Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 05-26-2012, 02:45 PM
  #10201
Happy Meal's Avatar
That french site is very interesting...i can get a kit with a novarossi for about the price of the kit in the states....does anyone know about customs charges??
Happy Meal is offline
Old 05-26-2012, 06:00 PM
  #10202
hefe's Avatar
Originally Posted by AZRC4Me
You can try going to 14t on the clutch bell if you want, or you can go to 14/48 which is like going down half a tooth on the clutch bell. No real drawbacks other than less bottom end. Make sure your epa is set right on your radio too, you want the slide to be even w/ the end of the restrictor opening at full throttle, no more. Just take the air cleaner off and get a visual while you set the epa.
Run the outer camber link on the top inner hole on the hub (hole 3 on setup sheet), and on the 5 hole tower, you should be on the 2nd hole up from the bottom on the inside row (hole 9 on setup sheet), or even the next hole up (hole 8). The lowest hole, #10, is really meant for ultra-high bite tracks and I've never really liked the feel of the car w/ the rear roll center in that location. It really unbalances the roll axis, but that's another topic for another day
thanks for the tips, sean
I made all of the camber link changes, checked epa, and went up a tooth on the cb..buggy felt great today. finished 3rd in mixed sportsman/pro buggy ..second time racing nitro, I'm stoked!
can't wait till next weekend
hefe is offline
Old 05-26-2012, 08:47 PM
  #10203
305M3's Avatar
Trader Rating: 43 (100%+)
Dang Sean - killin' it at JBRL Nitro Series Rnd #2. Congrats brother!
305M3 is offline
Old 05-27-2012, 01:23 AM
  #10204
2cool's Avatar
Hi, I broke an outdrive on my 2L old TKI3, do you think it poped the shaft a bit and being bigger shafts, broke the outdrive.
Also my driveshaft end pins are wearing alot for only 2 litres.
2cool is offline
Old 05-27-2012, 04:01 AM
  #10205
I dunno what Kyosho are doing, it's starting to look like they have now over hardened the outdrives. Mine snapped inside the diff casing. It snapped the shaft of the outdrive inside the diff case bushing clean in 2 last race meet. I've never seen that one before on any car..lol
Soapy is offline
Old 05-27-2012, 04:26 AM
  #10206
2cool's Avatar
Hi Kev, its Paul. First race meet and it broke. But until it broke it was flying.
2cool is offline
Old 05-27-2012, 06:32 AM
  #10207
eper's Avatar
Trader Rating: 14 (100%+)
really? i dont know what you guys are doing to break all these drive line parts ive been running a tki edition car pretty hard and competitvely and am still running the stock parts.
eper is offline
Old 05-27-2012, 07:39 AM
  #10208
Trader Rating: 18 (100%+)
I snapped an outdrive last weekend as well. Right outside the rear diff case, not the lightened areas as one might suspect. A friend that is a machinist thought it was probable that the heat treating was faulty as the part seems a little on the brittle side.
This was on a TKI3, first race on the car.
KSimmonds is offline
Old 05-27-2012, 08:30 AM
  #10209
Trader Rating: 25 (100%+)
I was going to get a TKI3 but thought I would wait to see how reliable the car is first. Looks like it was a wise decision. I'll just keep my TKI2 well maintained for now as it will take Kyosho another 6 months to sort this mess out Could be the stronger less flexible axles breaking the outdrives. I wonder if they will do a recall on the batch of outdrives produced with the problem?? Of course not, what was I thinking.
If they made the 92mm axles it might not be such an issue as the dog bone is farther in so less leverage on the the outdrive. Try using 93mm axles to avoid the problem. I was gobsmacked to see Kyosho staying with 91mm axles for the TKI3, surely it cant be that hard to make 92mm axles.
And the angle drilled pistons supplied with the TKI2, they were a flop, no one uses them and they know it so to get rid of them and make more sales of the white 1.3mm pistons they put angle drilled pistons in the kit knowing that us suckers will need to buy the white 1.3's
smelly62 is offline
Old 05-27-2012, 02:31 PM
  #10210
Trader Rating: 16 (100%+)
Dunno if the HD driveshafts are causing the problem coz if they were, one would expect that the same breakages would have been happening right up until now with people who run the captured unis, but I haven't really heard of anyone blaming them on outdrives breaking? Just a thought.
Definitely agree with you on the shock pistons - absolutely crazy that they still spec the ones which nobody uses.
aaron125 is offline
Old 05-27-2012, 08:20 PM
  #10211
Hey Paul. ok ultra hobies in qld have agama outdrives. These fit like a glove.
Get them and no more dramas .
Too soft a year ago and now too hard. bloody annoying.
Soapy is offline
Old 05-27-2012, 08:53 PM
  #10212
Jammin57's Avatar
Trader Rating: 120 (100%+)
Aaron have you heard anything about you're tki3 or checked the tracking number to see where it is?
Jammin57 is offline
Old 05-27-2012, 09:10 PM
  #10213
drstrangelove's Avatar
Hi John,
Thanks for asking, didn't do very well but since it's my maiden race, I'm quite happy with it.
I could have managed to get bump up to the higher main on the final, was going second and drop to fifth and maintaining it till someone t-bone me and the race ended.
Got number 76 out of 90 No where near you experts here.
Originally Posted by John.C
How was your race? Or is that next week? In either case I'm at the "The Big One" race at LCRC (Home of the 2012 Roar Offroad Fuel Nationals) this weekend. Today was practice and I got to run my brand new MP9 TKI3 e for the first time. This buggy is dialed!! I'm drinking the koolaid. Ryan Maifield w/ Jason from JConcepts, Billy Easton, Anthony Mazarra, and other factory drivers were there practicing. No Kyosho factory guys though
drstrangelove is offline
Old 05-27-2012, 09:14 PM
  #10214
101% agree on this! Even if you where to buy the shock sets, it still come with that piston which of no use! To say that it's already been done with TKI2 is acceptable, but still doing the same with TKI3 is way too much!
Old 05-27-2012, 09:47 PM
  #10215
Jammin57's Avatar
Is anybody using the CSI shock pistons?? I've seen people running them in other brands and was wondering if they are worth giving them a shot
Jammin57 is offline
