Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 07-25-2012, 10:33 PM
  #10951
AZRC4Me's Avatar
Originally Posted by Coach Townsend
Not sure yet. if it is i'll just run it from the tank through brake linkage. And not around the carb
I doubt you'll be over, I ran mine like that for a while before going to Tebo's routing. I never tech'd above 124.
AZRC4Me is offline
Old 07-25-2012, 11:24 PM
  #10952
drstrangelove's Avatar
Hey Coach,
I routed the fuel line like yours but when they did a fuel test I failed, so had to cut it much shorter. Maybe it's because I'm not using the stock kyosho filter (but I doubt it). Will be interesting to know if you pass yours. Do share with me if you do any test and pass. I can at least double check with them next time or switch back to Kyosho filter.
Added: Sorry I just realized I'm also not using Kyosho fuel line but the Fioroni one which is slightly thicker.
Originally Posted by hookem34
Coach have you had to "tech" your tank with that fuel line routing before? Are you over/under 125cc?
drstrangelove is offline
Old 07-25-2012, 11:36 PM
  #10953
I've tried running on L tread with the 91mm shaft on my bashing buggy without any problem. Did you shim them from the inside? I put 2 shim on the inside. Now I'm back with the S tread.
For the front, people at my track like to use the 93mm to prevent the shaft from popping out. I've been using the 91mm one for my bashing buggy without any problem though, just make sure you shim on the inside. The Spec A version which is factory build surprisingly did not put any shim on the inside, just 2 or 1 shim on the outside.
For my race buggy, i'm using the Kyosho Light Weight Front Universal Swing Shaft (90.7mm) KYOIFW333. Can't pass you the URL as amain is down for maintenance
Originally Posted by nicardyMP9
Hey guys,
I know this question has been bandied around on this forum before, but just want to check something. The 91mm outdrives supplied with the TKI3 dont seem to be able to work with a L tread width. The only reason I wanted to run a L tread width is that its just what Im used to with the TKI1. But Im finding even when I set it up for a S tread width the dog bones are only just in the diff drive cup? Im sure when its all setup and shocks are on it should be sweet. Im guessing that I need to run the 93mm outdrives to achieve a L tread width?
Old 07-25-2012, 11:52 PM
  #10954
Trader Rating: 25 (100%+)
Actually this is the better choice as it is equal to MP9 92mm shaft which is the perfect length for all adjustments on the rear. They will also fit on the front but some have reported that there is understeer under power due to the different design of the shaft (uni is about 1.5mm in compared to MP9 axles)
http://www.amainhobbies.com/product_...ng-Shaft-907mm
I am constantly surprised why Kyosho have not yet produced the 92mm long/3.5mm thick shafts yet cause if they did there would no longer be problems and confusion with the shafts like there is now. They would work on the front and rear with all settings. Must be a "business" thing, the way it is now they sell twice as much shafts AND all the old 777 shaft stock. At least it keeps up the post count in this thread,
smelly62 is offline
Old 07-26-2012, 02:14 AM
  #10955
Thanks smelly62 for pointing that out, I copy the wrong item.
Old 07-26-2012, 07:00 AM
  #10956
Coach Townsend's Avatar
I sure will on my way to Omaha, NE for the Byrons Race
Coach Townsend is offline
Old 07-26-2012, 07:35 AM
  #10957
Afun's Avatar
Trader Rating: 19 (95%+)
Any thoughts on BCE chassis for the TKI 3?
By the way my 93mm driveshafts for the front with the Agama outdrives work great. I never put in the outdrives that came with the kit just the center ones are Kyosho. Maybe I should call and get new ones for fear of breaking.
Afun is offline
Old 07-26-2012, 08:14 AM
  #10958
My pleasure
smelly62 is offline
Old 07-26-2012, 01:00 PM
  #10959
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Kyosho sends out front and rear replacements only. I have never heard of a center issue yet. I just saw a 2nd older tki2 outdrive break on an experienced racers buggy 2 weeks ago. Made me think I'll stay with agama units for life of this car
rallyebmx is offline
Old 07-26-2012, 02:00 PM
  #10960
Do any brand clutch bells fit the MP9?
IN a bit of a bind, have one ordered, but wont be here before the weekend.
I have a Xray, and a few other random ones at home, but thought I read somewhere that the stock MP9 ones are a slightly different design?
thorns is offline
Old 07-26-2012, 02:02 PM
  #10961
CoryD's Avatar
Any 32mm flywheel will fit.
Later,
CoryD is offline
Old 07-26-2012, 02:33 PM
  #10962
Later,
Yip, but clutch bells?
thorns is offline
Old 07-26-2012, 02:37 PM
  #10963
CoryD's Avatar
OFNA (OFN65028)
Hot Bodies (HBSC8029)
Pro-Tek (PTK-7000)
All very good. I myself toggle between the HB and the ProTek depending which is in-stock when I need one.
Regards,
CoryD is offline
Old 07-26-2012, 05:24 PM
  #10964
Afun's Avatar
Dynamite 13 tooth fits nice
Afun is offline
Old 07-26-2012, 05:45 PM
  #10965
nicardyMP9's Avatar
The rear hub carriers are offset 2mm so when you use the S tread setting it will be the same as the TKI1 with the L setting.
Awesome thanks for your help guys! appreciated. I started the new TKi3 build on Wednesday at 3pm and worked on it till 11pm, then 6 till 12 on Thursday and Im only halfway through the build!!haha I forgot how long (and sometimes tiring) building a new kit can be. I guess it pays to take your time with diffs etc. I wonder what the record time is for completing a kit?? start to finish?
I bought all the spares necessary to run the Cody King loose dirt setup, but I think I might try the Dirt Nitro challenge setup from the FARM. Anyone tried both setups, be keen to hear how they compared. Cheers
nicardyMP9 is offline
