Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 03-16-2011, 07:21 AM
  #5101
gabor szilagyi's Avatar
Originally Posted by RAlmeida
Not to sound like an ass, but...assuming we all drive mp9's, they all going to have different engines, pipes, servos, rx, rx packs, etc. and to top it off we all drive different, and at different tracks. I can understand people asking for what tires work where, NOW setup's???, there is nothing wrong with the mp9 box setup and adjust it to the track you drive at and your driving.
End of rant.
I am not a good driver by any means, I enjoy the hobby and know for a fact, that with a properly setup car, you fight the traffic and track and not worry about the car. There are many, many pages out there explaining setup's or you can just ask here, tells us what your car is doing that you don't like, and someone will explain how to correct it.
Agree .Certain setups gonna work on certain tracks.For example Cody's world setup might not going to be the "best" setup on an average small club track...Pro's setup might give a base ,but you will need to adjust to your track ....
gabor szilagyi is offline
Old 03-16-2011, 04:51 PM
  #5102
pitpop's Avatar
Default Japan
I'm with Matthijs in the way I think of this, as it is heart wrenching to think of the things going on in Japan right now. It's hard to think about racing and stuff when you are more concerned with what is going on at the power plant. You have to remember that this is the same culture that endured the atomic bomb and recovered into the technology and industrial power house on the face of the earth. I have no doubt that they will bounce back even more resilient. Everyone I have talked to in Japan is very optimistic, and as you can see from the buggysport post, so is Kyosho Japan. The port they use is Yokohama, which was unaffected by the tsunami. Very fortunate! Also, they had a container enroute when all this happened. Also very fortunate. They also just received a container full of kits I think yesterday. So what does all this mean? ...basically, given the gravity of the tragic events that have unfolded in Japan, Kyosho America is in about as good a shape as you could expect. Very fortunate!
pitpop is offline
Old 03-16-2011, 04:58 PM
  #5103
pitpop's Avatar
I have to honestly say that the top pros set-ups might not exactly fit everyone's driving style. I think Cody and Jared normally have the suspension set-up a little on the stiff side. The good news is, you can probably just soften the springs a little and it will be super dialed. The basic geometry of the chassis set-up (camber links, hub positions, etc.) should stay the same, as well as the diff fluids. That stuff translates over, but unless you are going full noodle into the lip of every jump, you may not need the stiffer suspension and it might be harder to drive. Softer with more traction might suit some intermediate level guys.
pitpop is offline
Old 03-16-2011, 06:02 PM
  #5104
deeje929's Avatar
Can someone tell me the difference other than the side bends on the TKI1 and TKI2 chassis
deeje929 is offline
Old 03-16-2011, 06:55 PM
  #5105
Paul please let us know how can we help!If you have idea what is the way to donate to them or anything please pass the info to us!
Old 03-16-2011, 09:38 PM
  #5106
Trader Rating: 31 (100%+)
I am about to purchase a new chassis for my MP9 TKI, wondering if any one has tried the fioroni one? I like the gasket idea on the bulkheads.
Thank you
I have the fioroni chassis on my buggy. It looks great. And is a little lighter than the tki. I tried the lic drive shafts fr, rr, and center and decided to go back to the stock steel after breaking twice. They would probable be great for oval or tracks with smaller jumps. Hey are extrememly light though!
flysullivan is offline
Old 03-17-2011, 01:05 AM
  #5107
MooseDrool's Avatar
Trader Rating: 7 (89%+)
Any place have the shock ends and cups for this car??? They seem to be out of stock everywhere
MooseDrool is offline
Old 03-17-2011, 04:04 AM
  #5108
deeje929's Avatar
http://www.stormerhobbies.com/cgi-bi...e=&man=&page=7
deeje929 is offline
Old 03-17-2011, 03:14 PM
  #5109
pitpop's Avatar
If you would like to donate to Japan relief, there are many ways to do it here:
http://www.google.com/crisisresponse...quake2011.html
or Paypal:
https://www.paypal-donations.com/pp-...gn.jsp?cid=-12
or via cell phone even:
http://american.redcross.org/site/Pa...lnav_text2help
pitpop is offline
Old 03-17-2011, 11:07 PM
  #5110
Trader Rating: 16 (100%+)
SCREW JAPAN. WHAT ABOUT THE USA PEOPLE THAT NEED HELP AND OUR DEFICET FROM IRAC AND OTHER COUNTRIES. ANY USA PERSON IS STUPID FOR DONATING WHEN OUR GOVERNMENT DOESN'T TAKE CARE OF OUR OWN PEOPLE!!!!!!!!!!!
GASSPRINT1 is offline
Old 03-17-2011, 11:13 PM
  #5111
808gx7r's Avatar
you guys started the war... in the first place
808gx7r is offline
Old 03-18-2011, 01:24 AM
  #5112
MooseDrool's Avatar
Any USA person who can't spell Iraq is stupid.
Old 03-18-2011, 02:11 AM
  #5113
Registered User
Megacrash is offline
Old 03-18-2011, 03:41 AM
  #5114
Super Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
please keep on topic.. all none related rc things please use the chat forums.. posts have been deleted only due to not being on topic... thank you
J.Whiting is offline
Old 03-18-2011, 06:16 AM
  #5115
Received some bits in the mail today & just been checking the weights of the new 91mm captured universal shafts IFW419 & the original 91mm universals IFW456 & as they are supplied, the new unis are heavier by about 0.6g, 23.77 vs 23.16g. If the brown cap/tube thingy is removed & tiny 1.5mm grub screw is used instead, as per just about every other brand on the market, the new IFW419 is lighter by 0.55g, 23.62g vs 23.17g (obviously my $7 ebay 0.01g scales are not quite Swiss watch accurate but they're more than sufficient for my needs).
So my question is: what's the point of having those brown tubes on the axle instead of a tiny grub screw like it's usually done? The brown tube is 1.23g vs 0.07g for a 1.5mm grub screw. Even if there were 2 grub screws per driveshaft, installing 1 on each side of the centre cross-shaft, the tubes are still around 10-20x heavier. The larger front/rear centre uni-shaft brown tube things are more than double the weight of the wheel driveshaft tubes at 2.49g vs 1.23g. With Kyosho always saying how light & efficient the MP9 drivetrain is & how easily it spins up, doesn't it make more sense to run grub screws? I've already put the screws in mine & taken off the tubes. Over the whole car it's less than 0.5g for 6 grub screws vs about 15g for 6 tubes.
So the brown/red/blue tube thingies can't really be all that much more secure than running a grub screw (or even 2 grub screws, just to be safe) can they? Or is it mostly for looks & bling? I realise that with the tube there is no possibility of the cross-shaft coming out, but surely 2 grub screws per shaft would have to accomplish the same? Am I missing something here?
aaron125 is offline
