Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 12-07-2010, 03:57 PM
  #4156
revrace's Avatar
Originally Posted by Pete Martinez
I was told that the tank cracks cause of chassis flex is this true.
I always run my tank screws a little loose so the tank is a little loose. I have never had a problem cracking tanks.
revrace is offline
Old 12-07-2010, 07:59 PM
  #4157
MadRacer's Avatar
Trader Rating: 33 (100%+)
Default TK1 ?????
Hi All.
As i posted earlier i bought a MP9 second hand. I always thought it was just a normal SE. Only 2 tanks old in grass park and is like new.
After reading that link of all the specs im pretty sure its a TK1.
I have the box and it says Kyosho International, Has AKA tires. Gold turn buckles. I just thought it was a SE. I have put the optional rear block on and ordered some alloy posts for the radio tray and wing. Have put on a set of OT spring strut braces and thats all.
From what i have read the TK2 has a the original rear end. Is the TK1 good with the other set up??? Or do i need to convert it to TK2 specs.
Any help much appreciated.
Thanks.
MadRacer is offline
Old 12-07-2010, 08:03 PM
  #4158
Trader Rating: 156 (99%+)
what length shock shaft do you run in the "medium" rear shock upgrade?
skoalisbad4me is offline
Old 12-07-2010, 08:43 PM
  #4159
Default Medium Shock
Skoal,
The medium shock length is 63mm part#IFW149-02
walidelagamy is offline
Old 12-07-2010, 09:35 PM
  #4160
mtbkym01's Avatar
Trader Rating: 27 (100%+)
Nope!
mtbkym01 is offline
Old 12-08-2010, 12:50 AM
  #4161
pitpop's Avatar
For the spec A car I suggest remove and add loctite to all the screws that go into metal (shock stay, radio tray, steering) and perhaps remove the gearboxes and add grease to the gears (I prefer hg joint grease Kyosho part # 96508). That's pretty much it... that's what we ran at Kyosho Masters
Car looks great!
Originally Posted by Caryphotography
Hey Guys,
I'm fairly new to the whole RC Tech forum site. I just got done building my MP9 TKi2 Spec A kit. This is my 2nd MP9, I bought out from the first batch that came out and I still have it. After seeing Cody Win the Worlds I thought I'd build up a car that was identical as possible to his winning can. only difference, I'm running the 3-port Orion instead of the 5-port. Anything I should be checking for on these spec A kits that should be addressed before i run it. In past, I tried to only get kits so that I can do all my little build tweaks. Attached is a photo of the car.
pitpop is offline
Old 12-08-2010, 07:16 AM
  #4162
deeje929's Avatar
Ron YGM!!!
deeje929 is offline
Old 12-08-2010, 03:41 PM
  #4163
didrace's Avatar
Originally Posted by Matthijs
- offset carrierhubs, I didn't notice much difference on the track, but I haven't really tested them back-to-back. I you put the offset hubs on you can retain the same wide of the car by reversing the bushing in the arm. That compensates for the 2mm. Or you can use the narrow wheelhub and use the standard position of the insert on the arm.
If you run a race series where you don't have to comply to ifmar rules about how wide your car is you can use the offset carrierhubs, standard wheelhubs and standard insert position, you'll need the 93 mm universals for that. You will gain 2mm on the back of your car, making it more stable.
- The new TKI2 body fits the TKI perfectly, you won't need the new sideguards or chassisplate. Only thing you'll need is a lower airfilterset, such as the one used on the TKI2. The TKI2 body sits lower.
-I really don't know what the difference is between the previous chassisplates and the new IF473 plate & the IF474 side guards, from the pics I can't tell any differences. Haven't had them on the bench yet ;-) On the TKI2 kit the 'normal' chassisplate is included.
- I didn't use the new shocks yet, winter time in The Netherlands, so indoor with the RB5 sp2!
Here is a series spec chart for the MP9 line-up: http://www.kyosho.com/eng/fun/specia...al_data02.html
Thanks a lot..
So from what i understand kyosho tried to change the rear geometry a bit.. they refined the rear end.. It sounds like the thought of jq where he uses longer hubs but shorter arms but his design looks a bit different..
I want to follow cody kings setup which is 2mm offset standard wheel hubs but from what i understand the bushings inside the a arm..
there must be some reason he used this setup in the worlds...
I hope they worth the money as i am going to buy them as soon as i can..
didrace is offline
Old 12-08-2010, 06:54 PM
  #4164
tony montana's Avatar
Trader Rating: 76 (100%+)
what are the best tki2 upgrades to do to the tki. Are the new tki2 shocks really a improvement over the tki? If I bought the tki2 shocks do I need the tki2's shock towers . Looking to get a order going
tony montana is offline
Old 12-08-2010, 07:35 PM
  #4165
rcjunky10's Avatar
Trader Rating: 227 (100%+)
Best upgrades are:
- medium rear shocks
- medium rear tower
- 93 mm swing arm
- 2mm offset rear hubs
These are the hot tickets for us tki owners.
rcjunky10 is offline
Old 12-08-2010, 08:09 PM
  #4166
rfleck's Avatar
Trader Rating: 58 (100%+)
Default MP9 SE discontinued???
Guys, Maybe someone can chime in but I have heard the MP9 SE has been discontinued. I've also noticed it has been on B.O. for quite some time at A-main and no longer on RPP's website.
Thanks,
rfleck is offline
Old 12-08-2010, 09:03 PM
  #4167
pitpop's Avatar
the threaded shocks are quite good, they seem to bleed easier with the new cap
pitpop is offline
Old 12-09-2010, 12:57 AM
  #4168
pitpop's Avatar
Thanks,
The SE version kit is most definitely still being produced, so if any shop has it on back order, they should receive the kits. I will check the supply line to see how long it might be...
pitpop is offline
Old 12-09-2010, 09:05 AM
  #4169
pitpop's Avatar
Kyosho America will receive SE kits January 20th. The back orders should be filled a couple days after...
pitpop is offline
Old 12-09-2010, 10:31 AM
  #4170
Is the out of box set up for the MP9 new racer friendly?
I am getting back into racing after 10 years and have narrowed my car choice to the MP9, 8ight, and the JQ Car.
I want to get the most bang for my buck while not getting frustrated with set ups.
Brad8283 is offline
