the kit or the shipping is higher and the kit box was inside another box with plenty of packing
Jammin57 is offline
Old 08-14-2012, 01:55 PM
  #11152
KarBro's Avatar
My MP9 is completed, what a build I must ad, now Ive got some itchy fingers to get it out on the track.
[IMG][/IMG]
Last edited by KarBro; 08-14-2012 at 01:57 PM. Reason: First time posting an image.
KarBro is offline
Old 08-14-2012, 02:09 PM
  #11153
305M3's Avatar
[IMG][/IMG]
Congrats. Is that the bittydesign pre-painted body? Very, very nice looking.
305M3 is offline
Old 08-14-2012, 02:16 PM
  #11154
KarBro's Avatar
Thank you, Ive actually painted the body my self, but heavily influenced by Bittydesign. It turned out quite good.
Im thinking of getting the new cabforward TKI3 body or the Bittydesgn Force, but first I need to get the car out on the track. I cant wait!!!
KarBro is offline
Old 08-14-2012, 07:22 PM
  #11155
nacho_gas's Avatar
Originally Posted by nacho_gas
Hi, Has anyone used the TCD front differential?
http://www.amainhobbies.com/product_...o-TCD-Gear-Set
Has any answers?
David Ronnefalk used this system in the front differential with 7-5-3 or 10-5-3
nacho_gas is offline
Old 08-14-2012, 08:32 PM
  #11156
drstrangelove's Avatar
Yah bro, it does feel good when you have that confident to go full throttle and you know your bug will go the direction you want or control them enough to fall where you want it too. Now it's all about me controlling it to the maximum.
Good luck for this weekend race!
Cheers
Great to hear you've worked through the million different setup options available on these cars to find something that works for you. My buddy, totally unfamiliar with the hobby, asked why there were so many options and settings.
I told him that like the snowflake, no two drivers are alike.
On an unrelated note, I HOPE I figured out my "brown out" issues. I essentially got a new radio system (radio/receiver/servos) and more importantly got new receiver batteries. I asked MaxAmps to build a 1700mAh receiver battery and it is AWESOME! I raced this weekend and experienced NO issues. Fingers crossed for this weekend at the Wicked Weekend in GA.
drstrangelove is offline
Old 08-14-2012, 08:34 PM
  #11157
How often do you replace your brake pad? Or you don't?
Old 08-14-2012, 08:41 PM
  #11158
Sweet looking bug you have there bro.
[IMG][/IMG]
Old 08-14-2012, 11:49 PM
  #11159
Tyson72's Avatar
[IMG][/IMG]
That looks so awesome! I would be too scared to get it dirty LOL
Tyson72 is offline
Old 08-15-2012, 06:26 AM
  #11160
305M3's Avatar
Replace? I'd have to use my brakes to justify changing them.
Just kidding, but I'm not sure. I did notice during my last race significant brake fade and it was annoying. We have a long stretch in the back that goes into an impossible rhythm section that I end up "standing on the brakes" so i don't go shooting off into the woods (which I did twice during that day).
I saw these on neobuggy:
PSM 'VX3' Brake discs
They look interesting and if I could get ahold of some, I'd try them out.
305M3 is offline
