Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-12-2012, 02:21 AM
  #10486
drstrangelove's Avatar
Hey bro,
If I use the stock spur gear I will use a 1mm spacer, if its 48t, I will use 2mm spacer. If not the spur gear stick out to much if feel.
Originally Posted by rallyebmx
Has anyone broken center outdrives ?
On my tki3 build the stock spur is sticking out the bottom of the chassis a hair. The manual says to shim for the optional spur It looks like I need to shim with the stock spur too. Did I do something wrong or is this the case?
drstrangelove is offline
Old 06-12-2012, 03:44 AM
  #10487
Trader Rating: 16 (100%+)
Originally Posted by Soapy
Hey Coach, what Shock boots are you running mate?
If they're the same as the shock boots Tebo uses (and they do look similar), they're the old 777 boots, IFW154. I just got a set myself, gonna build a set of shocks with them and see what they're like compared to the accordian style boots.
aaron125 is offline
Old 06-12-2012, 06:10 AM
  #10488
Coach Townsend's Avatar
KYOSHO'S IFW154 Shock Boots
Coach Townsend is offline
Old 06-12-2012, 07:55 AM
  #10489
Happy Meal's Avatar
Originally Posted by simon0721
Here an option part for the TKI3. Alluminium transponder-switch mount.
http://www.rakuseimodel.co.jp/online...p?jisya=167790
Where can i get one? I do not live in japan and cannot read japanese, lol
Happy Meal is offline
Old 06-12-2012, 08:01 AM
  #10490
Trader Rating: 18 (100%+)
Originally Posted by aaron125
Both of you are referring to the newer HC shock bladders, IF346-09 (I've no clue what the HC stands for, don't think it's High Compression, anyone have any idea?). I tried these last year, when they were initially released and had no end of problems. I couldn't even manage to get my shocks to blead properly. I rebuilt them several times and from all 4 shocks, could only get 1 of them to blead properly when using the new -09 bladders.
I changed back to the original bladders, IF346-03 and instantly all the problems I was having disappeared. I've no idea why I couldn't get them to blead right with my shocks but I tried 2 different packets of the -09 bladders and same problems with both packs, so it would seem the problem was definitely caused by the -09 bladders but others have used them successfully. Anyway, I've never had any problems using the original style -03 bladders, so that's what I recommend.
I just switched out the bladders this week to the older style and have to agree with the above. Just was never happy with the way the HC bladders caused the shocks to bleed. Once I went to the dome style, it was much easier to get the feel I wanted in the shock on the bench. Though I have not been on the track yet with the change, I anticipate it being more to my liking.
KSimmonds is offline
Old 06-12-2012, 10:27 AM
  #10491
simon0721's Avatar
Default IFW426
This is a newly released Kyosho option part. It will be avaiable soon. Check amain or infernosonly in the next days.
http://www.kyosho.com/eng/products/rc/newparts.html
simon0721 is offline
Old 06-12-2012, 02:44 PM
  #10492
Pete Martinez's Avatar
Trader Rating: 17 (100%+)
any one can give me a set up for a small track low traction and dusty.thanks
Pete Martinez is offline
Old 06-12-2012, 04:19 PM
  #10493
Trader Rating: 27 (100%+)
Pete, try Cody Kings bumpy loose setup. I think it's posted on the infernosonly website. If you need the orange and yellow springs I have them.
Johnieblaze is offline
Old 06-12-2012, 11:13 PM
  #10494
ben73's Avatar
Trader Rating: 40 (100%+)
nice
I am headed to the hobby shops in tokyo in a few hours.... will check for this!
ben73 is offline
Old 06-13-2012, 03:22 AM
  #10495
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Has anyone broken center outdrives?
rallyebmx is offline
Old 06-13-2012, 04:30 AM
  #10496
305M3's Avatar
Trader Rating: 43 (100%+)
I won't say "no", but I keep pretty good tabs on this thread, and I can say most of the concerns focus on the front/rear outdrives.
However, that's not to say some centers have not broke, they just are not as well voiced...
305M3 is offline
Old 06-13-2012, 06:27 AM
  #10497
Happy Meal's Avatar
nice...thank you......I see the Mini-z tools...too bad they dont carry the Kyo tools for 1/10, 1/8 in the US anymore..unless someone knows where to get them?
Old 06-13-2012, 07:49 AM
  #10498
Default Kanai tools
Kyosho America does carry the Kanai tools...I have them and purchased them from Kyosho America....Go to the website and type YKW in the search bar and all the tools should come up....
Walid
walidelagamy is offline
Old 06-13-2012, 08:14 AM
  #10499
Whats up Walid.
Old 06-13-2012, 08:39 AM
  #10500
SteveP's Avatar
I checked with customer service and they told me that the IF413 outdrives for the center diff have never been returned broken to Kyosho America since the release of the MP9. The results from our team drivers indicate that the replacements for the over-hardened ones included in the kits, are working fine. But, if you want an iron-clad solution, I believe the IF413 outdrives are also an option.
SteveP is offline
