Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 08-17-2010, 05:05 PM
  #3631
Actually is a 2650mah, home made Duracell rechargeable from home depot, $12.00 per pack of 4, and they actually take 2873mah. I had too many malfunctions with the lipos
RAlmeida is offline
Old 08-19-2010, 09:06 AM
  #3632
Matthijs's Avatar
new front alu brace, IFW418
Matthijs is offline
Old 08-19-2010, 09:24 AM
  #3633
Originally Posted by Matthijs
I'm still running the Alpha Abi 3 port. The model after that is the Alpha CRF Abi 3 port, or 7 port. New in the line up is the 5 port.. (which will be my new one).
Whats the 3port like on fuel & perfomance too?
carlin is offline
  #3634
Whats the 3port like on fuel & performance too?
carlin is offline
Old 08-19-2010, 09:30 AM
  #3635
JG!
JG!'s Avatar
Trader Rating: 25 (100%+)
Originally Posted by carlin
Do you know the model number because the Team Orion website isnt fairly up to date is it?
Seen that there is the new 5port out now
ORI80679 3.5 cm³ CRF 3.5ccm Off-Road Engine (ABC/5 port)
ORI80680 3.5 cm³ CRF 3.5ccm Off-Road Engine (ABC/5 port), set w/ pipe
But cant find any prices anywhere
I think this it
http://www.amainhobbies.com/product_...ine-Turbo-Plug
JG! is offline
Old 08-19-2010, 01:11 PM
  #3636
Matthijs's Avatar
For the Abi Alpha (not the CRF) fuel about 10 minutes with the 2057 pipe, If you are smooth on the throttle you can get some more... Powerband very smooth, not as explosive as the 5 port CRF Us Spec. On our tracks (astroturf) I liked the power of the CRF Us spec, so my next engine will be the Abi CRF 5 port... but that will be 2011... my 3 port still does the job!
Matthijs is offline
Old 08-20-2010, 06:41 AM
  #3637
Yeah the CRF US Ed is very good got so much bottom - mid power brilliant.
I run 6mm rest & 2013 pipe usually get about 11mins ish on good day. Just depends how i drive with the throttle
I think the 5port will be my next engine, does anyone know if it comes with the carb rest like the US Spec did?
carlin is offline
Old 08-23-2010, 12:18 AM
  #3638
Where do guys use the Kyosho 1300 weight oil, maybe rear diff in a truggy? I picked up a TON of kyosho oils and gonna slowly convert to using only kyosho, so to replace my 40wtin the front going to use 500-550 and the rear 300-350. Used to use losi for shocks mugen for diffs.
Andy
02maxima18 is offline
Old 08-23-2010, 07:06 PM
  #3639
Trader Rating: 26 (100%+)
can someone post a good starting setup. maybe a cody king. i know its been posted a million times i dont want to look back forever.
eddie10 is offline
Old 08-23-2010, 10:59 PM
  #3640
Originally Posted by Moustik
I took it before the new website come alive. I hope they will make a new factory support part or make the settings sheets available on a centralised database.
Luke....
You could try using Jared Tebos Nats 2010 setup (quoted above). Just click on the arrows (look like these >>) and it will take you to the original post where you can download the setup.
Alan D. is offline
Old 08-24-2010, 02:43 PM
  #3641
Got my TKI down to 2.983 KG no fuel or tires, up to 3.539 with tires and fuel, how can I get it lighter?
OS speed with 2050
life 1700
airtronics M11x small receiver
7955tg steering
9100s throttle
rear aluminum toe block
radio and wing aluminum posts
stock boby.
RAlmeida is offline
Old 08-24-2010, 03:28 PM
  #3642
Trader Rating: 16 (100%+)
Aluminum nuts, titanium screws, titanium turnbuckles, some tires/wheels weigh more than others
Zach Phillips is offline
Old 08-25-2010, 12:46 AM
  #3643
mp9er's Avatar
Post
get rid of the aluminium wing and radio posts run the plastic ones
mp9er is offline
Old 08-25-2010, 05:22 PM
  #3644
Default MP9E
This may be a question most of you might not have any experience with, but here in Fla. we run a lot of Oval, even with 1/8 buggies. I intend to run my new MP9E in Oval, and I'd like some advise as to the right Dif. Lubes to use. My friends are using 100K Front, 120K Center, and 10k rear in their Ofna Hyper 9s'. Should this work in the 9E? I appreciate the help.
Here's a link to the track:
http://southfloridadirtovalrc.com/Home.aspx
napolean is offline
Old 08-25-2010, 05:25 PM
  #3645
johnny boy's Avatar
Trader Rating: 326 (100%+)
http://www.rctech.net/forum/r-c-item...ml#post7845104
I have many other nip parts if anybody is interested
sorry for the post in here but i want to get directly to you mp9 guys
johnny boy is offline
