Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 07-26-2012, 07:41 PM
  #10966
Trader Rating: 25 (100%+)
Originally Posted by nicardyMP9
Awesome thanks for your help guys! appreciated. I started the new TKi3 build on Wednesday at 3pm and worked on it till 11pm, then 6 till 12 on Thursday and Im only halfway through the build!!haha I forgot how long (and sometimes tiring) building a new kit can be. I guess it pays to take your time with diffs etc. I wonder what the record time is for completing a kit?? start to finish?
I bought all the spares necessary to run the Cody King loose dirt setup, but I think I might try the Dirt Nitro challenge setup from the FARM. Anyone tried both setups, be keen to hear how they compared. Cheers
I've hammered one together in less than 5 hours, not including body though, I used an old shell to get me over the line.
smelly62 is offline
Old 07-27-2012, 04:33 AM
  #10967
Afun's Avatar
Trader Rating: 19 (95%+)
Originally Posted by rallyebmx
Kyosho sends out front and rear replacements only. I have never heard of a center issue yet. I just saw a 2nd older tki2 outdrive break on an experienced racers buggy 2 weeks ago. Made me think I'll stay with agama units for life of this car
Looks Like I am staying with the Agama front and rear outdrives for good also. Coming from Agama I know how long they will last me. I would say I am good for about a full season before replacing. Have you seen the new Agama outdrives with the curvature at the tip for more up swing? I wonder if it would work on the TKI3
Afun is offline
Old 07-27-2012, 08:20 AM
  #10968
CoryD's Avatar
You may want to start with his base setup and work from there; the MP9 is a very easy car to get working on almost any track. I don't want to say it's a "one setup car" but it's not far off.
Base Setup
If you need more rear grip, lay the rear shock down on the tower 1 hole, and move the inner camber mount to the middle hole (#8).
Later,
CoryD is offline
Old 07-28-2012, 08:02 AM
  #10969
slow coach's Avatar
just noticed this from the xray set up books, one from the older XB8 the other from their set up station book, lots of people use these guides as their bible, but unless the cars themselves are so different that the physics have changed between them, I think perhaps there may be an error!! open them both up and read the effects side by side they contradict each other completely, personally I have used the XB8 set up section of the manual on account of it covering the cars i have run in the past better, where as the new 808 doesn't but which one is correct or could both of them be !!!!????
see what you guys think.
Attached Thumbnails Inferno MP9 thread-xb8-set-up-front-roll.jpg   Inferno MP9 thread-808-set-up-front-roll.jpg
slow coach is offline
Old 07-28-2012, 09:45 AM
  #10970
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
I have found the older definition to be true. Higher roll center makes the car much more responsive.
hookem34 is offline
Old 07-28-2012, 11:24 AM
  #10971
The second one is correct
smelly62 is offline
Old 07-28-2012, 12:17 PM
  #10972
croracer's Avatar
Where can i get a great price on a tki3 right now?
croracer is offline
Old 07-28-2012, 02:31 PM
  #10973
KarBro's Avatar
I just pulled the trigger on one of these here MP9 Tki3 kits, i bought rear-, front-, front top arms and a spare wing. Is there anything els that I should have? Im coming from Durango over to the Red Army! Air cleaner, I forgot to order extra air cleaners.
Will the RB off road starter box work on the Mp9 TKi3? Ill be running my Alpha A852, I think that will make the buggy fly.
Are there oils included in the KIT?
KarBro is offline
Old 07-28-2012, 04:23 PM
  #10974
Default tki 2 wc
Hi guys I just got a tki2 wc I want to sale it but don't know how much to put it up for can any one let me know what to sale it for. Car only has les then a gal .of fuel Thanks Herman
hermsrc is offline
Old 07-29-2012, 02:43 AM
  #10975
More like where can I get a TKI3
$899 US
smelly62 is offline
Old 07-29-2012, 04:22 AM
  #10976
nicardyMP9's Avatar
Just finishing my TKI3 kit tonight, such a nice kit to put together. Kyosho up the stakes with each release, stoked that they included the flanged ball end was a good touch.
The kit comes with the tapered pistons that no one seems to use, so depend on the setup you are going to try I ordered the 1.3 x 8 straight pistons for the front and rear.
I also bought the DE Racing skid plates front and rear.
nicardyMP9 is offline
Old 07-29-2012, 05:21 AM
  #10977
KarBro's Avatar
Cheers, are there oils included in the kit?
KarBro is offline
Old 07-29-2012, 02:35 PM
  #10978
nicardyMP9's Avatar
Just the diff oils, 2 x 5k 1x 3k so you need to buy the shock oil. The kyosho rims you get look like a good design and fit AKA rubber perfectly.
Old 07-29-2012, 09:58 PM
  #10979
CoryD's Avatar
I've been told that we won't see any more TKI3s until August 20th (or so) here in N.America. So if you do find one, pull the trigger or you will be waiting until August.
Later,
CoryD is offline
Old 07-29-2012, 10:11 PM
  #10980
setanborneo's Avatar
Originally Posted by Mindux00
hi there,
could someone post some pictures of the way of fuel tube with pipe 2090? i have this pipe and the place where tube conects with pipe is in a different possition, that i was used to. would like to see how you put your fuel tubes on MP9.
thank You in advance
Kyle Car fuel tube, so nice
Attached Thumbnails Inferno MP9 thread-374156_372117836165413_1153280602_n.jpg
setanborneo is offline
