Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-05-2012, 07:54 PM
  #10396
drstrangelove's Avatar
Hey Alexander,
thanks bro, I will start doing all that when my TKI3 parts comes in
Cheers
Originally Posted by foampervert
Hola Doc!
Ifmar/Femca/Efra/and I believe Roar has limitation on max tire width, no limitation on minimum tire width.
It should be legal anywhere.
As for silicon-ing, just buy some rtv silicon gasket or regular bathroom silicon sealent (make sure it's the clear type and not the white type). smear a thin layer over the servo case joints and wire output.
There are some help viddies about sticking liquid silicon or grease in the servo case, but I think it's unnecessary.
You could also use this, I've tried it and it works well... I don't know the mechanics of it but I suspect it's some kind of quick dry rubber compound.
magic waterproofing goop
Oh... if you own multiple engines, you might want to leave your oldest or least powerful engine aside as your "wet weather engine", this way, you won't be wearing out your high dollar race engine (which is wasted on a wet and slippery track anyways... less power gets you around faster when wet and slippery)
-Alexander
drstrangelove is offline
Old 06-05-2012, 08:10 PM
  #10397
Well done!
Originally Posted by Coach Townsend
Its abouot damn time!!!
Old 06-05-2012, 08:37 PM
  #10398
Oh wow, cool. JQ has a iPad app for you to get all the setups and even create your own setup all through the app. Very very cool.
http://itunes.apple.com/us/app/jq-pr...526815474?mt=8
Old 06-05-2012, 09:08 PM
  #10399
AZRC4Me's Avatar
Originally Posted by CALVIN THINMAN
IN CONSTRUCTION
YOUR CAR, I PLAN ON GETTING A REVOLVE CAR STAND, AND A PIT TOWEL. ARE THINGS LIKE HUDY SET-UP SYSTEM A WASTE OF $$$$$$. ALL ADVICE IS APPRECIATED!!!1
Your post reminds me of this:
http://www.imdb.com/video/hulu/vi2350685209/
(take the caps lock off, no need to shout )
The revolve stand is pretty dialed, I have one but only use it at home, it's a little tough to travel with. A Hudy or similar setup station is not really needed, it's a fringe accessory that you can get if you want. I would also invest in a pitboard, and it's a must to get a good quality set of tools, i.e. don't cheap out on the tools. Good tools make the build more enjoyable and will last longer. Enjoy the build!
AZRC4Me is offline
Old 06-05-2012, 09:49 PM
  #10400
pitpop's Avatar
pitpop is offline
Old 06-05-2012, 09:54 PM
  #10401
pitpop's Avatar
Originally Posted by MAPRACING
I will check the alignment of the spur gear to the clutch bell and see if it is in the middle. I will also make sure my mesh is not too loose. If the teeth are hanging out the bottom of the chassis with a 46t spur gear should I use the shims that came with the kit for the 48t spur gear?
I think you can use a thin spacer under the middle diff mount for extra clearance.. Jared does that.
pitpop is offline
Old 06-05-2012, 10:26 PM
  #10402
Trader Rating: 16 (100%+)
Originally Posted by 1evo RRR Driver
ok thanks, next issue........i purchased tki3 rear shocks and mine came with flat bladders, a buddy of mine built a tki3 kit and his had dome bladders, i also purchased strr evo shocks and they also have the domed bladders!!
what was in Ur tki3??
Originally Posted by KSimmonds
Mine were of a flat variety as well.
Both of you are referring to the newer HC shock bladders, IF346-09 (I've no clue what the HC stands for, don't think it's High Compression, anyone have any idea?). I tried these last year, when they were initially released and had no end of problems. I couldn't even manage to get my shocks to blead properly. I rebuilt them several times and from all 4 shocks, could only get 1 of them to blead properly when using the new -09 bladders.
I changed back to the original bladders, IF346-03 and instantly all the problems I was having disappeared. I've no idea why I couldn't get them to blead right with my shocks but I tried 2 different packets of the -09 bladders and same problems with both packs, so it would seem the problem was definitely caused by the -09 bladders but others have used them successfully. Anyway, I've never had any problems using the original style -03 bladders, so that's what I recommend.
aaron125 is offline
Old 06-05-2012, 10:40 PM
  #10403
AZRC4Me's Avatar
I haven't used the flat bladders yet, but I remember aaron having issues w/ shock bleading. I would guess though that you would need to increase the upstroke of the piston to make up for the shallower bladder - unscrew the shock end a little bit, then fill the cap w/ oil before screwing it onto the body. I'll have to try that sometime and see what's up.
AZRC4Me is offline
Old 06-05-2012, 10:45 PM
  #10404
I'm using 2mm spacer for 48t, think the manual stated 1mm but I find the spur gear came out too much below the chassis with 1mm so I go with 2mm.
I think Tebo using 48t, anyone happen to know what size spacer he uses?
Old 06-06-2012, 02:44 AM
  #10405
adrictan's Avatar
Originally Posted by drstrangelove
Oh WOW, thanks for the tips Alexander, really appreciate it! I will try to do all the stuff you recommended. One thing though, do you happen to know if GRP narrow tire approved at Southern and the KL track?
Btw, how do you silicon your servos? Do you have to tear them apart?
U can get CorrosionX to waterproof yr servos if u want. I tried it on a used servo, left it submerged in water for whole day and it still worked fine.
adrictan is offline
Old 06-06-2012, 05:34 AM
  #10406
My TKI3 kit from France finally arrived today!!
aaron125 is offline
Old 06-06-2012, 06:09 AM
  #10407
305M3's Avatar
Trader Rating: 43 (100%+)
Congrats!!!
305M3 is offline
Old 06-06-2012, 08:42 AM
  #10408
Happy Meal's Avatar
Originally Posted by Jammin57
On the tki3 radio tray you mount the transponder under the switch, I had to trim the hole a little bigger on the rx box so the end of the ko propo switch would fit, mine is all done except the shocks because I'm waiting on some different pistons to get here thought I had some extras but I couldn't find them
Thanks!
Happy Meal is offline
Old 06-06-2012, 08:43 AM
  #10409
Happy Meal's Avatar
Hey Everyone,
Holy Crap
Old 06-06-2012, 09:18 AM
  #10410
Here are the shock collars for the mp9 and evo. Will have them with me at the AMS event if some guys want to give them a try.
The picture is of a short shock body but we just grabbed a medium legnth shock collar for picture purposes. The short would get a short and medium would get a medium and long would get a long.
Currently the shocks spring sags and rests against the shock body. This will support the spring thus keeping it straight and protect the body of the shock while allowing the spring compression under load to take place without any interference. Thats the idea anyways....Im pretty sure it will work out well.
Enjoy
Attached Thumbnails Inferno MP9 thread-imag0181.jpg   Inferno MP9 thread-imag0182.jpg
NLR-Power and C is offline
