Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 08-06-2012, 03:21 AM
  #11056
With 1.3 x 8 pistons, is it tapered side of piston down?
thorns is offline
Old 08-06-2012, 03:23 AM
  #11057
pitpop's Avatar
tapered side goes away from the cap, toward the cartridge
pitpop is offline
Old 08-06-2012, 03:24 AM
  #11058
Cheers mate.
thorns is offline
Old 08-06-2012, 03:33 AM
  #11059
Guest
Originally Posted by LOSIRACER77
ok guys i am looking for a new nitro buggy, some tell how this cars compares with the losi 2.0 buggy, the wear and tear on these buggys???? i want some new at the track,
please anyone??????
LOSIRACER77 is offline
Old 08-06-2012, 06:07 AM
  #11060
ben73's Avatar
Trader Rating: 40 (100%+)
please anyone??????
ok so I ran a losi a couple of years ago for 18 months. Both very good cars.
The Tki3 is as easy to work on as the Losi which is great, the Tki3 handles all types of tracks really easily with minimum setup changes. The Tki3 comes with everything you need in the kit. The Losi you need to buy extra bits
In terms of wear I would say the plastics are on par, it may lean in favour of the K car. But only just.
You wont be unhappy with the Tki3
ben73 is offline
Old 08-06-2012, 07:26 AM
  #11061
Default Insomnia?
Posting at 2:23am? They make pills that help u sleep! HA!
dirtn is offline
Old 08-06-2012, 08:57 AM
  #11062
305M3's Avatar
Trader Rating: 43 (100%+)
+1. I also came from an 8B and 8T 2.0's. With the 8's I was concerned w/ the rear coming out or the "twitchy-ness" causing me to concentrate on side-to-side corrections as much as I was concerned with going fast in a straight line. The MP9 slowed down the race for me b/c of its stability (eliminating side-to-side concerns) and enabled me to focus on going fast in a straight line. Truly point and shoot.
Also, the shocks absorb EVERYTHING.
Difficult to explain in words and the best suggestion is to find someone who will let you wheel their MP9 for a couple of laps. The downside is after those couple of laps, you'll end up replacing all your Losi stuff w/ Red Army gear.
305M3 is offline
Old 08-06-2012, 02:34 PM
  #11063
Coach Townsend's Avatar
305M what is your home trak
Coach Townsend is offline
Old 08-06-2012, 03:22 PM
  #11064
305M3's Avatar
Awesome RC in Fredericksburg, VA. Stop by anytime, great group of folks and great facility.
305M3 is offline
Old 08-06-2012, 10:59 PM
  #11065
AZRC4Me's Avatar
Originally Posted by smelly62
But apparently I shim diffs wrong.:lol
There's really no wrong way to shim a diff, it's all based on manufacturing tolerances. Just don't make them too tight or too loose and you should be good to go.
Originally Posted by Dyno-Dylan
The diffs you interchange, do they have different weight oils in them? If so, which do you usually switch between?
I've tried different oils before, I settled on 6/4/4, but I didn't like this as much as 5/5/3 (what I run everywhere now). So no, I really don't switch fluids, it's just nicer to rebuild a bunch of diffs at once then swap in fresh ones during a rebuild.
Originally Posted by Afun
With proper work on the buggy, how long do you think these buggies are good for? I would hate to hear a season. I want to keep this car forever. It does not get any smoother.
I really think that's a loaded question that's going to depend entirely on how you drive, the track you drive on, and how often you race and replace/rebuild components. Any rc car takes a ton of punishment, especially in long mains. If you err on the side of caution and replace parts before they get too worn, you'll be less likely to have more severe and costly issues. Going into a big race, I tend to go in with as many new components as possible, with maybe a tank on them just to shake them down. I figure that if I'm going to a race for several days and spending upwards of $50 on entry fees alone, I'm not going to chance a used clutch spring, plastic, etc over the length of an event. I mean, anything can happen and I'm not afraid of the durability of anything in the MP9, it's just I'd rather be on the safe side.
Originally Posted by Nitronut3
I saw this last Saturday, a guy just switched from serpent and had the same prob, he had the 46/13 combo just like mine and couldn't figure out y mine was tighter than his. I looked his buggy over and found that he was running the center diff spacers to lift the center diff up. Took those out and no problems with mesh again
That's interesting...I've run before without the spacers, but I added the spacers recently and didn't notice my mesh change. I actually like the spacers as they raise the spur gear above the bottom line of the chassis, and I've noticed my spur gears have substantially less chips on the ends of the teeth than they did before.
We run OS and they hit the bottom engine mount plate so it was out with the dremmel and put a 45 deg chamfer on the edge of the inside plate. All fixed now.
I ran OS before and this is definitely the trick . Smelly's talking about the fixed flat plate closest to the rear center driveshaft that the engine mount block slides on - just give it a little chamfer for some added clearance. Also make sure your gears aren't too worn.
AZRC4Me is offline
Old 08-07-2012, 03:47 AM
  #11066
check out the new kyoshorango
http://www.neobuggy.net/modules/news...?storyid=12375
elkapitan is offline
Old 08-07-2012, 04:00 AM
  #11067
nice input sean, better to be proactive rather than reactive maintenance, which addresses such problems only when they surface and will lead you into more expensive repairs.
Old 08-07-2012, 05:03 AM
  #11068
drstrangelove's Avatar
I thought its a new kyosho buggy man!
It's just a prototype but strange to be using other brand parts for your prototype.
Originally Posted by elkapitan
drstrangelove is offline
Old 08-07-2012, 06:40 AM
  #11069
Jammin57's Avatar
Trader Rating: 120 (100%+)
They had those buggies a few months ago but the first buggies they tested had more kyosho parts on them
Jammin57 is offline
Old 08-07-2012, 11:36 AM
  #11070
KarBro's Avatar
I got my MP9 TKi3 kit today, so let the building begin
KarBro is offline
