Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-06-2012, 08:10 AM
  #8251
Coach Townsend's Avatar
Default Bumper
Now going to back it with rubber sealant to keep it from flexing too too much
Coach Townsend is offline
Old 02-06-2012, 08:45 AM
  #8252
Smile DE support tuned
Hi all!
I tuned the DE and Kyosho bumpers in this way:
a) Standard DE rear plate + the front one being cut, plus:
b) the Kyosho original one cut to prevent the DE support to bend too much since it's too soft.
It works quite well and it lasts much more.
Regards,
Attached Thumbnails Inferno MP9 thread-de-support-tuned-up.jpg   Inferno MP9 thread-de-support-tuned-down.jpg
kurobox is offline
Old 02-06-2012, 09:54 AM
  #8253
Trader Rating: 30 (100%+)
Originally Posted by drstrangelove
Btw, are you recommending not to get the 91mm Front CVD Set or the 84mm Front/Center CVD or both. Just to confirm, I figure it would be the 91mm Front CVD set. thanks
The 91 mm dont get those just run the universals i would only get the center cvds 84 and 110 and run the standard universals on the front rear
And yes the kit comes with alum. Rear toe in plate
Just need the upper rear front holder that comes plastic in kit
jewn_beef is offline
Old 02-06-2012, 01:23 PM
  #8254
mlbright's Avatar
In what cases are you guys running the 48t center gear??
mlbright is offline
Old 02-06-2012, 03:34 PM
  #8255
shinnbad12's Avatar
Default Skid plates
I feel that aftermarket bumpers and skid plates are a waste of money and time. This buggy reacts to ride height so well, what do you think the 2+mm thick does to the performance??????? Just run the thing and race your A$$ off, when its time for a chassis,,,,,,,, well get a new one. 100 bucks for a chassis 2 times a year is not worth worring about chassis wear. Think about the money spent on tires throughout the year??????? You wouldnt use a lesser of a tire just to save a couple hundred bucks in the course of a year.
Just food for thought.
Scott
shinnbad12 is offline
Old 02-06-2012, 03:42 PM
  #8256
mblgjr's Avatar
Trader Rating: 86 (100%+)
Short tracks that really have no straightaway.
For general purposes, lets say anywhere that has a lap time of 20secs. or less. Or a straightaway that is 65' or less.
mblgjr is offline
Old 02-06-2012, 04:03 PM
  #8257
Unhappy Body cracking
Does anyone have a secrete to stop the bodies from cracking? I tried the stock body and bitty designs both crack in the same spot were the rear section rounds up to the tail.
rob-d is offline
Old 02-06-2012, 04:14 PM
  #8258
shinnbad12's Avatar
When you cut out the body, leave more material where it curves up towards the tail. Dont follow the cutout lines ! It makes it to thin right where it cracks.
Scott
Old 02-06-2012, 05:43 PM
  #8259
drstrangelove's Avatar
Ok, noted on that Jewn_Beef. thanks for the advise. Much appreciated.
drstrangelove is offline
Old 02-06-2012, 05:44 PM
  #8260
Old 02-06-2012, 08:12 PM
  #8261
houston's Avatar
Trader Rating: 96 (100%+)
Orrrrrr 14/48 for large tracks
Its like gearing up half a tooth on the clutch bell
houston is offline
Old 02-07-2012, 09:19 AM
  #8262
mblgjr's Avatar
I left plenty of material on the stock body, it lasted no time.
Running the JC Punisher for RC8 on mine now; works perfect and handles properly now
Kyo also has a reinforcing material thats like an epoxy jelly pad. Works good too.
mblgjr is offline
Old 02-07-2012, 11:47 AM
  #8263
Save all that stuff. just get some rubber gasket sealant and forget about it
Old 02-07-2012, 07:07 PM
  #8264
Does anyone know where I could find a good company to get some parts hard anodized? I tried contacting zig racing a few times with no responses back.
rob-d is offline
Old 02-07-2012, 07:31 PM
  #8265
Where are you located? In Northern Virginia, Alexandria plating is very good
Don Elliott is offline
