Inferno MP9 thread
#6571
I don't really get the quality complaints either. My practice car has 10 gallons on it and all i've had to swap out was the out drives. The kyosho ones wore a bit excessively on our track. I have heard that they are addressing this issue however. How many hot bodies D8s would it take to go 10 gallons? Only car at our club that lasts as long as the k-car is the updated JQ.
I also did wreck a few clutch bells -- once I drilled the hole in the chassis where the bell was hitting (TKI2 Chassis only issue) I was golden. This mod was free and since I've not had to replace a single bell.
As far as price ... the Yen is a very strong currency; I suspect that has a lot to do with it. Plus, the K-car is made in Japan not in China. Knowing that it wasn't produced in a sweat shop is worth it to me.
Later,
Later,
#6572
anyone know where in the US I can get the kyosho green dish wheels???
seems Amain.Absolute and stormer are out??
#6573
#6574
MP9
Guys I'm having an issue with my tki2 WC.. The front upper chassis stiffener between the steering studs and upper diff case. Its not sitting properly on the diff case. When I screw it down it creates a huge gap as seen in the picture. Is it just me or is this a horrible engineering design?
That's lame I can't post pictures.
#6575
Hi, i have a tki2, I broke two times the read cvds, anybody know if the fioroni ones fit in the tki2? Thanks
http://www.gshobby.com/index.php?mai...ducts_id=17812
#6576
but to answer your direct question yes those will work for the tki2
#6577
#6578
yes i know it is common sense but i just didnt care as i was only breaking in a new motor, but do NOT continue to drive when you have a chipped tooth on your spur gear. it can create massive problems. this started out as 1 tooth missing on the spur and turned to this after about 12 tanks on the new motor lol
#6579
Rear Grip TKI 1
Hi.
I have a TKI 1 with a few upgrades.
The problem is the lack of rear grip. I have adj a lot of steering out but is still a little loose in the back.
is the TKI 2 rear set up better in rear grip???
If so what do i need.
Rear shocks
Rear shock tower
Any help much appreciated .
Rear shocks
Rear shock tower
#6580
Hi.
Rear shocks
Rear shock tower
Rear shocks
Rear shock tower
#6581
the only major difference in the tki2 wc is the offset rear hub carriers
#6582
Auto-Correct? LOL
#6583
#6585
set up !!!!!!!!!!!!!
Thanks guys.
im good at set up just im getting older and don't like heaps of steering. Inserts are correct.
Orange Aprons ???????????? You mean springs?????????????
I have herd the shorter rear tower and shocks help traction but don't understand how???
Much appreciated guys
