Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 07-22-2012, 03:33 PM
  #10921
Jammin57's Avatar
Trader Rating: 120 (100%+)
He just means that it's a good buggy, there is no overdrive gears for the mp9.
Jammin57 is offline
Old 07-22-2012, 05:30 PM
  #10922
nacho_gas's Avatar
ok thanks!
nacho_gas is offline
Old 07-22-2012, 07:18 PM
  #10923
Afun's Avatar
Trader Rating: 19 (95%+)
Originally Posted by slow coach
you could try this option but run through the tank the other way to come out in front of the pressure nipple
Coach,
Shouldn't the fuel line go from the end of the filter straight to the carb?
Afun is offline
Old 07-22-2012, 08:20 PM
  #10924
oghobavo's Avatar
My fuel line routing....
Attached Thumbnails Inferno MP9 thread-fuel3.jpg   Inferno MP9 thread-fuel5.jpg
oghobavo is offline
Old 07-22-2012, 09:09 PM
  #10925
Pete Martinez's Avatar
Trader Rating: 17 (100%+)
If anyone is interested I am selling my TKI 2 and .19 os speed motor.
Pete Martinez is offline
Old 07-23-2012, 01:44 AM
  #10926
drstrangelove's Avatar
Bro, will the length of your fuel line pass the fuel test?
I have to cut mine to be shorter as I failed the fuel test during one of the race.
drstrangelove is offline
Old 07-23-2012, 07:25 AM
  #10927
When will this be on sale?
I'm referring to the pit mat
Old 07-23-2012, 07:37 AM
  #10928
Afun's Avatar
I like the way you wrao the fuel line around the air filter and have the carb nipple facing up. I have always had the card nipples facing semi sideways or down. Whats the reason for the.excess fuel line on the front chassis brace?
Afun is offline
Old 07-23-2012, 07:58 AM
  #10929
Happy Meal's Avatar
cool
Happy Meal is offline
Old 07-23-2012, 08:08 AM
  #10930
Happy Meal's Avatar
[QUOTE=ben73;10992212]I thought that when I purchased both bearing and pin tools from judy 12 months ago. after many engine rebuilds it has saved me so many hours of time and frustration.... totally worth it.
Pin tool makes a annoying job easy.
its money well spent man, and the great thing is these tools will last you for decades[/QUOTE=ben73;10992212]
So when you guys break a pin, the bearings also need to be replaced in the hub, or are we talking about two different things? What are the two tools needed? Having tools that save time are always awesome, lol
thanks
Old 07-23-2012, 01:15 PM
  #10931
TSherm's Avatar
How much are you selling them for and how much are they used? Thanks
TSherm is offline
Old 07-23-2012, 05:25 PM
  #10932
slow coach's Avatar
Originally Posted by Afun
Coach,
it does when i said go through tank other way i meant through the holes drilled in tank for pressure line to go through, the fuel line and pressure line run parallel by the side of the tank past the exhaust
slow coach is offline
Old 07-23-2012, 06:10 PM
  #10933
oghobavo's Avatar
Never had my fuel line measured at any of the races I attend.
oghobavo is offline
Old 07-23-2012, 06:15 PM
  #10934
400 shipped for the TKI2 it has about two gallons through the car and the motor is 200 with 2060 pipe.
Old 07-23-2012, 09:12 PM
  #10935
CoryD's Avatar
Fuel line is included in the capacity. If you run @ ROAR or RC Pro sanctioned events (and several stand-alone races) you will be tech'd. That being said, the MP9 fuel tank is a tick small; I have pretty close to the same length of fuel line and I have a 1cc buffer.
Later,
CoryD is offline
