Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 10-25-2010, 06:56 AM
  #3766
deeje929's Avatar
Not much still coaching waiting for the season to be over. So I can apply for
defensive coordinator jobs or position coach ont he college level.
AND AND waiting for Kyosho's newest female driver to come in
the world on Dec 3.
deeje929 is offline
Old 10-26-2010, 10:36 AM
  #3767
iglu25's Avatar
Trader Rating: 15 (100%+)
the world on Dec 3.
What!! Congrats bro, and good luck with the coaching gig.. Hope to see you at a race in the near future.
iglu25 is offline
Old 10-26-2010, 01:06 PM
  #3768
deeje929's Avatar
Thanks bro.
deeje929 is offline
Old 10-26-2010, 11:45 PM
  #3769
pitpop's Avatar
Cody interview, and yes, I told him medium compound lol ... maybe I should just keep my mouth shut sometimes
http://rcinsider.com/?p=1901
pitpop is offline
Old 10-27-2010, 05:40 PM
  #3770
iglu25's Avatar
lol... I like how he covered for you though.. "I had some people throw some stuff at me, and I changed at the last second." It's all good, I'm sure you've been right the other four thousand times.. or maybe not
iglu25 is offline
Old 10-27-2010, 06:03 PM
  #3771
hopsing's Avatar
Trader Rating: 13 (93%+)
LOL, I did the same thing...was set on running soft enduros for the 10 min 1/8 Elec main and changed to mediums the race before and the car wasnt nearly as good at the beginning as it could have been, not that I had anything for Kortz or Moller I think I changed my mind on tires at least 3 or 4 times that morning (pretty much every time the sun came out or went behind the clouds )
Cody was dialed though, his TKI2 looked soo good....I think he may be a contender at the Worlds He's been driving really good lately.
hopsing is offline
Old 10-27-2010, 06:52 PM
  #3772
pitpop's Avatar
I think it's true what he said about the end of the race is more about the compound than the tread. The mediums were good at the beginning, but I was afraid they might be a handful at the end. We had the softs ready and he could have switched it up, so he takes his share of the blame. I think it's cool the top 3 all had enduros and both compounds were competitive, reflects well on AKA. It was a very tough choice the way the temp was fluctuating. Mid day the medium would have been dialed.
This has absolutely no effect on our Worlds effort. We're ready to turn and burn in Pattaya, and we will definitely have the tire choice right over there. I'm excited to see the AKA rubber on the oily track...
pitpop is offline
Old 10-27-2010, 06:54 PM
  #3773
pitpop's Avatar
I'm usually right
pitpop is offline
Old 10-28-2010, 10:07 AM
  #3774
Trader Rating: 152 (99%+)
Is the body for the tki (not the tki 2) the same as the regular MP9 body? Also anyone know where I can buy a tki2 body from?
skoalisbad4me is offline
Old 10-28-2010, 10:59 AM
  #3775
Jammin57's Avatar
Trader Rating: 120 (100%+)
The bodys are the same only the tki2 is different, there was some on eBay but not sure where else you can get them
Jammin57 is offline
Old 10-28-2010, 11:20 AM
  #3776
Ask your local Kyosho dealer to see if they can order the TKI2 body.
Alan D. is offline
Old 10-28-2010, 05:37 PM
  #3777
ON A MISSION's Avatar
Trader Rating: 34 (100%+)
Default PK
PK did you ever post the sidewinder set-up by chance ?
ON A MISSION is offline
Old 10-28-2010, 08:03 PM
  #3778
Trader Rating: 17 (95%+)
to make the SE like the TKI2 what do i need to change? i dont care about bling or shocks and already have the hingepin holders..thanks
jbaq is offline
Old 10-28-2010, 10:32 PM
  #3779
Jammin57's Avatar
It's the exact same car as what you got, the tki2 just has threaded shocks, all aluminum hingepin plates, aluminum off-set rear hubs with 93mm universals, Lightweight outdrives, and body and air filter so if you don't want the shocks you just need the offset hubs longer rear universals The lightweight outdrives and body and filter
Jammin57 is offline
Old 10-29-2010, 12:02 AM
  #3780
what about the rear shock tower is it the same?
jbaq is offline
