Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-11-2011, 11:48 PM
  #4771
pitpop's Avatar
Originally Posted by MFigueroa
Anyone knw the item # for those aluminum pivot balls??
Here is the post with the "just like Cody King's MP9" parts list
http://www.rctech.net/forum/8479041-post4456.html
pitpop is offline
Old 02-13-2011, 05:13 AM
  #4772
a complete noob question. my mp9e is pushing when exiting corners. shocks oils are 500 front and rear. anti squat -2. 7000/5000/3000 diffs oil. Where do I start?
1) lighten rear sway bar ?
2) lighten the rear diff oils?
3) a lighter finger ?
any suggestions? any reading materials to look up on?
thanks a million
crittertoo is offline
Old 02-13-2011, 07:14 AM
  #4773
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Thanks for all the help here on the forum Paul. I just tried Cody's set up from CRCRC at a local indoor clay track and it was DIALED!
johnnyboy is offline
Old 02-13-2011, 12:23 PM
  #4774
Hey guys. I ran the round 1 of the grass roots series yesterday at Palm Desert RC Raceway. I struggled all day to find a setup to tame the rear end down, and was able to somewhat get it tamed, but at times it still feels like i was driving on ice at times. I also felt that the car had way too much steering that my current skills could handle. Do you guys have any suggestions as to how I can tame the steering as well as the rear end. I managed to squeak into the A main for sportsman, but I did poorly in the main as the car was too much of a handful for me. Heck if you guys know of a stable setup and doesnt have a ton of steering but good enough that would be great!. I am running 7-5-3 in my diffs right now.
xpertpredator is offline
Old 02-13-2011, 12:53 PM
  #4775
Trader Rating: 156 (99%+)
Try running 552 in the diffs or 553. Also drop to the 2.3 front and 2.5 rear sway bars. ReaLy settle the hole car down a lot. I put those bars on at rev for the losi race and made a huge difference. Also what were you running for shock oil and shock springs?
skoalisbad4me is offline
Old 02-13-2011, 12:57 PM
  #4776
Wouldnt dropping the front down to 5 give me more steering? Ill check what sway bars I have on there now. Whatever came stock with the TkII. I was running the light blue springs all around and 42.5 oil up front and 30 in the rear. My ride height was 28mm F and 29mm R. I have a video of me driving which really shows what I mean but I have no clue how to post it here.
Old 02-13-2011, 02:22 PM
  #4777
quick question about front toe out and setup, i set my tki2 up on a setup station and set the front toe at 1 deg out when i set the car on the stand afterwards the wheels seem to point out allot more than 1 deg but when it is on the ground it seems ok. is this normal should they be more true when on the stand also ?
jboy77 is offline
Old 02-13-2011, 05:19 PM
  #4778
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
i would like to know if i can fit up a couple new Losi flywheel's clutch's combo's, hardned,etc lAYING around, will those be able to get any love either? I like the losi setup, i have a dialed combo, w/shoes/springs/heavier flywheel....will this system work?
TommyBlazin is offline
Old 02-13-2011, 06:04 PM
  #4779
Trader Rating: 30 (100%+)
i was running 553 with 1.3x8 hole pistons with light blue springs and 45 front and 30 in back with rear link in #4 position and car was bad
switched to 1.2 x8 hole pistons and med. green springs in the back with 35 front and 22.5 in back and went to # 8 postion on rear link and the car was way better track was very rutted so no setup was going to be great for bumps but this got me close to bad i broke fuel line at filter in crash in main caused flame outs and aggrivation
also if you want stable try 553 in diffs more toe out loosen sway bars at bulk head so have slop and go to the #8 position in back this makes the car rotate less will work good for you try it out and let me know what you think
jewn_beef is offline
Old 02-13-2011, 08:00 PM
  #4780
Trader Rating: 15 (100%+)
Hey guys. I want to make the switch to threaded shocks, but I have a question. I know that you need the medium threaded shocks for the rear, but what about the front- Do I get the short [KYOIF471] version?
Anyone know where or when the medium threaded shocks will be in stock? All the online places I know of are listed as out of stock.
STi oWn$ Jo0 is offline
Old 02-13-2011, 08:25 PM
  #4781
I was just about to get the threaded shocks front and medium rear and they were both in stock at infernosonly.com
I ended up going with the medium velvet coated ones instead just because personal preference
Old 02-13-2011, 08:30 PM
  #4782
infernosonly was one of the places I looked, they must have just sold their last set.
I need part numbers KYOIF470 and KYOIF471 to go threaded shocks, correct?
Old 02-13-2011, 08:40 PM
  #4783
Default shocks
Yes those are the correct part#s, remember those come with the tapered pistons and no springs...So order accordingly...
Walid
walidelagamy is offline
Old 02-13-2011, 09:11 PM
  #4784
Thanks Walid,
Should I use other shock pistons? Do you have part numbers? I appreciate the help!
Edit: Nevermind, I just looked at Cody's set up sheet. I'll be sure to get (4) 1.3x8 white shock pistons.
Old 02-14-2011, 12:03 AM
  #4785
I will go ahead and give that a try. I have seen that 553 has been the typical setup with this car. My only concern is that it may have too much steering for my taste, but this car has so many tuning options I am sure I could dial it down someway. I was considering trying 10-10-5, but I dont know how that would work. I am basing all of my knowledge on what I tried with my old car the Hot Bodies D8. Gotta get this car dialed for the next grass roots race at Thunder Alley.
