Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 12-09-2010, 11:59 AM
  #4171
Trader Rating: 25 (100%+)
pitpop,
what lipo part # do you guys use with the front battery mod?
Thanks,
arm2storm is offline
Old 12-09-2010, 12:06 PM
  #4172
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Originally Posted by arm2storm
pitpop,
Thanks,
I think it is either one of these (depending on LiFe or LiPo):
http://www.amainhobbies.com/product_...-Balancer-Plug
johnnyboy is offline
Old 12-09-2010, 03:48 PM
  #4173
Key
Key's Avatar
I thought they would use team orion's lithium stuff or am I mistaken?
Key is offline
Old 12-09-2010, 04:52 PM
  #4174
johnnyboy's Avatar
You are mistaken. Orion only have NiMH RX packs. Cody King is also sponsored by A Main Hobbies, hence the ProTek stuff.
Old 12-09-2010, 05:55 PM
  #4175
pitpop's Avatar
Hi there. Johnnyboy is correct, we use the Protek 2300 LiPo. This came about because Orion only has an 1100 LiFe battery, which isn't enough for a one hour main. It's nice to have A Main with a lot of high quality parts. The Protek pack is really reliable and tough with the kevlar sleeve protecting it... very high quality.
pitpop is offline
Old 12-09-2010, 06:08 PM
  #4176
pitpop's Avatar
Originally Posted by Brad8283
Is the out of box set up for the MP9 new racer friendly?
I am getting back into racing after 10 years and have narrowed my car choice to the MP9, 8ight, and the JQ Car.
I want to get the most bang for my buck while not getting frustrated with set ups.
Hi Brad. The set-up on the TKI2 Spec A is very racer friendly. It's actually a good set-up, although depending on your track conditions, you might want to adjust it some.
pitpop is offline
Old 12-09-2010, 09:50 PM
  #4177
Thank you guys
Old 12-10-2010, 05:46 AM
  #4178
Thanks pop
Brad8283 is offline
Old 12-10-2010, 07:14 AM
  #4179
pitpop's Avatar
Thanks pop
np... later if you want some tweaks, come on here and there's always a lot of help...
pitpop is offline
Old 12-10-2010, 01:32 PM
  #4180
Hi Pitop,
Wonder if you can help me, I've just about to order my new engine for next season.
I'm currently running CRF US Ed, do you if the venturi fit the new CRF Alpha engines. I'm going to have one of the 5port, do you know what size venturi comes with the engines as it doesnt really say great deal on this.
What size's have you tried using, I'm thinking of getting the 5.5 & 6 but this depends what actually comes with the engine in the first place.
Hope you can comfirm this for me please
carlin is offline
Old 12-10-2010, 04:27 PM
  #4181
Pete Martinez's Avatar
Trader Rating: 17 (100%+)
Christmas is coming early this year I order the TKI 2 and I get it next week cant wait to get it.
Pete Martinez is offline
Old 12-10-2010, 07:13 PM
  #4182
Key
Key's Avatar
Orion is not limited to carrying NiMH rx bats. 1500mah and 2400 SLB LiPos in hard casing are also available. Since they are sponsored by ProTek it would make more sense to go with those.
Key is offline
Old 12-11-2010, 02:09 AM
  #4183
johnnyboy's Avatar
I don't think those were ever readily available in North America.
Old 12-11-2010, 09:47 AM
  #4184
Key
Key's Avatar
Quite a few places carry them in Canada and the US. The big two are:
infernosonly.com
advantagehobby.com
Key is offline
Old 12-11-2010, 12:16 PM
  #4185
vince7870's Avatar
Trader Rating: 15 (100%+)
My tki2 with all the hardcoated parts and 300$ in spares is on eBay. Pete you are a dumbass for not emailing me. :-)
vince7870 is offline
