Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 05-06-2012, 10:42 AM
  #9901
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Originally Posted by freefallmarine
Guy's im wanting to run the KO on/off switch on my car, cause Kyosho said the new radio box accommodate's it. Is it ok to use the switch with my 6.6v life battery? Anyone have a picture of it mounted on the new updated radio box? Thank's.
I used to run a LiFe with my KO switch. Just make sure you turn off the Lipo cutoff function on the switch.
hookem34 is offline
Old 05-06-2012, 10:43 AM
  #9902
Trader Rating: 16 (100%+)
It is designed specifically for use with LiPo packs so definitely no probs using it with a LiFe battery. Here's a pic of it in the updated TKI3 mount.
aaron125 is offline
Old 05-06-2012, 11:49 AM
  #9903
freefallmarine's Avatar
Thank's DC/Aaron for the reply. I guess the transponder just goes in the radio box right?
freefallmarine is offline
Old 05-06-2012, 12:28 PM
  #9904
You can do that or put it in the area behind the rx box, where the normal style switch would be mounted or you can run it underneath the KO switch, on the underside of the transponder mount. The new rx box has an opening for the wires to be passed through from both the top and also the bottom of the mounting plate.
aaron125 is offline
Old 05-06-2012, 06:47 PM
  #9905
Pete Martinez's Avatar
question for anyone and maybe pit pop, the last two week i have blown out two clutch bells is any one having this problem. i sheared off all the teeth on my bell today.
Pete Martinez is offline
Old 05-06-2012, 07:08 PM
  #9906
305M3's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Pete Martinez
question for anyone and maybe pit pot, the last two week i have blown out two clutch bells is any one having this problem. i sheared off all the teeth on my bell today.
From Pitpop's post #4575 or start at this link:
http://www.rctech.net/forum/nitro-of...ml#post8546039
Also, searched "drill chassis". That should give you a place to start.
305M3 is offline
Old 05-07-2012, 12:55 PM
  #9907
Attached Thumbnails Inferno MP9 thread-mp9-radiotray-2.jpg   Inferno MP9 thread-mp9tki-2.jpg
mauro67 is offline
Old 05-07-2012, 03:52 PM
  #9908
305M3's Avatar
Hey Sean, saw the results from the Grassroots series this past weekend - great run. Looks like Kyosho did really well. Gotta find a way to catch that Cody guy.
Are you headed to AMS this year?
305M3 is offline
Old 05-07-2012, 04:30 PM
  #9909
Does anyone have any idea when the tki3 parts will be in the hobby shops ?
BILLYK is offline
Old 05-07-2012, 04:35 PM
  #9910
They already are on sale in retail LHS in some parts of the world (but unfortunately not mine). I know JE Spares in the UK has had them in stock and on sale for about 2-3weeks now.
aaron125 is offline
Old 05-07-2012, 06:14 PM
  #9911
RacerScott's Avatar
Anyone know if the AKA wheel nuts are the right thread type for the mp9 hubs? How are the kyosho nyloc nuts?
RacerScott is offline
Old 05-07-2012, 06:17 PM
  #9912
Yep, just tested them and the AKA's thread on perfectly. The Kyosho nyloc wheel nuts are great too, no problems with them or the AKA wheel nuts.
aaron125 is offline
Old 05-07-2012, 06:23 PM
  #9913
drstrangelove's Avatar
I've never use them but I will be surprise if it does not fit into mp9 wheel hub since we know how close the two of them are.
I prefer to use the Jconcept one, make things more cleaner on the inside. and if you are buying the Kyosho nut, might want to consider Jconcept.
http://www.amainhobbies.com/product_...-4-Fine-Thread
drstrangelove is offline
Old 05-07-2012, 07:34 PM
  #9914
I have a silly question for pit pop,, where do you guys get your shirts done. The ones where kyosho is going down the shirt instead of across ?
bkuff-losi is offline
Old 05-07-2012, 10:24 PM
  #9915
AZRC4Me's Avatar
Thanks man, it was a great 1-2 finish for Kyosho, Pro-Line, Team Orion, Byron's, and Lucky7. Yeah, that Cody guy is stupid fast lol. But it's funny, Cody and I were talking on the drive home and there's a few things I need to tweak in terms of my driving style to get faster - mainly slowing down. It was a 20 min main and I did one stop at 10 min, and at the end of the race when PK was telling me to be smooth and conserve fuel, I ran my fastest laps but they felt the slowest, go figure.
I wish I could head out to AMS, but it's tough to take off that much time from my job (I'm the Lead Test Engineer at StopTech Brakes) and the travel expenses are pretty steep to cover on my own too. I'm trying to do nationals this year but we will see how that plays out...
On a side note, I've let a couple guys I know drive my car this past week, both of them drive something else but are thinking of a Kyosho, and both were able to run faster laps than their own cars on the first tank with the Kyosho...
AZRC4Me is offline
