Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-13-2012, 12:32 PM
  #10501
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Originally Posted by SteveP
I checked with customer service and they told me that the IF413 outdrives for the center diff have never been returned broken to Kyosho America since the release of the MP9. The results from our team drivers indicate that the replacements for the over-hardened ones included in the kits, are working fine. But, if you want an iron-clad solution, I believe the IF413 outdrives are also an option.
Thank you
rallyebmx is offline
Old 06-13-2012, 01:12 PM
  #10502
Default Coach
Originally Posted by Coach Townsend
Whats up Walid.
Coach,
Not much, my kids have been playing sports all year and still playing ......so I have been running the roads, bringing them to tourneys all over the south.....Almost over though, so Im ready to start racing alot again.
Walid
walidelagamy is offline
Old 06-13-2012, 03:05 PM
  #10503
Pete Martinez's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Johnieblaze
Pete, try Cody Kings bumpy loose setup. I think it's posted on the infernosonly website. If you need the orange and yellow springs I have them.
ok cool thanks
Pete Martinez is offline
Old 06-13-2012, 08:59 PM
  #10504
Coach Townsend's Avatar
I hear ya walid.
Coach Townsend is offline
Old 06-14-2012, 01:51 AM
  #10505
adrictan's Avatar
Anyone has any idea wht's the size of the pins for the wheel hubs?
adrictan is offline
Old 06-14-2012, 03:07 AM
  #10506
Trader Rating: 25 (100%+)
2.6 x 17mm
smelly62 is offline
Old 06-14-2012, 07:54 AM
  #10507
Happy Meal's Avatar
Originally Posted by walidelagamy
Kyosho America does carry the Kanai tools...I have them and purchased them from Kyosho America....Go to the website and type YKW in the search bar and all the tools should come up....
Walid
Wow, been looking forever...thank you
Happy Meal is offline
Old 06-14-2012, 09:10 AM
  #10508
305M3's Avatar
Trader Rating: 43 (100%+)
WOW, those prices are outrageous! I am all for paying for quality, but that may be a bit much... But that's just me.
305M3 is offline
Old 06-14-2012, 10:34 AM
  #10509
Trader Rating: 75 (100%+)
Differences between the tki2 vs tki3?
gixxer420 is offline
Old 06-14-2012, 10:47 AM
  #10510
4ptss's Avatar
Front tower is a little stronger, driveshafts are thicker, radio tray/box has been revised, side gaurds changed some & rear shock shaft length changed. And the first TKI3's came with easily breakable outdrives ( I hear that problem has since been fixed ). These are the only changes that I noticed.
4ptss is offline
Old 06-14-2012, 10:58 AM
  #10511
R/C Tech Elite Member
hookem34's Avatar
Really? Are they longer or shorter?
hookem34 is offline
Old 06-14-2012, 11:36 AM
  #10512
4ptss's Avatar
TKI2 rear shaft IF337 (66mm)
TKI3 rear shaft IFW149-02 (63mm)
So they are shorter, I assume it's to limit the possible total droop gain since they switched to the shorter rear drive shafts.
4ptss is offline
Old 06-14-2012, 11:38 AM
  #10513
Trader Rating: 16 (100%+)
Nothing's changed on either front or rear shock or the parts which make them up (ok, crappy new IF346-09 HC bladders I don't count as quite a few have had problems with them and the original -03 bladders solves the problems instantly). Both the front and rear shock shafts are also unchanged:
Front shock shaft: IFW140-02 L=53mm
Rear shock shaft: IFW149-02 L=63mm
And that's how it's always been ever since the initial release of the TKI2 kit and is still unchanged in the TKI3 kit. What misleads some is that there are misprints/typos/wrong part numbers for the rear shaft in some TKI2 Instruction Manuals. Some quote IF337 (L=66mm) but this was never actually used or included in any TKI2 kit. The IF337 shaft is the one from the original TKI with it's long rear shocks.
But rest assured, nothing whatsoever has changed in the shock shafts from the very first TKI2 kit right up until the current TKI3 kit.
Hope that helps clear up any confusion or incorrect information anyone has been told or had provided to them.
aaron125 is offline
Old 06-14-2012, 11:42 AM
  #10514
Please read my post, below yours, posted 2mins after your post, to clear up your confusion or misunderstandings. It's quite an easy mistake to make as so many iterations of the TKI2 instruction manuals had the wrong part number for the rear shock shaft.
aaron125 is offline
Old 06-14-2012, 11:49 AM
  #10515
4ptss's Avatar
Sorry, I was not trying to give out bad information. When you look up the rear shafts for the TKI2 at Amain they come up as the 66mm shafts so I guess they have the wrong part listed also. I just compared my manuals ( TKI2wc & TKI3 ) when I recieved my new kits to see any changes.
4ptss is offline
