Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 03-30-2012, 10:43 AM
  #8971
pitpop's Avatar
Originally Posted by aaron125
Dunno where you've seen this but every setup sheet of Cody's always says he has the rear tread width setting on "S" for small. Also, just about every pic I've ever seen of his car where this is visible, never been anything other than the short/small setting.
Oh ye, if you are building 2 cars and have them using different axles and different rear tread width settings, the cars will handle differently and might throw you off if you got one of them setup all sweet, go to the other and start to wonder why stuff is different when you thought everything was identical between the 2 cars. Just FYI.
we have used the middle setting but never the wide setting with the 2mm off-set hubs.. If we put 93mm dogbones in the rear, I use the middle setting, but I don't think it would pass an iFMAR inspection. ROAR I think middle is ok, but not iFMAR.
pitpop is offline
Old 03-30-2012, 01:50 PM
  #8972
camocowboy's Avatar
Trader Rating: 24 (100%+)
Originally Posted by jzemaxx
I heard they are going to be running AE shocks on their cars.....heard AE shocks are the best
I think I just peed a little
camocowboy is offline
Old 03-30-2012, 02:22 PM
  #8973
oghobavo's Avatar
:Are any guys running zero rebound/dead shock setup? If so, how does it feel on the track?
oghobavo is offline
Old 03-30-2012, 02:37 PM
  #8974
c2k
In my opinion the rebound depends on the track condition :
Bumpy Track --- Fast Rebound.
Smooth Track --- No Rebound.
So i change the rebound accordingly and i feel the MP9 always silky smooth.
c2k is offline
Old 03-30-2012, 02:39 PM
  #8975
Trader Rating: 16 (100%+)
How do you change the speed of the rebound - different pistons?
aaron125 is offline
Old 03-30-2012, 02:49 PM
  #8976
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
I think he meant full rebound?
Only way to get "faster" rebound is using a heavier spring and light oil and on a bumpy track, this would prove to be a poor choice
hookem34 is offline
Old 03-30-2012, 03:48 PM
  #8977
c2k
Sorry I meant Full Rebound. I think in my native language and i have to translate it .
c2k is offline
Old 03-30-2012, 04:11 PM
  #8978
Oh my bad, thanks for explaining. With all the talk of Fioroni double-action pistons and stuff, I wasn't sure if you did mean to change the speed/piston or the rebound setting when bleeding the shocks.
Thanks mate.
aaron125 is offline
Old 03-30-2012, 04:29 PM
  #8979
eper's Avatar
Trader Rating: 14 (100%+)
can someone post the part # for the 93mm shafts you guys are running
eper is offline
Old 03-30-2012, 04:43 PM
  #8980
I'm not using them atm but the part # is: IFW404b
aaron125 is offline
Old 03-30-2012, 06:03 PM
  #8981
eper's Avatar
thank you. are you running the 2mm offset rear hubs?
eper is offline
Old 03-30-2012, 06:09 PM
  #8982
Funny that you should ask that as I was just about to post the following.
Scott and Mr Smelly: Do you guys (and everyone else, of course) reckon there is anything strange going on with my car and the amount of space from the end of the dogbone to the bottom of the outdrive? From what you've been saying, about having problems if running the 93mm axles and the narrow tread setting, I shouldn't have as much room as is visible in the pic. There is easily more than 2mm there at all points in the range of suspension travel, hence I could very easily run the 93mm axles in the narrow setting and still have some wiggle room, so that the axle won't bottom out.
Does anyone else have so much room with the same setup as what I'm using? How much room should there be with the 91mm axles/2mm offset/narrow tread settings?
Thanks guys.
Attached Thumbnails Inferno MP9 thread-my-tki2-91mm-rear-unis_heaps-room-outdrives.jpg
aaron125 is offline
Old 03-30-2012, 07:34 PM
  #8983
hookem34's Avatar
Thanks guys.
I run the same rear setup and mine look identical to yours. 6 gallons on my chassis with ZERO issues.
hookem34 is offline
Old 03-30-2012, 09:20 PM
  #8984
drstrangelove's Avatar
Hmm, interesting, I shimmed mine on the outside and I can see there is not much different in space between yours and mine. I'm running them today with the 91mm shimmed outside and will update you.
With the conditions of local track (Johor track out today due to heavy rain!) if it were to pop out or have any issue, this will be the best track to try... i think
My other buggy I'm running with 93mm, shimmed outside with narrow setting and I see enough play between the outdrive and dogbone but I can't test that one yet and there is NO way I'm running that on the local track
I'm heading down now and will be able to share with you within the next 4 to 5 hours if there is any value coming from noob like me.
PS: Sean, will snap some photos of my buggy with dirt later.
Thanks guys.
drstrangelove is offline
Old 03-30-2012, 09:39 PM
  #8985
I'm using the 2mm offset with the 93mm, shimmed on the outside with narrow setting but I've not tested them yet. From what I see, it looks ok.
