Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 07-05-2011, 08:53 AM
  #6421
R/C Tech Elite Member
Trevor Williams's Avatar
Trader Rating: 207 (100%+)
lmao.....
what up Nigel
Trevor Williams is offline
Old 07-05-2011, 09:40 AM
  #6422
CoryD's Avatar
Originally Posted by gabor szilagyi
I...outdrives still good (after like 4-5 gallons).I think there could of been a period when they changed something on the production process and those parts and kits might be different quality...
Driving style and traction conditions have a lot to do with this. Just use OFNA outdrives. Problem solved. Retail on the OFNA outdrives is dealer cost on the Kyosho ones, so they will save you a lot of money.
For the engine move I recommend to use a little medium (blue) tread lock,just a little ,do not dip it in it!
Blue is not for use with fine threads; you should really use purple. It is intended for fine thread applications. Since I started using purple I've never had a motor move.
Later,
CoryD is offline
Old 07-05-2011, 09:59 AM
  #6423
I've never had a ENGINE move period...Nigel, I will be at the Futaba race hanging out...I will probably be pitting for Pucci, if you need any help with anything or pitting, come find me....that goes for all the STL. Kyosho guys
or anyone else for that matter =P
Old 07-05-2011, 12:04 PM
  #6424
sugelle's Avatar
Trader Rating: 63 (100%+)
Default OFNA OUTDRIVES?
What is the part # of the OFNA outdrives people are referring too? Also, is it direct fit or do you have to mod or shim it?
sugelle is offline
Old 07-05-2011, 12:11 PM
  #6425
CoryD's Avatar
http://spstore.rcdepot.ca/TEAMGUYs/C...tdriveMod.aspx
Mod is super easy. Can be done in 5 mintues. Part number is OFN40596.
Later,
CoryD is offline
Old 07-05-2011, 03:02 PM
  #6426
pitpop's Avatar
Hi Guys. Just FYI, Kyosho is addressing this. It's possible there is a batch of outdrives with less than satisfactory heat treating. I can assure you this has nothing to do with "cutting cost" etc. It costs just as much to heat treat the stuff wrong as it does right. Unfortunately this can occur from time to time, and getting it sorted out can be a little tricky. If it goes the other way and suddenly there is too much hardening, it causes other problems. It's a delicate matter. Kyosho has a lot of pride in delivering the highest quality items to the customers. As soon as I get some info that I can release publicly, I will do so...
pitpop is offline
Old 07-05-2011, 03:06 PM
  #6427
pitpop's Avatar
We're going to 2012 Worlds to win it. This opportunity to step into the record books is truly a once in a lifetime opportunity. I fully expect Cody to be on pace, and with a chance to do it. That's all you can ask for.
pitpop is offline
Old 07-05-2011, 03:12 PM
  #6428
malcnz's Avatar
After driving a friends MP9 on sunday after racing I have just ordered a WC version which will need to come from Japan and wonder if I will get the one with harder outdrives..would be nice to I guess if they wear out early and there is a known problem I could claim a warranty?
malcnz is offline
Old 07-05-2011, 04:17 PM
  #6429
Trader Rating: 28 (100%+)
Default MP9
Well just got my car built and to the track today. Track was nasty gnarly, loose, ruts everywhere, kickers from all the weather, perfect for testing.
Took me 3 tanks to get comfortable with the car. I thought Losi's had steering...OH NO! This car will turn inside of any car ive ever driven, off power, on power, at any speed. Very impressed at how flat it stays off of everything. Great car!
Disappointed in the chassis anodize though. Car looks like it has 4 gallons on it. Which whatever, I am on my wheels not my lid, but still.
Well time to start cleaning up the losi for quick sell! MUHAHAHAHA
T
mxtoeknee is offline
Old 07-05-2011, 04:33 PM
  #6430
malcnz's Avatar
Glad you like it . First thing I noticed as well was the steering, and it goes where you want it to go. and it jumps really flat as well.
Also it doesnt get out of shape easily and rides the bumps very well...very easy to drive and within a couple of laps I felt comfortable with it and it wasnt even mine..so I ordered one...cant wait for it to arrive now
malcnz is offline
Old 07-05-2011, 04:51 PM
  #6431
808gx7r's Avatar
you'll love it.
808gx7r is offline
Old 07-05-2011, 06:09 PM
  #6432
Originally Posted by RAlmeida
On a different note, When is Kyosho releasing the Inferno MP10?
The MP9 is a great buggy but too many revisions (and I owned them all)
MP9 TKI
MP9 SE
MP9 TKI2
MP9 TKI2 WC
Will Kyosho take this platform to the 2012 worlds?
The MP10 should be out for 2012 if the follow the plan as in the 7.5 and 777(4 years and 2 WC each).
chirivita is offline
Old 07-05-2011, 07:26 PM
  #6433
MrJinx76's Avatar
Default Orange Springs
Finally got myself a set of Orange Springs to try out!! These are hard to get a hold of, gotta be quick or they sell out all the time!
MrJinx76 is offline
Old 07-05-2011, 08:33 PM
  #6434
SLIM6971's Avatar
Trader Rating: 24 (100%+)
T
Glad I could help you decide to buy the MP9
SLIM6971 is offline
Old 07-05-2011, 10:16 PM
  #6435
Kyosho is about evolution revising and making the proven MP9 platform better and better every year. I hope Kyosho doesn't come out with a totally new car for a good 5 more years just keep revising and making changes and it will be the perfect buggy, just look at ALL the changes from the original TKI to the TKI2.
I will not put a Jammin part on my Kyosho.
Andy
02maxima18 is offline
