Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-24-2012, 05:41 PM
  #10636
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Default ROAR setups
Would love to get my hands on the ROAR setups for Cody and/or Jared.
hookem34 is offline
Old 06-24-2012, 05:59 PM
  #10637
Afun's Avatar
Trader Rating: 19 (95%+)
My first race day with the TKI 3 is behind me. My experience with this buggy was a thrill. A few new buggy issues like screws coming out and meshing. Other than that the build held up great. The Agama Front and Rear Outdrives with the Kyosho center outdrive combo worked out just fine. I don't know if my buggy came with the bad outdrives, but I did not want to risk it. The buggy just drives awesome and very nimble in all turns. Great acceleration with the OS SPEED and 2090 pipe. I really love the way this buggy drives. I came from driving an Agama. Agama has done a great job with the A8. I just think that it requires more effort to drive. The Kyosho was just so simple to take through all the obstacles. The only thing is the violent nose dive at slower speeds off some jumps. I have also noticed that the buggy does wear some. I can't wait to go back out there.
Afun is offline
Old 06-24-2012, 06:13 PM
  #10638
nacho_gas's Avatar
Has anyone tried the pistons FIO-OT-UR916?
http://www.amainhobbies.com/product_...k-Piston-Set-4
nacho_gas is offline
Old 06-24-2012, 08:44 PM
  #10639
Jammin57's Avatar
Trader Rating: 120 (100%+)
Afun what do you mean by wear some?
Jammin57 is offline
Old 06-24-2012, 08:49 PM
  #10640
jwcobra03's Avatar
Trader Rating: 69 (100%+)
I've had the chance to borrow a friends TKI2 for the past few races and i'm really impressed with car. It's responsive,smooth, and planted without sacrificing steering. He runs the latest version of the BCE chassis on it also. After 4 years with Losi, i plan on making the switch
jwcobra03 is offline
Old 06-24-2012, 09:12 PM
  #10641
oghobavo's Avatar
I run them in my buggy, I run 30f 25r with dark green springs all around. They are the softest springs kyosho offers, well yellow rears are a step softer. I like them so far, they don't fully stop the bottoming out but they do help that more than the 1.3x8's. My spring choice also aids bottoming out, I like to run softer spring setup than most. Even when I run the 1.3x8's I use orange springs all around 45f-30/32.5r. Only time I really liked the feel of the light blues all around was on a hard packed blue groove track.
Next time at the track I am going to try orange springs all around with the fioronis with the same oils 30f/25r...
oghobavo is offline
Old 06-25-2012, 09:48 AM
  #10642
Afun's Avatar
I spent the entire past year driving an Agama A8 2011 Edition. This buggy was bullet proof. It never broke any plastics and I by no means am the greatest of drivers. The shafts and outdrives lasted an entire year. I also had a good amount of races on it. The TKI 3 has some discoloration of the gunmetal on some of the wheel hexes. The gunmetal (aluminum) is rubbing off the shock body. The bottom of the chassis looks like its been raced plenty more than once. I guess its just the anodizing that is rubbing off. I took a look at the pins on the uni-shafts and they look a little indented. The plastic radio box has lost its shine, glossy look to it on the sides. This is just my observation.
I still think this is the best buggy I have driven. I have only had 2 to other inlcuding a MBX5R and the A8. The drivetrain on the TKI 3 is the smoothest I have ever felt. We have aluminum everywhere where it's important. The diff gears still look great. Everything is very functional just some wear. Tell me what you think about the car.
Afun is offline
Old 06-25-2012, 09:59 AM
  #10643
i known this stupid question but can someone help me how big of inner diameter in mm of kyosho mp9 Spring? really important for me. Tk
windy is offline
Old 06-25-2012, 10:09 AM
  #10644
Afun's Avatar
19mm, someone please confirm. I heard their would be no math in this hobby,lol.
Afun is offline
Old 06-25-2012, 10:13 AM
  #10645
speedy2's Avatar
19.5 mm
speedy2 is offline
Old 06-25-2012, 10:29 AM
  #10646
much smaller with gs clx spring then, does someone known what spring have inner diameter 22mm. ok thank guys i really appreciate
windy is offline
Old 06-25-2012, 10:36 AM
  #10647
305M3's Avatar
Trader Rating: 43 (100%+)
HAHAHA... Very good...
305M3 is offline
Old 06-25-2012, 12:19 PM
  #10648
Afun's Avatar
Unreal, down to the last mm
Afun is offline
Old 06-25-2012, 12:31 PM
  #10649
CoryD's Avatar
Good luck on getting a Tebo setup; I have heard his posted setups are not even remotely close to what he runs.
Later,
CoryD is offline
Old 06-25-2012, 02:55 PM
  #10650
hookem34's Avatar
Later,
Based on all the pictures of his buggy at the big races, the non-fluid settings seem pretty similar from race to race.
Cody tends to post more set-ups than Jared, so it would be really neat if Paul would post his ROAR setup on here soon
The tracks I run at have very similar dirt and surface conditions.
hookem34 is offline
