Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 04-01-2012, 04:51 PM
  #9001
Edit
RAlmeida is offline
Old 04-01-2012, 05:34 PM
  #9002
psr
psr's Avatar
Originally Posted by Nitronut3
Whats everyones diff setups?
ive tried 5-5-3 and 7-4-4
The 553 was good but the car felt like it wasnt pulling itself out of the corners, but 744 did but make the car snap hard out of the corners, sometimes almost spinning the car out.
try 7-7-4
psr is offline
Old 04-01-2012, 05:36 PM
  #9003
Originally Posted by joecool
Here is my MP9 for 2012
Now that's a nice paint scheme. Really like it!!
How'd you get those line so straight?
ratjayfala is offline
Old 04-01-2012, 05:40 PM
  #9004
I use front LSD, center 7000, rear 2000
RAlmeida is offline
Old 04-01-2012, 06:21 PM
  #9005
psr
psr's Avatar
hi guys just finishing off a new tk2 kit i have heaps of fastners left over is this normal like i followed the kit instructions and used what i was surpose to ?
psr is offline
Old 04-01-2012, 06:24 PM
  #9006
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Originally Posted by psr
try 7-7-4
Only problem with this oil setup is that you dramatically decrease your off power steering.
hookem34 is offline
Old 04-01-2012, 06:48 PM
  #9007
Nitronut3's Avatar
How bout 5-5-5?
that might be what im looking for
Nitronut3 is offline
Old 04-01-2012, 07:11 PM
  #9008
psr
psr's Avatar
who runs battery forward compared to battery rear ? and why does it work or not work for you
psr is offline
Old 04-01-2012, 07:13 PM
  #9009
psr
psr's Avatar
only suited to non tech tracks like more flowing arangments but 7-5-5 doesnt seem to suit anything
psr is offline
Old 04-01-2012, 07:14 PM
  #9010
Coach Townsend's Avatar
Nate i have that diff ready and 5.4.4, 5.5.4. Im starting with 6.4.4
Coach Townsend is offline
Old 04-01-2012, 08:04 PM
  #9011
PAGIE #536's Avatar
Post
7 5 3 seems dialed with good corner speed
PAGIE #536 is offline
Old 04-01-2012, 08:48 PM
  #9012
drstrangelove's Avatar
Hey Guys,
Managed to go down to Southern Alley track (Johor, Malaysia) yesterday (my first try on proper track) and I seems to have problem with cornering, when I turn and full throttle the back seems to skid left and right.
i believe it might be the BUKU clutch that I'm using, might not set them properly thus causing that. Maybe i'm being too ambitious to go with BUKU, should dial my driving first before considering BUKU. (Disclaimer, nothing to do with BUKU, just me not doing it correctly)
Next run I will try to use the stock clutch to see if it solve the problem and try to improve my driving (like what someone told me, learn how to walk before you start running ). But overall it's a tough buggy! had a few bad (some real bad) jump and even managed to go out of the track and into the drainage but it is still going strong!
On a separate note, do you guys maintain 2 buggies? One for practice and one racing or you guys just maintain 1? Using them for both practicing and racing. I was advise to maintain one as I was told no 2 buggies are similar even how similar the setup is. You tend to suffer if you are used to the practice buggy and on race day, you are using the racing buggy which you often don't drive. Your opinion on this?
drstrangelove is offline
Old 04-01-2012, 10:20 PM
  #9013
PAGIE #536's Avatar
Post
i see time and time again people put option or hop up parts on their cars before getting to grips with the car at stock and wonder why the car is a pig to handle try find a base setup and start from there before adding parts etc, so you know whats going on with the car.
Old 04-01-2012, 10:41 PM
  #9014
likeaboss's Avatar
Default weights
I apologize if this has been gone over before, I've tried to search this thread but it's h u g e! What are average weights for the MP9 with/without upgrades? Are there limits to how light it can be and still pass tech? I guess it varies between racing sanctions. Just trying to get more info on weight and corner-balance. Thanks!
likeaboss is offline
Old 04-01-2012, 10:52 PM
  #9015
marmittone's Avatar
Originally Posted by aaron125
I too thought I had a similar problem a while back when I first started driving my MP9 but for me it was happening at all times, not just while braking. By that, I mean even when just slowing by engine braking/backing off the throttle, the back-end would always want to come around and the car would oversteer even with just a little bit of steering input.
Not sure how you came to the conclusion it might be too much front brakes for you, as normally too much front brake would cause the car to plow straight on, understeering heaps. Too much rear brake would cause a car to oversteer.
Anyway, for me, it turned out to be because of the ride height. I started out with Cody's general baseline setup and the way he sets up his ride, with 1-2mm lower front ride height than rear, just made my car have WAY too much off throttle steering. I setup the car so that front and rear ride heights are the same and problem solved.
A quick and easy way for you to figure out if the problem is being caused by too much front or rear brakes would be to simply unscrew the rear brake rod by quite a bit, so that the car has only front brakes. Then see if the problem is still there. Do the opposite, so fronts are effectively disabled and you only have rear brakes and you'll know exactly what's causing the oversteer issue, whether it's too much front or rear brakes.
If the oversteer still happens even when not using the brakes, perhaps like me, it could be a setup thing. Give that a try and see if it helps. At the very least, you'll know for future reference, what too much front or rear brakes feels like.
Hi guys,
where do you measure the front ride height? I usually measure it where the downstop screws touch the chassis. Is it correct?
marmittone is offline
