Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 08-11-2012, 05:56 AM
  #11116
ben73's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Imcaracer20
so i was thinking of putting the alum c hubs on, is it worth it?
I run them, they take the flex out of the plastic standard ones which people have had some issues with - related to popping uni's
ben73 is offline
Old 08-11-2012, 11:27 AM
  #11117
Heya Guys, I saw a few of you guys are running OS Speed with this buggy. I'm running on a big fast track, the dirt nitro challenge track, what kind of run times are you guys getting on the OS Speed? I'm debating on weather to buy another one as a back up but only if I can get 10 minute pits with this engine. I might have it ready to fly tonight
Vortexted is offline
Old 08-11-2012, 11:53 AM
  #11118
houston's Avatar
Trader Rating: 96 (100%+)
Originally Posted by rallyebmx
On your diff gear wear, I know I'm not the only one suffering from dirt entering the bulkheads from the mating surface to chassis. I am on to sealant now after trying grease to create a seal in this area
When installing your front/rear end on the chassis plate lay down some lucky7/airseal where the bulkhead meets up around the outside of the screws , it works awesome . Silicone works ok also but i much prefer using the lucky7/airseal
houston is offline
Old 08-11-2012, 01:39 PM
  #11119
Afun's Avatar
Trader Rating: 19 (95%+)
Do you mean using special o-ring grease for the o-ring diffs. I have not had any issues with dirt getting in. I have been told that the precision of the suspension on these cars are hard on the chassis and most components... including diff gears.
Afun is offline
Old 08-11-2012, 01:49 PM
  #11120
Afun's Avatar
The OS SPeed is the smoothest, powerful, and best tuned engine I have ever owned. I think its weak point is run time. Using a OS 2090 pipe, VP Fuel, and 6 carb venturi you could get close to 10 minutes. I have yet to push my car to that limit in fear of fueling on an empty tank and flaming out. I am currently using a 6.5 carb venturi and happy with its tuning window. I am sure some other guys with more experience can help.
Afun is offline
Old 08-11-2012, 08:47 PM
  #11121
Guest
Default tki3
hello guys where can i find the cheapiest price on a tki3????
LOSIRACER77 is offline
Old 08-11-2012, 09:29 PM
  #11122
Jammin57's Avatar
Trader Rating: 120 (100%+)
http://www.the-kyosho-store.com/
Jammin57 is offline
Old 08-11-2012, 09:48 PM
  #11123
305M3's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Jammin57
+1. Just got mine today. Took 9 days from the day they sent to get to me.
Jammin and Lewis, to answer the ?'s I bothered U guys w/ earlier. It came via USPS and no signature was required.
305M3 is offline
Old 08-12-2012, 12:41 AM
  #11124
rallyebmx's Avatar
Trader Rating: 21 (100%+)
I'll try some lucky 7 next. I currently use racers edge sealant. It seemed to block almost all the dirt. It was better than grease. Strange problem for a well established company.
rallyebmx is offline
Old 08-12-2012, 06:16 AM
  #11125
Tyson72's Avatar
Originally Posted by smelly62
He will if the Mrs finds out
Just read that comment out to her...she says ohh great u will spend even more time in the shed LOL
Tyson72 is offline
Old 08-12-2012, 08:49 AM
  #11126
nitroxr's Avatar
Hey everyone I just picked up a mp9 tki2 and I want to upgrade the battery tray to tki3. Is there anything else that I will need to order besides the battery and receiver box? Any help would be great.
nitroxr is offline
Old 08-12-2012, 09:13 AM
  #11127
Jammin57's Avatar
You also need the radio tray and the transponder mount
Jammin57 is offline
Old 08-12-2012, 09:20 AM
  #11128
A small report for those that want to know the difference between using 7-5-3 against 5-5-3.Yesterday tried 5-5-3 for the first time in my car.With 7-5-3 for me the front pulls and is noticeable the loss of turn-in,couldn't counter-steer safely while on power or it would bite back.The pull is nice to have provided there's high traction tough.
With 5-5-3 I can feel the time when the car tells me it's being over-driven and it's mindless to throw into corners,it just works right.Should've tried sooner!
30Tooth is offline
Old 08-12-2012, 10:32 AM
  #11129
houston's Avatar
5f-7c-3r or 2r
houston is offline
Old 08-12-2012, 11:23 AM
  #11130
Thanks houston,what should I expect from that setup?Nonetheless will try next practice
30Tooth is offline
