Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 07-29-2012, 10:21 PM
  #10981
KarBro's Avatar
Originally Posted by nicardyMP9
Just the diff oils, 2 x 5k 1x 3k so you need to buy the shock oil. The kyosho rims you get look like a good design and fit AKA rubber perfectly.
Thank you, IŽve got some Durango and Losi shock oils, they will do for starters. IŽll have to get some tires for the rims, but IŽve got a few sets of AKA- pre mounts.
I see I need a new receiver-battery as mine won't fit the MP9 TKi3, what are you all running?
KarBro is offline
Old 07-29-2012, 10:59 PM
  #10982
nicardyMP9's Avatar
I'm running life and lipo, unfortunately had to ditch my ol trusty 2600mah nimh! decided to ugrade the servos at the same time so got the savox high voltage 67 & 68. One thing that I've notice is make. Sure your on off switch has enough length to reach the battery box, most do but some don't, so Ive upgrade my tki1 to the kopro switch also.
nicardyMP9 is offline
Old 07-29-2012, 11:28 PM
  #10983
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Whats the word on when the new body will be available?
rallyebmx is offline
Old 07-30-2012, 05:50 AM
  #10984
ben73's Avatar
Trader Rating: 40 (100%+)
they have been released and are out. I got a few last week and painted one up on Saturday
ben73 is offline
Old 07-30-2012, 07:58 AM
  #10985
Happy Meal's Avatar
Where?
Happy Meal is offline
Old 07-30-2012, 09:06 AM
  #10986
Are they thin like the kit body ?
evolution03 is offline
Old 07-30-2012, 09:09 AM
  #10987
AZRC4Me's Avatar
Don't think they're out in the US now. The part # is IFB006, which indicates it'll be thin, but I bet they also have an IFB006H which would be the thick body.
AZRC4Me is offline
Old 07-30-2012, 11:50 AM
  #10988
KarBro's Avatar
I have also got the Ko Propo switch. IŽll just get a new hump-lipo-pack, the Team Orion one looks nice, or the Vampire Racing one (it costs nearly 50% less than the Team Orion one here in Sweden).
KarBro is offline
Old 07-30-2012, 12:23 PM
  #10989
Jammin57's Avatar
Trader Rating: 120 (100%+)
I use these packs they work great and are the same as protek packs but a lot cheaper
http://promatchracing.com/proddetail.php?prod=2S2300HP
Jammin57 is offline
Old 07-30-2012, 12:33 PM
  #10990
KarBro's Avatar
Yes they look good, but as I live in Sweden they will not ship lipo-batteries via USPS.
KarBro is offline
Old 07-30-2012, 06:48 PM
  #10991
ben73's Avatar
yes they are thin. Sean is spot on with the product code.
ben73 is offline
Old 07-30-2012, 07:35 PM
  #10992
rallyebmx's Avatar
What country are you in?
Old 07-31-2012, 12:52 AM
  #10993
ben73's Avatar
Singapore
Kyosho shipped out last week to distributors in Asia.
ben73 is offline
Old 07-31-2012, 07:16 AM
  #10994
nacho_gas's Avatar
I bought all the spares necessary to run the Cody King loose dirt setup, but I think I might try the Dirt Nitro challenge setup from the FARM. Anyone tried both setups, be keen to hear how they compared. Cheers
sorry, what is the Cody King loose dirt setup.
nacho_gas is offline
Old 07-31-2012, 08:05 AM
  #10995
http://www.codykingrc.com/category/m...loose_surface/
ratjayfala is offline
