Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 08-14-2010, 11:29 AM
  #3616
Matthijs's Avatar
Originally Posted by carlin
Do you know the model number because the Team Orion website isnt fairly up to date is it?
Seen that there is the new 5port out now
ORI80679 3.5 cm³ CRF 3.5ccm Off-Road Engine (ABC/5 port)
ORI80680 3.5 cm³ CRF 3.5ccm Off-Road Engine (ABC/5 port), set w/ pipe
But cant find any prices anywhere
I'm still running the Alpha Abi 3 port. The model after that is the Alpha CRF Abi 3 port, or 7 port. New in the line up is the 5 port.. (which will be my new one).
Matthijs is offline
Old 08-16-2010, 05:49 AM
  #3617
Matthijs's Avatar
Originally Posted by Pdpower
So give us your feeling on the performance of the car with the medium shocks and tower vs the large ones, after that race.
Had the race this sunday, finished 5th in the Amain, very happy with the car and changes sofar. I didn't have time to practice on saterday, so no tracktime with the long shocks and the medium on the same track/tires.
But the car was very stable with the medium shocks and towers. Also my initial setup with the tapered 1.3x8 & 1.4x8 shocks (600 front and 450 rear) were spot on for this astroturf track with medium & low jumps. Definately worth trying. In two weeks we have our national series race on the same track, I'll try some other setups again.
The ebay-shocktowers held pretty well! Let's see how they hold up the next race, as stated before, the car was very stable so no big crashes for me this time
Matthijs is offline
Old 08-16-2010, 08:42 AM
  #3618
captain america's Avatar
Are you talking about the e-Bay vendor that sells remarkably cheap aluminum parts out of British Columbia?
captain america is offline
Old 08-16-2010, 10:13 AM
  #3619
Matthijs's Avatar
yes, I contacted him if he could make a costum front tower with an extra topbrace in it, should be very strong... I'll let you know
Matthijs is offline
Old 08-16-2010, 10:55 AM
  #3620
morgoth's Avatar
Where did you race Matthijs?
morgoth is offline
Old 08-16-2010, 01:24 PM
  #3621
Matthijs's Avatar
local clubrace @ Berlikum in Friesland (that's way up north...). Had lots of fun and practice for our Xceedcup-series in two weeks...
Matthijs is offline
Old 08-16-2010, 02:56 PM
  #3622
morgoth's Avatar
Big smile I'd like to do some more races, but everything seems to be Nitro only Or they have 30min finals (if you get there )
I'm off to Mach One this weekend to practise a bit for the No Nitro cup I hope the date is 5 september...
morgoth is offline
Old 08-16-2010, 06:12 PM
  #3623
What is everyone's car weight in at, mine (TKI) with speed, 2050MP, 7955tg and 9100s, proline m2 calibers, airtronics m11x rx, and proline body and wing, 2700nmih, comes in at 3459g without fuel, heavy I think
RAlmeida is offline
Old 08-17-2010, 05:13 AM
  #3624
deeje929's Avatar
How can I get one of those jacket shipped to the US.
Also I see that there ae 1.2*8 and 1.4*8 SP pistons and both are white how to tell the difference between the two
deeje929 is offline
Old 08-17-2010, 05:30 AM
  #3625
morgoth's Avatar
A lipo instead of nimh will lower the weight.
Try calipers, they work for me.
morgoth is offline
Old 08-17-2010, 07:30 AM
  #3626
Thats quite on the heavy side, are you sure your scale is acurate?
Thanks Matthijs on the input
Pdpower is offline
Old 08-17-2010, 02:01 PM
  #3627
Trader Rating: 18 (100%+)
Standard Kit+alum radio mounts, Proline Holeshots, 808 stock body, Speed w/2050, 7955TG, 1700life, proline wing, futaba receiver -- 3305 grams no fuel.
SkaterX is offline
Old 08-17-2010, 02:22 PM
  #3628
morgoth's Avatar
That's a difference of a least 70-85g at least on the reciever pack only...
morgoth is offline
Old 08-17-2010, 04:20 PM
  #3629
Nimh is 120 grams, the life is 90.
The difference would be in the tires/rims most likely.
Also, the 808 body is much lighter and fits like a glove...
SkaterX is offline
Old 08-17-2010, 04:27 PM
  #3630
morgoth's Avatar
A 5pack 2700mah Nimh? Could you link me a pack that light? I guess you were looking at a 1700mah nimh pack.
morgoth is offline
