Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 10-12-2011, 08:21 AM
  #7246
KWT-NITRO's Avatar
hey guys,
just a small question. i still run my TKI1 since day one and never had a problem with the stock dogbones!!!
why is everyone going to CVDs??
KWT-NITRO is offline
Old 10-12-2011, 08:53 AM
  #7247
jzemaxx's Avatar
You guys that are replacing the universals......still using the KYOIF456's??
I have been running mine now for several long practices and several races now and see just a small sign of wear. Not sure why folks are having problems. My TKi2 has been bulletproof.
jzemaxx is offline
Old 10-12-2011, 09:04 AM
  #7248
Trader Rating: 16 (100%+)
Originally Posted by KWT-NITRO View Post
hey guys,
That would have to depend on your definition of 'everyone' as I'm sure that a large majority would be using the standard universals, IF456. As for this minority author, I have been running IF419 up front since they were released and IF456 in the rear.
aaron125 is offline
Old 10-12-2011, 09:09 AM
  #7249
ON A MISSION's Avatar
Trader Rating: 33 (100%+)
I just recently switched to the TKI2 alum rear hubs. I have broke one used 91mm universal since putting them on. I have installed a new set of 91 universals to test if i run into more problems. I personally have not seen the outdrives wear at the rate people are talking about. I will get back on and post after i run.
ON A MISSION is offline
Old 10-12-2011, 09:11 AM
  #7250
houston's Avatar
Trader Rating: 96 (100%+)
Thumbs up
The driveaxles are fine , it was a problem with the outdrives
All is good in yoshi land now
houston is offline
  #7251
hookem34's Avatar
Trader Rating: 17 (100%+)
When running the +2mm rear aluminum hubs, you can't change the tread width with bushings can you?
I bought my tki2 with wc upgrades second hand and noticed the 91mm in the rear and 93mm shafts in the front. Just want to know if I can quickly change rear tread witdth.
Thanks!
hookem34 is offline
Old 10-12-2011, 09:14 AM
  #7252
You still adjust it using the inserts at the end of the lower suspension arms, doesn't matter which driveshaft length is in being used.
aaron125 is offline
Old 10-12-2011, 09:17 AM
  #7253
So my outdrives are too stong and are breaking my universals ?
J.KiSSINGER is offline
Old 10-12-2011, 09:56 AM
  #7254
hookem34's Avatar
Ok. So what is the front/rear tread section on the set up sheets referring to? You can mark s/m/l and I assumed this was achieved with the lower bushing in the rear hubs.
hookem34 is offline
Old 10-12-2011, 10:02 AM
  #7255
There's nothing that can be changed or altered with the rear hub inserts, they are there for a snug fit on the hinge-pin as it woud otherwise be inserted directly into the metal of the hub.
The S/M/L you refer to is for changing the rear track width (with the insert in the end of the suspension arm). Some (very few) have been known to try and use this for an outboard toe adjustment but it is not intended to be used in that way.
Front tread width is adjusted with the inserts at the back of the gearbox in the front lower rear hinge-pin holder. It only has 2 positions, S/L.
aaron125 is offline
Old 10-12-2011, 10:30 AM
  #7256
houston's Avatar
The notches in the outdrives are breaking them silly , or they are bottoming out in the od cup during uptravel
houston is offline
Old 10-12-2011, 11:07 AM
  #7257
hookem34's Avatar
Got it! Thanks for the explination Aaron.
So can you run the L position in the rear with the 91mm shafts without issues, or will they pop out on uptravel?
hookem34 is offline
Old 10-12-2011, 11:13 AM
  #7258
Good question, depends on your setup. Is that with the +2mm hubs or the standard version (same as plastic)? Without the 2mm offset, with 91mm driveshafts, answer is yes. Any other setup, not sure. Why do you want to run in the L position?
aaron125 is offline
Old 10-12-2011, 12:24 PM
  #7259
No thats not it , there are no notches in my outdrives and these are the 91mm axles ... Good answer though i'm thinking the bad run of outdrives, maybe a bad run of axles. If i break another 91 mm those +2 hubs are gone ...
Old 10-12-2011, 12:45 PM
  #7260
hookem34's Avatar
+2mm hubs.
Not sure what the effects will be if I do change to L setting. Just curious I guess.
hookem34 is offline
