Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-09-2011, 12:43 PM
  #6136
Moustik's Avatar
You can use the TKIČ body on TKI1 as well as the radio box.
Moustik is offline
Old 06-09-2011, 12:50 PM
  #6137
the heat mizzr's Avatar
Default BODYS
Thanks ,
the heat mizzr is offline
Old 06-09-2011, 12:59 PM
  #6138
Default BODYS
Is anyone running a cab forward type body like the mugan body?
Old 06-09-2011, 01:05 PM
  #6139
I run the Proline Bulldog for RC8B, fits perfect!
Vicce is offline
  #6140
Moustik's Avatar
Bittydesign has just released a cab forward body for the MP9 "Force". Some people here manage to get the RC8 cab forward body mounted on the MP9. As they said it fits well, just take care to not follow the cutting line on the body specially at the rear.
Luke....
Moustik is offline
Old 06-09-2011, 01:20 PM
  #6141
BigP's Avatar
Originally Posted by Zach Phillips
I can tell it is a 2058, I just bought one for my mp9, and It is about 3/4 inch shorter than the 2013. The one pictured is just as short.
the 2013 is more of a power pipe
the 2058 is a little bit smoother, has more runtime, but not as powerful. Still has plenty of power though.
On that pic of the Car of Jared Tebo from the ROAR 2011 from the RedRC Website (http://events.redrc.net/event-galler...ts/?nggpage=22) you see (when you zoom in), that is a Orion 2013 pipe number on it. But the picture was taken in Qualifing, not sure what he run in the final.
Perhaps pitpop can clear that question and also tell us what pipe, how many ports, venturi size, Cody run in the Qualifing and Final ?
BigP is offline
Old 06-09-2011, 01:51 PM
  #6142
Default body
Just ordered a clear Bittydesign force body to Ridgeway paint , it looks awsome in the photos . Gota look good if your running a world champion car.
Old 06-09-2011, 03:00 PM
  #6143
Trader Rating: 16 (100%+)
he must have changed it for qualifying.
he ran the 2058 at neobuggy with the 3 port though
Zach Phillips is offline
Old 06-09-2011, 03:43 PM
  #6144
Trader Rating: 156 (99%+)
Originally Posted by the heat mizzr
Can i ask if anyone is running the TKI 2 body with the TKI 1 chassis? Olso ,will theTKI 2 radio box fit a TKI 1 chassis?
Both tki2 options you are wanting to do on your tki will work. Both my WC I had a tki and ran the tki2 body since it was released. Much better looking body. As far as the radio box there were no changes made
skoalisbad4me is offline
Old 06-09-2011, 06:16 PM
  #6145
CoryD's Avatar
Anyone who shames their mp9 with a cab-forward body should be forced to sell their mp9 and run a lesser brand; like losi!!!
This is one rc trend that I cannot wait to be over!!!
CoryD is offline
Old 06-09-2011, 06:20 PM
  #6146
BIGTIME's Avatar
Trader Rating: 117 (99%+)
The stock body is DIALED!!!
BIGTIME is offline
Old 06-09-2011, 06:30 PM
  #6147
CoryD's Avatar
Agree; its 55 grams with paint and stickers. You would HAVE to be sunburned in the brain NOT to use it!!!
CoryD is offline
Old 06-09-2011, 07:47 PM
  #6148
didrace's Avatar
Originally Posted by pitpop
the angled piston holes will give more pack, so more high speed damping. This will work for big jumps and flat landings, but if you have really rough conditions, I'm sure you want larger straight hole pistons..
Paul thanks alot..
I have noticed that you rarely use the angled pistons.. so i suspect the normal ones will generally work better..
btw there is slight bending on my front tower..you have to look very closely to notice it..would that make any difference or would it costs any problems?
didrace is offline
Old 06-10-2011, 05:18 AM
  #6149
Any1 know why Tebo has silver springs??? Are they the blues n he jus stripped the color off of them??
MFigueroa is offline
Old 06-10-2011, 06:56 AM
  #6150
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
they were light blues all the way around he just stripped them for looks..
per his post on facebook....
Also just my luck amain is out of stock on the mp9e!! are they out of stock because there is a new update coming for the mp9e? does anyone know?
looks like i will have to order from stormerhobbies!!!
are there any coupon codes for stormerhobbies??
bigBoyBigToy is offline
