Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 03-21-2012, 07:47 AM
  #8836
Trader Rating: 16 (100%+)
KICK-UP
Kick-up is the angle between the ground and the lower inner hinge pins on which the suspension arms swing. Altering kick-up will affect the car much like caster does. In addition, adding kick-up will make your bump higher and further. You should only consider decreasing kick-up when the track has few or no jumps.
Just thought I'd add the following as the above is perhaps not the greatest explanation of what kick-up does.
Kick-up refers to the hinge-pin angle relative to horizontal plane of the chassis. If the hinge-pins are parralel then this is zero kick-up. Raising the front or lowering the rear of the hinge-pins gives positive kick-up. In a similar way to how anti-squat affects how much the rear of the car squats under acceleration, kick-up affects how much the car dips under breaking and cornering.
By making kick-up more positive/front higher, this reduces the amount the front will dip and therefore less weight transfer. This also increases caster and camber during cornering.
aaron125 is offline
Old 03-21-2012, 07:52 AM
  #8837
PAGIE #536's Avatar
Post
adjusting your skid angle smooths out the steering but has a negative effect on jumping big jump sections will be hard to clear.
PAGIE #536 is offline
Old 03-21-2012, 07:58 AM
  #8838
Trader Rating: 21 (100%+)
Originally Posted by AZRC4Me
what tires/compound are you running and what's the track surface like? tires are the most important aspect of your setup, and you need to get the compound right to take advantage of the pin design. always start with tires first...this time of year with the weather the way it is, you should be running an M3 or M4 compound depending on the track surface/weather conditions.
m3 holeshots is what i was running track is good but a little slick at times and can get a little dust on it
toyota 2jz is offline
Old 03-21-2012, 05:32 PM
  #8839
Retired09's Avatar
Default How abiut MP9 Fuel Tank Spring?
Originally Posted by talho
Tank lid o-ring is ORG18/pack of three.
Tommi
Tommi.
Thanks a million. Would have never found that part number!!!!!!!!!
Any idea what part number the spring is?
Retired09 is offline
Old 03-21-2012, 05:39 PM
  #8840
GSM Storm's Avatar
Trader Rating: 114 (100%+)
Default Front / rear diff gasket
Hi all
Does anyone know if there is a part number for just the front / rear diff gasket, the only thing I can find the gasket comes with a case, I found the center diff gasket pack of 5, but it is a different size.
Regards
Gary
GSM Storm is offline
Old 03-21-2012, 05:54 PM
  #8841
Originally Posted by GSM Storm
Hi all
Regards
Gary
this is what you need m8.
http://www.amainhobbies.com/product_...-Case-Gasket-5
no: KYOIF30-1
adir
adir is offline
Old 03-21-2012, 08:18 PM
  #8842
pitpop's Avatar
Originally Posted by aaron125
KICK-UP
I just wanted to clarify a couple things... the caster angle includes the kickup, so in terms of the MP9, you have 21 degrees caster when you run the c-hub bushing in the zero position (middle) 22 with plus one, and 20 with minus one.. also, more kick-up makes the car dive MORE on braking, not less. If you want less dive, you can reduce kick-up and increase caster angle to get the steering response you want.. my .02
pitpop is offline
Old 03-21-2012, 08:51 PM
  #8843
shinnbad12's Avatar
I have heard this refered to as is antidive (aka kickup) but seems to be the opposite as the rear,,,,,, I guess its because its on the opposite end ????
Scott
shinnbad12 is offline
Old 03-21-2012, 09:08 PM
  #8844
AZRC4Me's Avatar
Scott
It has to do with the geometry of both the upper and lower arms in the front, and where their centerlines intersect each other in relation to the wheel center and the ground plane. This point of intersection is referred to as the side view swing arm and affects the spring rate of the front suspension. The technical term is referred to as anti-dive, as full size cars don't have "kickup". The rc term is kickup, but more kickup doesn't mean more anti-dive. All you really need to know is what PK said, and to test it, go back to his roll center example of putting the car on the street and testing the most kickup, then the least kickup, and see how the car handles under a hard brake.
AZRC4Me is offline
Old 03-21-2012, 09:19 PM
  #8845
AZRC4Me's Avatar
Originally Posted by drstrangelove
Are you using them mate? or you using the tki2 chassis?
I'm running the TKI2 chassis. I've run the TKI before but the 2 is better through the bumps and gives me a more confident feel. I brought a TKI chassis w/ me to DNC as I planned on the track being high bite and smooth and that's when I'd run the TKI chassis, but the TKI2 chassis felt so good and my MP9 was awesome, I never even thought about changing the chassis. In fact, I don't think I made any changes to my buggy all week, except different tires once.
AZRC4Me is offline
Old 03-21-2012, 09:20 PM
  #8846
Default It was past my bedtime.
Of course more kick-up means more diving under brakes, etc., I meant what you said but it came out the opposite of what I was trying to say... it was just before 2a.m. when I made that post so, that's my excuse and I'm sticking to it.
Thanks for that Mr King.
aaron125 is offline
Old 03-21-2012, 11:43 PM
  #8847
Scott
Actually, front kick-up as we use it in off-road RC is pro-dive, not anti-dive, as Mr King alluded to. If the hinge-pins are front down/rear up, that would be anti-dive. Though never seen on an off-road car, pro-dive is actually used sometimes on touring cars in high grip situations.
aaron125 is offline
Old 03-22-2012, 03:04 AM
  #8848
foampervert's Avatar
Default moving right along....
Hiya Aaron,
Thanks for the clarification. Seriously, Mr. King is not wrong, see:
+ve kickup = -ve prodive
-ve kickup = +ve prodive
0 degree kickup = 0 degree prodive
Same difference.
Just so noobs don't get confused, let's call it kickup in the front and squat in the rear.
+ve antisquat = -ve prosquat
-ve antisquat = +ve prosquat
0 degree antisquat = 0 degree prosquat
pro squat is the same as kickup, but for the rear suspension.
so a car with +ve kickup and +ve prosquat will have your suspension pins look like this from the side view: \ /
+ve kickup and +ve anti squat: \ \
-ve kickup and +prosquat: / /
and so on...
terms are usable interchangeably, as long as you add a +ve or -ve.
confused?
-Alexander
foampervert is offline
Old 03-22-2012, 03:08 AM
  #8849
Originally Posted by foampervert
Hiya Aaron,
Ye, I know, that's why I thanked him for pointing out where I was wrong and typed in the opposite of what I was actually trying to say.
aaron125 is offline
Old 03-22-2012, 03:28 AM
  #8850
c2k
Guys ,
Thanks for the in depth explanation but i am afraid i did not explained myself . In the front tower you can change the upper bushing from H to L or 9. This changes the front upper arm height and angle. and i donīt understand what it does this affect the car handling. I believe that in the L position will affect the front Roll Center and i should gain more front traction . Am i right ???
Attached the eluding setting .
Thanks and Cheers, .
c2k is offline
