Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 11-02-2010, 07:57 PM
  #3796
Trader Rating: 28 (100%+)
Need to make room for the TKI2.
bphil49 is offline
Old 11-02-2010, 08:00 PM
  #3797
pitpop's Avatar
smart man
pitpop is offline
Old 11-02-2010, 08:29 PM
  #3798
ON A MISSION's Avatar
Trader Rating: 34 (100%+)
PK any testing with the new cvd's ? center or f/r ?
ON A MISSION is offline
Old 11-03-2010, 10:57 AM
  #3799
Peter Martin's Avatar
Kanai Battery holder
Peter Martin is offline
Old 11-03-2010, 11:09 AM
  #3800
I see an aluminum upper arm holder as well.
Alan D. is offline
Old 11-03-2010, 11:15 AM
  #3801
Jammin57's Avatar
Trader Rating: 120 (100%+)
The tki2 comes with all aluminum arm holders front and rear
Jammin57 is offline
Old 11-03-2010, 11:16 AM
  #3802
http://rcmag.com/modules.php?name=Fo...wtopic&t=38732
Old 11-03-2010, 03:08 PM
  #3803
mtbkym01's Avatar
Trader Rating: 27 (100%+)
Default Bulldog Body
Those guys using the RC8 bulldog body, did you have much trouble fitting it onto your MP9?
mtbkym01 is offline
Old 11-03-2010, 03:27 PM
  #3804
Default BullDog
Fits very well, the only thing is cut the rear body line long, the RC8 body is about a 1/4" short. Everything else is fine....
Walid
walidelagamy is offline
Old 11-04-2010, 03:47 PM
  #3805
-WHEELMAN-'s Avatar
Trader Rating: 267 (98%+)
She's mine!! Cant wait!! And the Losi 2.0 is up for sale but not like you guys care!! I checked out Petit RC wheres all the setups? If anyone wants to help out ill be running on a 140x60 medium to high bite track.
-WHEELMAN- is offline
Old 11-04-2010, 04:08 PM
  #3806
Brett the set up on it now is Cody Kings from the 2008 worlds. I would send it to you but I see Kyosho has taken it off there site. Maybe Pitpop will chime in.
bphil49 is offline
Old 11-04-2010, 04:24 PM
  #3807
pitpop's Avatar
pictures of Cody's car, sans engine:
http://www.facebook.com/#!/album.php...0&id=747584896
pitpop is offline
Old 11-04-2010, 04:30 PM
  #3808
pitpop's Avatar
they switched servers and lost all our set-ups
I would use Cody's Sidewinder set-up and use the forward battery mounting, it's dialed...
pitpop is offline
Old 11-04-2010, 04:32 PM
  #3809
pitpop's Avatar
unfortunately not.. we "might" run the centers in the first or second round of qualifying, but it's a little sketchy to run something you haven't been using at the Worlds. Even if we had been testing all week with them, I still might not feel comfortable...
they may very well be the best thing since sliced bread
pitpop is offline
Old 11-04-2010, 05:34 PM
  #3810
-WHEELMAN-'s Avatar
Man thats got to piss ya off. With all the time you have invested in helping.
Nice, ill be watching, good luck in beautiful Ti.
Thanks Brian, ill locate it one way or another. I will be trying the Sidewinder setup as well. Will be running it nitro for the first few weeks before it gets cold and I go indoor for the winter Running the 2.0 nitro first helped show me what the differance was between that and electric. Showed me what I had to fix in the setup.
