Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 07-19-2012, 06:47 PM
  #10906
ben73's Avatar
Trader Rating: 40 (100%+)
Originally Posted by 305M3
I watched a youtube on the Hudy and was suprised a hammer was needed to get pins out. Mugen and RCRenew have very simple systems and can operate w/o a hammer. Plus, they are 1/2 of the price. Pretty good products...
the hammer + judy tool is not great. I never liked that.
get the mugen one where you don't need a hammer. sounds better
ben73 is offline
Old 07-19-2012, 08:04 PM
  #10907
Originally Posted by CoryD
Just the weeping tile! <ducking>
HAHAHA! JK Kane -- good job @ RC Pro; Red Army all the way!
later,
I do at times get a little affectionate with the weeping tile!
Not this Saturday though, I will be gunning for the back of your car!
Kane-o is offline
Old 07-19-2012, 08:51 PM
  #10908
305M3's Avatar
Trader Rating: 43 (100%+)
They're a goofy size; what I have been suggesting is getting some RTR dogbones:
http://rcdepot.us/SitePages/Product....oductID=128263
push the pins out of the RTR dogbones and put them into your existing universals. It would be nice if someone made a replacement pin but it is an odd size. I think it's 2.7 X 13.5 or something. DO NO put a 3mm pin through -- you will weaken your univeral and it won't fit into the cup properly either.
Regards,
I measured the pins today (had them out to loc-tite some stuff). The sizes I got w/ my calipers were:
2.91-2.96 X 13.91-13.95
Can someone else measure these? That blows that a 3mm pin doesn't work because those are on sale everywhere.
305M3 is offline
Old 07-20-2012, 03:51 AM
  #10909
Kyosho pins are 2.9mm instead of the common 3mm.One solution is 2.9mm drill blanks and then cut the required length.
30Tooth is offline
Old 07-20-2012, 05:32 AM
  #10910
Mindux00's Avatar
Default 2090 pipe - mounting the tube
hi there,
could someone post some pictures of the way of fuel tube with pipe 2090? i have this pipe and the place where tube conects with pipe is in a different possition, that i was used to. would like to see how you put your fuel tubes on MP9.
thank You in advance
Mindux00 is offline
Old 07-21-2012, 05:13 AM
  #10911
Mindux00's Avatar
Originally Posted by Mindux00
hi there,
any help? please.
Mindux00 is offline
Old 07-21-2012, 05:40 AM
  #10912
slow coach's Avatar
any help? please.
you could try this option but run through the tank the other way to come out in front of the pressure nipple
Attached Thumbnails Inferno MP9 thread-east-hertfordshire-20120305-00234.jpg
slow coach is offline
Old 07-21-2012, 08:22 AM
  #10913
Imcaracer20's Avatar
So I drove my tki3 last for the first time and demolished an out drive. Is this normal for these cars?
Imcaracer20 is offline
Old 07-21-2012, 08:25 AM
  #10914
SteveP's Avatar
No. Some of the outdrives produced for the first batch of kits were over-hardened and as a result, more easily damaged. Contact customer service at Kyosho America and they can hook you up with a new set at no charge. 949-454-8854.
SteveP is offline
Old 07-21-2012, 09:20 AM
  #10915
sweet!!! thanks man for the info
Old 07-21-2012, 05:13 PM
  #10916
nicardyMP9's Avatar
Hey guys, just wondering what peoples opinions are regarding the vented TKI1 brake disc vs the new TKI3 version? which is better? and what parts if any would you swap over from the TKI1 to the TKI3? Cheers
nicardyMP9 is offline
Old 07-21-2012, 06:36 PM
  #10917
Jammin57's Avatar
Trader Rating: 120 (100%+)
The solid black disks on the tki3 look cheap but they seem to work fine but I have a extra set of the vented disks I will probably put on it, if you have the bad outdrives I would replace the rears Itleast
Jammin57 is offline
Old 07-22-2012, 08:10 AM
  #10918
nacho_gas's Avatar
hello
I want to know if there are any overdrive system for Kyosho MP9.
A greeting
nacho_gas is offline
Old 07-22-2012, 09:04 AM
  #10919
houston's Avatar
Trader Rating: 96 (100%+)
Originally Posted by nacho_gas
hello
A greeting
Not necessary on a kyosho
Have i mentioned that the mp9 ROCKS!?!
houston is offline
Old 07-22-2012, 12:20 PM
  #10920
nacho_gas's Avatar
I'm very sorry, my English is really bad. I did not understand this sentence: Have i mentioned that the mp9 ROCKS!?!
What do you mean?
