Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 04-09-2012, 02:13 AM
  #9151
Trader Rating: 16 (100%+)
Originally Posted by elkapitan
If I put thicker diff oil on the rear will it prevent the fishtail
Nope, less throttle/more throttle control will stop fishtailing.
Originally Posted by drstrangelove
Thanks bro, the Cody slippery setup is this?
http://www.infernosonly.com/v/vspfil...ll_Classic.jpg
Yap, I do plan to have more track time and always remember to go slow... That braking point is noted. My friend been telling me that too and I've been trying to get the braking point right. So it will be more practice.
I will be there at MNL2, most probably as a spectator.
Mate, don't worry about changing your setup - it looks fine in the vid, just leave the car the way it is now, only thing I'd say to change would be front ride height higher, same as rear.
But don't go making wholesale changes, such as Cody's whatever setup. Just learn to drive the thing. Like Sean said, if you keep making all these changes every time you go out, you have to learn a new car every time you drive. And that's definitely not beneficial to your progress. Leave the car alone, setup-wise for a good few months, or at least a month or so, apart from the ride height.
Car seems fine, what you need to adjust is the driver.
aaron125 is offline
Old 04-09-2012, 03:22 AM
  #9152
drstrangelove's Avatar
I think so too.
drstrangelove is offline
Old 04-09-2012, 04:11 AM
  #9153
J33
J33's Avatar
Stay at the middle of the lane at first till you get more familiarized with the track then you will get less mistake and dont worry as the fast guys will still over take you. Thats what the pros say when i started out lol
I think so too.
J33 is offline
Old 04-09-2012, 04:37 AM
  #9154
Yap, that's what I was told when I'm on the track
Old 04-09-2012, 07:06 AM
  #9155
Wonderful race by Jared, Elliott and Cody!!
Old 04-09-2012, 07:08 AM
  #9156
Do you have the URL from the vid/site you were watching the race on? Please share here.
aaron125 is offline
Old 04-09-2012, 07:14 AM
  #9157
liverc.com
ratjayfala is offline
Old 04-09-2012, 07:18 AM
  #9158
Originally Posted by ratjayfala
liverc.com
Old 04-09-2012, 08:00 AM
  #9159
Don't suppose either of you would have the actual URL to the Neo final vid? I went to Liverc.com but to view the race for free, they had me on a countdown, starting from 1500!! And it was only going about 1 number per second or so, would take 1/2 hour until I could actually watch the race. Is that normal for Liverc?
aaron125 is offline
Old 04-09-2012, 08:05 AM
  #9160
305M3's Avatar
Trader Rating: 43 (100%+)
Yes, that is very normal. Especially for an A-main event.
Also, using the free service, you only get to view the race from one camera angle and for a limited amount of time (I think it's 10 mins).
305M3 is offline
Old 04-09-2012, 08:09 AM
  #9161
J33
J33's Avatar
http://www.justbuggy.net/?p=1257
http://rcspecial.com/news/?p=98910
J33 is offline
Old 04-09-2012, 08:38 AM
  #9162
Yes mate, you got to pay 30 buck to watch them and if you want full access another 30 bucks.
the final starting in another 30 to 45 mins
Old 04-09-2012, 10:27 AM
  #9163
Yes, Tebo the NEO 12 Champion! Wonderful racing man, wonderful...
Old 04-09-2012, 12:25 PM
  #9164
racerjerm's Avatar
Originally Posted by racerjerm
Need new lipo reciever batteries! Mine sat for two years and are now gone. having a hard time finding one that fits the battery box with a voltage regulator in there too... maybe the Protek or Losi model for Losi Eight on Amain. Anybody have better ones?? Was running some Protek 750 and 1000 that fit great but apparently they dont make those sizes anymore.
Anybody?
racerjerm is offline
Old 04-09-2012, 03:04 PM
  #9165
Anybody?
how hard is it to measure the rx box, go to amain or any other store and find a rx battery that fits? can someone wipe my ass?
RAlmeida is offline
