Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 08-07-2012, 11:56 AM
  #11071
jzemaxx's Avatar
Originally Posted by elkapitan
Just following the same road AE did with the RC8.2. To be competitive pretty much it needs to be an MP9 clone...lol
jzemaxx is offline
Old 08-07-2012, 12:06 PM
  #11072
drstrangelove's Avatar
You are going to love it bro. I love mine and never look back. People tell me they are expensive, that it's the driver and not the car that win a race but you just have to own it to understand it!
Originally Posted by KarBro
I got my MP9 TKi3 kit today, so let the building begin
drstrangelove is offline
Old 08-07-2012, 12:12 PM
  #11073
jpz_67's Avatar
Trader Rating: 56 (100%+)
Question for the Kyosho guys. Is there a 6 hole 1.3 shock piston that not only the piston tapered but the holes are tapered or conical? Thanks.
jpz_67 is offline
Old 08-07-2012, 01:09 PM
  #11074
305M3's Avatar
Trader Rating: 43 (100%+)
Congrats. The build is great, driving it is even better!
305M3 is offline
Old 08-07-2012, 08:14 PM
  #11075
Hey bro, did you solve your switch issue?
Old 08-07-2012, 08:21 PM
  #11076
305M3's Avatar
Naw man, still troubleshooting - haha. Being an engineer, I have these elaborate troubleshooting diagrams and it's looking like it may be the battery.
Thanks for asking brother.
305M3 is offline
  #11077
Guest
Default kyosho
hello guy i believe i will be joining the kyosho tki3 buggy this year, what else to do i nedd to buy???
LOSIRACER77 is offline
Old 08-07-2012, 11:27 PM
  #11078
AZRC4Me's Avatar
As an engineer myself, I had to laugh at picturing your elaborate troubleshooting diagrams! Hope you get it sorted. What switch are you using?
AZRC4Me is offline
Old 08-07-2012, 11:30 PM
  #11079
AZRC4Me's Avatar
The only thing that I would purchase right away that doesn't come in the kit, is the 1.3x8 straight hole pistons. Otherwise, buy the usual spares - arms, hinge pins, shock shafts, and maybe some other plastics. You don't really need the pistons right away, but that's what everyone runs. Everything you need comes in that beautiful black box.
AZRC4Me is offline
Old 08-07-2012, 11:33 PM
  #11080
AZRC4Me's Avatar
Short answer, no.
Long answer, the only 1.3x6 hole pistons are straight holes. The SP pistons also have straight holes, but they're drilled at a 45 through the piston. The holes themselves are not conical or tapered in any piston Kyosho makes to my knowledge.
AZRC4Me is offline
Old 08-07-2012, 11:35 PM
  #11081
nacho_gas's Avatar
hello
I usually use "5-5-2" in differentials. I feel more comfortable with "5-5-2" than with "5-5-3"
I'm thinking of trying something harder as 7-7-3, 10-10-5 ...
What do you think? What you use in differential setup? and How does the car?
thanks
nacho_gas is offline
Old 08-08-2012, 07:48 AM
  #11082
305M3's Avatar
Hey Sean: Using the KO Switch 2. I am using Lipo, so adjusted the Switch appropriately - turned off Lipo cutout.
I've changed the Switch to a regular switch (JR) and I still get the issues. The "brown out" occurs about 10-12 minutes into a race (~250-300mAh out of the battery) when I TURN "and" TH/BRAKE at the same time.
My gut is telling me that it is the battery b/c that is the only component that was changed since I started having these issues. However, the issues go away when I plug the battery directly into the receiver. Very interesting.
Oh, it's a Revtech 2500mAh, Lipo.
If you want a good laugh, I'll pdf my work and send it to you.
305M3 is offline
Old 08-08-2012, 09:26 AM
  #11083
Afun's Avatar
Trader Rating: 19 (95%+)
I agree 100%. You have to own one to understand how good it really is. I have never felt a drivetrain that is so smooth. Also, nothing fancy about the Kyosho's, just the aluminum parts. Everything has an old school design to it. Clutch, knuckles, throttle assembly, etc... I came from using a Mugen MBX5r and Agama A8. Very worthy competitors for the MP9.
Afun is offline
Old 08-08-2012, 11:50 AM
  #11084
jpz_67's Avatar
Short answer, no.
Ok, thanks brotha.
jpz_67 is offline
Old 08-08-2012, 12:42 PM
  #11085
nacho_gas's Avatar
Originally Posted by nacho_gas
hello
I'm thinking of trying something harder 7-7-3 or 10-10-5 ...
thanks
Has any answers?
