Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-15-2012, 03:40 PM
  #10531
Have any of you guys tried the " kyosho" style protek clutch bells ?
evolution03 is offline
Old 06-15-2012, 04:37 PM
  #10532
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Yep, and they work perfectly.
hookem34 is offline
Old 06-15-2012, 04:48 PM
  #10533
Trader Rating: 16 (100%+)
What's the strength/wear/longevity like compared with the Kyosho clutch bells? Also, I've just been checking the Amain website and the Protek 13t and 14t clutch bells which are specified as "Kyosho style" state that they work for everything except the MP9(!!). How is that even possible? It says ok for ST-RR Evo but not MP9, when the Evo uses the MP9 clutch setup, FFS!
Anyone got any ideas what's going on there?
aaron125 is offline
Old 06-15-2012, 08:49 PM
  #10534
hookem34's Avatar
The verbiage on the amain site is incorrect. They work perfectly fine on the MP9. I have been using them for 8 months now. They are just as good as the K version.
hookem34 is offline
Old 06-15-2012, 10:11 PM
  #10535
I thought that was the case because I also checked the Kyosho 13t clutch bell and it lists all the same cars as being compatible but includes the MP9. It's a bit strange how they actually make a point of saying that the clutch bell will work with all or most Kyosho 8th scale nitro vehicles but specifically not the MP9. Really wierd as they normally have such reliable blah blah blah about their products on the Amain site.
Anyhoo, if it really is as good as the Kyosho part but for 1/2 the price, I know I'm gonna give them a try. 2 for the price of 1 never hurts.
aaron125 is offline
Old 06-16-2012, 06:15 PM
  #10536
ben73's Avatar
Trader Rating: 40 (100%+)
protek are good but the ascendancy ones are a little better. the teeth mesh really well like std K ones. and they are cheap too
ben73 is offline
Old 06-17-2012, 09:43 AM
  #10537
Ok i got another question i just bought a st-rr evo and havent received it yet what size clutch does have ? A 32mm or 34mm I know this is a mp9 thread but i getting no responses in the st-rr thread
Old 06-17-2012, 09:46 AM
  #10538
Yeah i just tried a ascendancy clutch bell last night they do work well
Old 06-17-2012, 09:55 AM
  #10539
Jammin57's Avatar
Trader Rating: 120 (100%+)
it's the same size as the mp9 the old Strr flywheels are bigger
Jammin57 is offline
Old 06-17-2012, 06:26 PM
  #10540
So the St-rr evo is 32mm ?
Old 06-17-2012, 06:42 PM
  #10541
hookem34's Avatar
Originally Posted by AZRC4Me
When I do this with the 63s, I find I have to unscrew the shock end some to get there. I know I have a set of both 63s and 66s so when I do a shock rebuild tonight I'll do a test and snap some pics.
Sean were you able to get those pics?
hookem34 is offline
  #10542
hookem34's Avatar
hookem34 is offline
Old 06-17-2012, 07:00 PM
  #10543
thank you ! My st-rr evo should be here tomorrow or tuesday
Old 06-17-2012, 09:37 PM
  #10544
AZRC4Me's Avatar
I forgot to take em, but Aaron's right, the 66s are really too long. Even when I screw the shock ends all the way down, there's too much uptravel. The 63s are definitely the way to go in the rear. I do have to unscrew the front shock ends a little to get the right uptravel though, I just couldn't remember it was the fronts not the rears. But I did run the 66s in the shocks at a race today and they were fine and didn't produce any adverse handling effects. They're fine to use in a pinch if you don't have 63s.
AZRC4Me is offline
Old 06-18-2012, 07:36 AM
  #10545
eper's Avatar
Trader Rating: 14 (100%+)
OK guys just wanted to post some of my race experiences with the tki2. the car is phanominal. I have only raced nitro about 3 times. the first race i tq ed and won the main, the next event was a bit bigger so i raced intermediate and tq ed and finished 2nd in the main, the last race was this past weekend. on friday the car was really good but had the same issues as my earlier outings which i'll post in a moment. on saturday in my first qualifier i was warming up the car and noticed my steering wasnt centering, i had read on here that some guys where glueing the king pin bushing in so i did that before quals because i wanted to tighten up some of the play in the front of the buggy. well lets just say i dont recommend doing that. i was just trying to get my run in and figured with the guys i was up against it wouldnt be a huge problem. so about 2 laps in some guys going the wrong way and hits me head on,shattering the front lower hingepin brace. which brings me to my first complaint parts availability, its always a problem with kyosho cars. the other issue is the area i race most everyone who runs kyosho is a di@&. they dont like to help others out. so i figured i was out for the weekend. that night a freind and i came up with the idea of tracing the pieces of the brace onto a losi 8 chassis and cutting it out with a dremel. so sunday morning i was on a mission and got the car back up and running. it was a proud moment. i got in 1 qualifier and Bqed. Then bumped into the A. ended up 4th overall after triple a mains so it was a descent weekend.. the only handling charecteristic i cant seem to come to grips with the car is that it turns in really well but once i get back on the throttle (rolling on the throttle)and put more steering input into the car it tends to want to loop out, it doesnt happen everytime time which makes me not be able to get off the corners with confidence. i'm running the cody king sidewinder setup with 5/5/5 diff oils. if anyone has had this issue or has a idea to help me out i would really appreciate it, sorry for such a long post but racing this car makes me very excited and i wanted to share that story.
eper is offline
