Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 03-14-2011, 05:32 PM
  #5086
Originally Posted by NeedAJOB
stick with the stock TKI1 chasis really no BIG difference in quality, unless your all about the BLING Factor!
Get the new tki2 hard chassis, same awesome hard coating as the tki1 chassis and the tki2 has a little bit different milling I think, and different bends for the new side guards. If you buy the tki2 chassis you will need the new side guards part number if474.
Andy
02maxima18 is offline
Old 03-14-2011, 05:38 PM
  #5087
My MP9 held up at PNB too and except had battery problems in my last qualifier when I was on a 12 lap run with ONE minute to go!! I went through shock therapy and lost all power! Then in my main, power kicked on and off a few times so I brought it in, big bummer, had a great time, nothing broke on my buggy even in practice which was brutal out there. Next time I'll buy a new lipo for the race.
I saw a lot of MP9's out there, lots of support last weekend, was also cool to see Lutz running the ST-RR, he was crazy fast with that truck wow! Was happy to see Travis bump into the a-main!
Andy
Old 03-14-2011, 09:13 PM
  #5088
gabor szilagyi's Avatar
Yeah congrat to Travis!Also big thanks to mr Martin Philips ,Travis ,and James Banta for the setup help and shock build lesson!
gabor szilagyi is offline
Old 03-15-2011, 01:32 AM
  #5089
MooseDrool's Avatar
Trader Rating: 7 (89%+)
A few Questions. I know this is the nitro thread, but i also know cody runs the electric car too and there is not much help in the electric thread.
I'm looking at getting an MP9e and have a few questions.
-Does it come with aluminum hinge pin holders?
-How is the stock setup
-What would be a good setup to start with for outdoor on a medium sized semi dusty and bumpy track with large jumps?
-What pistons does the car come with?
-How are the stock black springs
-What are some spares that I should keep? I want to be prepared.
-What upgrades does the car need to be as solid as its TKI2 counterpart?
I know it's a lot of questions about a car in the wrong thread, but really will appreciate any answers considering there is very little info on the MP9e
MooseDrool is offline
Old 03-15-2011, 03:52 AM
  #5090
Matthijs's Avatar
- as a start, here is the manual: http://www.kyosho.com/jpn/support/in...rno_mp9e_m.pdf
- stock black springs are the lime green in front and purple in back (I think Pitpop mentioned this along time ago)
- no alu hinge pin holders
- thats your upgrade ;-)
- piston front: 1.2*8, piston rear 1.3*8 (non tapered)
- spare parts: arms
Matthijs is offline
Old 03-15-2011, 10:09 AM
  #5091
MonkeyButt's Avatar
Trader Rating: 46 (100%+)
Guy i sold my tki to wants to put aluminum rr hubs on it, if he puts TKI2 r hubs what else needs to be changed ? IF he puts these :KYOIFW410 nothing needs to be changed i'm assuming but do they have the plastic inserts ?I'm sure this has been asked and answered in this thread already but after skimming for a while I can't find it and any help would be appreciated
MonkeyButt is offline
Old 03-15-2011, 06:18 PM
  #5092
setanborneo's Avatar
- Alum Front Hub
- Alum Rear Torque
optional use front battery holder,to make care easy entering the corner and make easy to jump,its my opinion
setanborneo is offline
Old 03-16-2011, 12:18 AM
  #5093
pitpop's Avatar
You might want to run the 91mm dogbones with the 2mm off-set hubs. Just check the plunge into the outdrives and make sure the pins aren't bottoming out.
pitpop is offline
Old 03-16-2011, 02:35 AM
  #5094
MooseDrool's Avatar
What setup should I start with for the electric car?
Old 03-16-2011, 02:42 AM
  #5095
Matthijs's Avatar
All the info you're looking for can be found on the site from Kyosho USA (I see you mentioned them in your signature, visit their site, that wouldn't hurt)
start with cody's setup: http://www.kyoshoamerica.com/assets/...rcrc2011ai.pdf
Matthijs is offline
Old 03-16-2011, 06:21 AM
  #5096
MonkeyButt's Avatar
[QUOTE=Matthijs;8809970]All the info you're looking for can be found on the site from Kyosho USA (I see you mentioned them in your signature, visit their site, that wouldn't hurt)
start with cody's setup: http://www.kyoshoamerica.com/assets/...rcrc2011ai.pdf[/
Old 03-16-2011, 06:49 AM
  #5097
Not to sound like an ass, but...assuming we all drive mp9's, they all going to have different engines, pipes, servos, rx, rx packs, etc. and to top it off we all drive different, and at different tracks. I can understand people asking for what tires work where, NOW setup's???, there is nothing wrong with the mp9 box setup and adjust it to the track you drive at and your driving.
End of rant.
I am not a good driver by any means, I enjoy the hobby and know for a fact, that with a properly setup car, you fight the traffic and track and not worry about the car. There are many, many pages out there explaining setup's or you can just ask here, tells us what your car is doing that you don't like, and someone will explain how to correct it.
RAlmeida is offline
Old 03-16-2011, 06:50 AM
  #5098
Suspended
www.top-achtung.blogspot.com
Marius13 is offline
Old 03-16-2011, 06:51 AM
  #5099
Any news on Kyosho Japan? Are we going to have parts support?
RAlmeida is offline
Old 03-16-2011, 07:02 AM
  #5100
Matthijs's Avatar
http://www.buggy-sport.info/index.ph...an-update.html
I think the human thing to do is not worrying about parts for your toycar, but to think about the thousands of people losing everything they had in their lives.
parts should be fine, they just need a week to reorganise and get back in business.
Matthijs is offline
