Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-28-2011, 06:01 AM
  #4906
gabor szilagyi's Avatar
Wow!!Double win by Kyosho at the Dirt!!Good job Tebo!!!!Also we R soo proud of Cody's strong 3. place in buggy!!!!Cody stayed close to Tebo and Truhe all the time proving his WC knowledge!
gabor szilagyi is offline
Old 02-28-2011, 10:11 AM
  #4907
Default Great Win for Kyosho
Great job by Cody and Jared.
Jared was on fire at the 2011 Nitro Challenge. Cody's interview indicated as such giving props. Was just Jared's weekend. Nonetheless great showing for Team Kyosho/AKA.
Kyosho proving to be a dominant force at the start of 2011. I don't see much changing.
Kyosho back on top for the foreseeable future.
Congrats again.
cfish8u2 is offline
Old 02-28-2011, 10:58 AM
  #4908
Key
Key's Avatar
Anyone know if the mp777 plastic spur fits or works on the MP9?
Key is offline
Old 02-28-2011, 11:02 AM
  #4909
Trader Rating: 16 (100%+)
Did it really have a plastic spur gear? Mine wasn't. Either way, it doesn't matter as it won't work - the centre diff case is a bit larger & the screw holes don't line up.
aaron125 is offline
Old 02-28-2011, 11:05 AM
  #4910
Key
Key's Avatar
It was a separate option part available for the MP777, GT's and ST's but thanks for that tip!
Key is offline
Old 02-28-2011, 11:12 AM
  #4911
Key I gotta ask, why would you do that?
cfish8u2 is offline
Old 02-28-2011, 11:20 AM
  #4912
lol, I was thinking exactly the same thing & that it wouldn't be strong enough but I figure why would Kyosho make/sell it if it was just gonna get stripped as soon as you put it in, so suppose it must be tough enough to last for a little while.
aaron125 is offline
Old 02-28-2011, 11:29 AM
  #4913
deeje929's Avatar
What brand are those springs you use on the brakes
deeje929 is offline
Old 02-28-2011, 11:32 AM
  #4914
I got the same springs on my brakes - mine are Dynamite brand, got em from ebay.
aaron125 is offline
Old 02-28-2011, 12:51 PM
  #4915
Key
Key's Avatar
cfish8u2: I was looking to put it on my MP9e.
Key is offline
Old 02-28-2011, 01:02 PM
  #4916
Pete Martinez's Avatar
Trader Rating: 17 (100%+)
does anyone have the setups for the nitro pit for cody and tebo truggy and buggy thanks.
Pete Martinez is offline
Old 02-28-2011, 01:10 PM
  #4917
I tryed to find it but its still too early,i guess we have to wait till the Sheriff is back in the town (pitpop back on the forum)!
Old 02-28-2011, 01:14 PM
  #4918
thanks do you know where i can find any other set ups i have the codys worlds setup.
Old 02-28-2011, 01:18 PM
  #4919
Trader Rating: 42 (92%+)
pete this is laquan
i would get with jimmy james his car has been pretty dialed
lmk if u want his info
icemandolmite is offline
Old 02-28-2011, 01:25 PM
  #4920
Originally Posted by icemandolmite
pete this is laquan
thanks i forgot
