Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-28-2011, 02:58 PM
  #4921
bad ass's Avatar
Trader Rating: 7 (89%+)
hi, I just bought a tki, can I put the same setup in the tki and the tki2???
bad ass is offline
Old 02-28-2011, 03:35 PM
  #4922
gameholic2's Avatar
Yes, at a price.
gameholic2 is offline
Old 02-28-2011, 03:48 PM
  #4923
Trader Rating: 16 (100%+)
Default Tebo not using IFW423
I also have a TKI & there's no probs using the TKI2 setup sheets.
Anyone notice that Tebo was running the forward battery on his buggy at The Dirt 2011 but he was not using the Kyosho genuine part? When IFW423 was released I thought that the DIY mod would actually improve the handling more or in a better way than the genuine part because IFW423 mounts the batt hanging off the radio tray whereas the DIY mounts it further down, on the side guard which would have to improve CoG & change of direction.
I'd guess that apart from a few pros there would be very few people who could actually feel the difference between the DIY & IFW423 placement but you reckon that's why Tebo didn't use IFW423?
aaron125 is offline
Old 02-28-2011, 04:55 PM
  #4924
iglu25's Avatar
Trader Rating: 15 (100%+)
I'm sure it's just a matter of personal preference. I prefer the look of the carbon fiber strip over the top of battery personally, like in Cody's car even though mine looks more like Tebo's.
iglu25 is offline
Old 02-28-2011, 05:06 PM
  #4925
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
notice the shock are all the way out on the tower.
Ultraspeed84 is offline
Old 02-28-2011, 05:20 PM
  #4926
gabor szilagyi's Avatar
Originally Posted by Pete Martinez
thanks do you know where i can find any other set ups i have the codys worlds setup.
U can find lots a stuff here: www.infernosonly.com just click on setup sheets on the top...
gabor szilagyi is offline
Old 02-28-2011, 05:35 PM
  #4927
Tebo ,Pavidis,Cody,Kanai, they all have their own ideas how to mount the battery to the front.Kyosho came out with the IFW423 for us (the public).....
Old 02-28-2011, 06:22 PM
  #4928
I was just wondering if handling had anything to do with his choice coz he also doesn't have the batt as far forward or as far inwards as it could be mounted so it just made a little curious. Not sure about Pavidis but Cody was running IFW423. For sure I prefer the look of Cody's Worlds setup, with the carbon strap though.
aaron125 is offline
Old 02-28-2011, 07:08 PM
  #4929
If you ask me i would think that 1/8 inch doesn't matter,about Pavidis i saw his buggy at Motorama he is running his own idea the same as at the world.Has been pictured and posted on Neobuggy back in the time...His battery has about the same position as Jared's just Pavidis has a nice cover over the battery ....
Old 02-28-2011, 07:13 PM
  #4930
Here you go!This is what Pavidis using :
Old 02-28-2011, 07:19 PM
  #4931
Jeff Werner's Avatar
Trader Rating: 30 (100%+)
Does the Kyosho Produced front battery mount fit/work on the St-rr?
Jeff
Jeff Werner is offline
Old 02-28-2011, 08:31 PM
  #4932
My guess is no because ST-RR has different radio tray. But it just depends on the spacing of the screw holes on the ST-RR. Also coz its only 2 screws, if you really wanted I'm sure a bracket could be made.
aaron125 is offline
Old 02-28-2011, 10:36 PM
  #4933
Does it matter if you use a nihm or lipo when using the forward battery mount? I am considering picking up IFW423 but all I have are numh hump packs so I want to be sure.
xpertpredator is offline
Old 03-01-2011, 12:11 AM
  #4934
No, it doesn't. You can use either Nimh, LiFe, or LiPo hump packs.
STi oWn$ Jo0 is offline
Old 03-01-2011, 04:07 AM
  #4935
setanborneo's Avatar
use front mounted battery, ease into the corner
setanborneo is offline
