Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 07-24-2012, 05:08 AM
  #10936
oghobavo's Avatar
Fellas, what are you alls opinions on 13-14/48 gearing vs 13-14/46? I recently changed to 14/48 but have yet to get track time with it. I'm hoping that it won't cause excessive wheel spin.....
VinceO.
oghobavo is offline
Old 07-24-2012, 05:39 AM
  #10937
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Originally Posted by oghobavo
Fellas, what are you alls opinions on 13-14/48 gearing vs 13-14/46? I recently changed to 14/48 but have yet to get track time with it. I'm hoping that it won't cause excessive wheels spin.....
VinceO.
I run 13/48 here in SA, but change to 13/46 in Houston for Mikes. No issues with wheelspin now that I run the Buku.
hookem34 is offline
Old 07-24-2012, 08:11 AM
  #10938
VinceO.
we run the 14/48 all the time with no problems, gives you a little more top end speed.
donrod is offline
Old 07-24-2012, 01:02 PM
  #10939
morocho1979's Avatar
Hi im new with kyosho i will race with a tki2 wc with foward battery buy i will use lipo with regulator where i can put the regulator im using novak regulator any have any picture because i put the regulator in the box where the battery was but i need some advise or picture thx
morocho1979 is offline
Old 07-24-2012, 01:55 PM
  #10940
CoryD's Avatar
What radio do you use? Many do not require a regulator; 4PKS, KO Helios to name a pair.
Later,
CoryD is offline
Old 07-24-2012, 02:08 PM
  #10941
Trader Rating: 19 (100%+)
Default BUKU
How do you like the buku clutch? I 've been running my mp9 for two years with the stock clutch and have considered trying the buku.
Chartos is offline
Old 07-24-2012, 02:30 PM
  #10942
Later,
I use ko pro with spectrum module but I don't use lipo servos
Old 07-24-2012, 03:17 PM
  #10943
AZRC4Me's Avatar
VinceO.
Listed in order of bottom end speed to top end speed:
48/13 - 3.7 ratio (most bottom end)
46/13 - 3.5 ratio
48/14 - 3.4 ratio
46/14 - 3.3 ratio (most top end)
I prefer 46/13, 48/14 is like going up half a tooth on your clutch bell.
AZRC4Me is offline
Old 07-24-2012, 10:06 PM
  #10944
Exist any way to use a 15bell using another spur ??
Old 07-25-2012, 09:03 AM
  #10945
Coach Townsend's Avatar
,. just a few mods i've done
Coach Townsend is offline
Old 07-25-2012, 09:05 AM
  #10946
This how I ran my fuel line
Old 07-25-2012, 11:36 AM
  #10947
hookem34's Avatar
Coach have you had to "tech" your tank with that fuel line routing before? Are you over/under 125cc?
hookem34 is offline
Old 07-25-2012, 12:07 PM
  #10948
Not sure yet. if it is i'll just run it from the tank through brake linkage. And not around the carb
Old 07-25-2012, 06:36 PM
  #10949
nicardyMP9's Avatar
Hey guys,
I know this question has been bandied around on this forum before, but just want to check something. The 91mm outdrives supplied with the TKI3 dont seem to be able to work with a L tread width. The only reason I wanted to run a L tread width is that its just what Im used to with the TKI1. But Im finding even when I set it up for a S tread width the dog bones are only just in the diff drive cup? Im sure when its all setup and shocks are on it should be sweet. Im guessing that I need to run the 93mm outdrives to achieve a L tread width?
nicardyMP9 is offline
Old 07-25-2012, 09:09 PM
  #10950
Trader Rating: 25 (100%+)
Originally Posted by nicardyMP9
Hey guys,
The rear hub carriers are offset 2mm so when you use the S tread setting it will be the same as the TKI1 with the L setting.
smelly62 is offline
