Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 10-29-2010, 12:27 AM
  #3781
Same medium tower and shocks on the SE and TKI2.
Alan D. is offline
Old 10-29-2010, 12:48 AM
  #3782
Trader Rating: 17 (95%+)
ok, thanks grabed a used SE here.. its going to be my practice car
jbaq is offline
Old 10-29-2010, 11:33 AM
  #3783
hopsing's Avatar
Trader Rating: 13 (93%+)
Originally Posted by jbaq
to make the SE like the TKI2 what do i need to change? i dont care about bling or shocks and already have the hingepin holders..thanks
Originally Posted by Jammin57
It's the exact same car as what you got, the tki2 just has threaded shocks, all aluminum hingepin plates, aluminum off-set rear hubs with 93mm universals, Lightweight outdrives, and body and air filter so if you don't want the shocks you just need the offset hubs longer rear universals The lightweight outdrives and body and filter
The TKI2 hubs are part# IFW414 and the 93mm universals are IFW404. The TKI2 also uses longer kingpin bolt/bushing kit which is IFW467 and the pistons used are IFW405-1.3 8 hole in the front and IFW405-1.4 8 hole in the rear. Hope that helps!
hopsing is offline
Old 10-29-2010, 04:01 PM
  #3784
pitpop's Avatar
Originally Posted by ON A MISSION
PK did you ever post the sidewinder set-up by chance ?
Here you go:
pitpop is offline
Old 10-30-2010, 12:55 AM
  #3785
mp9er's Avatar
Post
thanks pitpop goodluck at the worlds
mp9er is offline
Old 10-31-2010, 02:06 PM
  #3786
rfleck's Avatar
Trader Rating: 58 (100%+)
Default SE, TKI, TKI2?
Hello,
I am looking at potentially going with an MP9. Are there any performance benefits to buying the higher priced TKI or TKI2 or is the SE just as good on the track?
Thanks,
rfleck is offline
Old 10-31-2010, 02:17 PM
  #3787
The reason the SE is much cheaper than the TKI or TKI2 is it does not come with rims or tires the velvet coated shocks and the hard aluminum chassi. they all can be "upgraded or downgraded to SE, TKI and TKI2" the tki2 has the new body, air filter, all the aluminum bling, treaded shocks (but not velvet coated).
they all are great cars, basically the same car with different options......
RAlmeida is offline
Old 11-01-2010, 05:56 AM
  #3788
Default whats this part?
hi guys, just got my mp9 tki2 kit and im almost done building.
anyone any ideas what this part is , there is 2 of them ?
it says they not used but curious what they are just
jboy77 is offline
Old 11-01-2010, 12:58 PM
  #3789
gameholic2's Avatar
I don't own a kyosho but that looks like a radio tray mounting post.
i'm probably wrong...
gameholic2 is offline
Old 11-01-2010, 02:56 PM
  #3790
skydark_34's Avatar
Default shock piston
what is the size for these shock piston?15mm?16mm?or 17 mm?
Kyosho SP Big Shock Piston (1.3 x 8 hole) (2)
[KYOIFW405-138]
Kyosho SP Big Shock Piston (1.4 x 8 hole) (2)
[KYOIFW405-148]
skydark_34 is offline
Old 11-01-2010, 04:42 PM
  #3791
Trader Rating: 16 (100%+)
15.8mm on the calipers. So 16
Zach Phillips is offline
Old 11-01-2010, 05:21 PM
  #3792
pitpop's Avatar
Hi guys, please let me clarify something. The SE has the same high quality 7075 aluminum chassis. The anodizing IS different, however the benefit of the green coating is marginal IMO. The brown anodizing is more cost effective than the green coating (hence cheaper), but in my opinion they wear off at almost the same rate. Of course you will see the scratches on the brown coating much more clearly than the light green coating on the TKI chassis, it's just more obvious to see the silver aluminum color behind the brown. Once the coating is scraped off, the two chassis wear the same (very well I might add)... I would say the TKI chassis is not much better than the SE chassis. I believe all the replacement chassis have the light green coating.
As far as the SE car goes, it also doesn't have the lightweight diff shafts (or out-drives as many people say). We raced an SE car out of the box and did very well with it. You could basically win any race with the SE car in box stock trim. JMO
pitpop is offline
Old 11-01-2010, 05:27 PM
  #3793
johnnyboy's Avatar
Trader Rating: 28 (97%+)
I noticed the hard annodized parts wore better than the brown anodizing. Still the good aluminum but the hard anodizing is tougher.
johnnyboy is offline
Old 11-02-2010, 06:21 PM
  #3794
Trader Rating: 28 (100%+)
Selling my MP9 TKI. Check it out.
http://www.rctech.net/forum/r-c-item...ml#post8157403
bphil49 is offline
Old 11-02-2010, 07:46 PM
  #3795
pitpop's Avatar
Originally Posted by bphil49
looks nice!
pitpop is offline
