Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 08-11-2010, 11:01 PM
  #3601
Matthijs's Avatar
Originally Posted by vince7870
i recently purchased the 2mm offset rear hubs. i noticed the instructions said to turn arm insert so hub closer to diff housing. with regular hubs the insert was the opposite way. anyone have any insight on these hubs? i had the previous regular aluminum hubs but bent those rather quickly
Originally Posted by pitpop
Hi Matthijs... well, let me say that I don't want to discourage anyone from using the full offset if they are allowed. My post here was based on my experience, that the MP9 just barely fit into the IFMAR box, so surely if 2mm added width, could be illegal.
To answer your question why use more offset and move hingepin, theoretically you will get less roll center variation with shorter lower arm, which I think is a good thing. It is a slight adjustment to the geometery of the rear suspension, which always yields at least some effect on the handling of the car. This will also theoretically reduce camber change on compression of the suspension. (which will produce [in PK's suspension book] "positive camber push" at the apex of a corner) That's my own term, you heard it here first.
there you go!
Matthijs is offline
Old 08-11-2010, 11:06 PM
  #3602
Matthijs's Avatar
Got some new blingbling om my car (let's see who can find them), also finally the medium rear shocks, can't wait to see if I notice something different. The more I look at the bulldog body, the more I like it, especially in all white...no green for the time being...
Matthijs is offline
Old 08-12-2010, 04:33 AM
  #3603
Very nice!
I see that the shock towers changed color, that buldog body looks like it was made for that car! What body is it for, RC8?
Pdpower is offline
Old 08-12-2010, 07:43 AM
  #3604
Matthijs's Avatar
Originally Posted by Pdpower
Very nice!
yes, it's a RC8 body from Proline, fits really nice after some alternative cutlines. The shocktowers are an ebay gamble don't know how they hold up, exact copy of the originals and I needed the medium rear tower, for the price I couldn't resist. I have a race this sunday and will test them with some big crashes...
Matthijs is offline
Old 08-12-2010, 08:09 AM
  #3605
So give us your feeling on the performance of the car with the medium shocks and tower vs the large ones, after that race.
Pdpower is offline
Old 08-12-2010, 08:25 AM
  #3606
deeje929's Avatar
How can u tellt he differcne between the 1.3* SP and the 1.4*8 Sp pistons
if they are both white . I notice that one had a ring on teh outside of the piston but what is the size
deeje929 is offline
Old 08-12-2010, 08:32 AM
  #3607
Matthijs's Avatar
the 1.3x8 sp piston is black: http://www.amainhobbies.com/product_...-13-x-8-hole-2
the 1.4x8 sp piston is white: http://www.amainhobbies.com/product_...-14-x-8-hole-2
all of them: http://www.amainhobbies.com/advanced...filter_cat=994
Matthijs is offline
Old 08-13-2010, 12:15 PM
  #3608
jesperolsen1972's Avatar
Default Astro
Hi guys
Does anyone have experience with astroturf racing?
Im going to a race at a brand new track here in Norway, and its 100% astroturf. I have never raced on that surface, and i wonder if anyone has a good starting set-up.
What tires do you use for instance?
Have anyone tried the Schumacher mini-spike tyres? I know they work well at 1/10 races.
All inputs will be appreciated
jesperolsen1972 is offline
Old 08-14-2010, 12:38 AM
  #3609
Matthijs's Avatar
Originally Posted by jesperolsen1972
Hi guys
Schumacher angled spikes for long astro turf, of mini pin for short. Both used with aka insert (or any other closed cell type).
Setup:
diff f/c/r: 10.000 - 10.000 - 5.000
shock front 550 with 1.2x8, rear 450 with 1.3x8
shockangle, all in on tower, out on arms
long upperarm link
ackerman in middle
low rollcentre on front and back, 2 degrees antisquad, 21 degrees caster
limited droop settings, depending on the jumps.
If you keep having traction roll remove some outher row pins from the tires. On very dry tracks I remove the outher 2 rows and inner 2 also. Seems odd, but trust me, you will have the best acceleration ever en very high corner speeds.
Matthijs is offline
Old 08-14-2010, 01:04 AM
  #3610
Yep, it's true
m.velder is offline
Old 08-14-2010, 07:48 AM
  #3611
Setup:
long upperarm link
ackerman in middle
Great
Thank you. Now i have a starting point. I'm looking forward to try this high traction racing
Old 08-14-2010, 10:04 AM
  #3612
Hi Matthijs,
Nice looking ride with the RC8 shell.
Little bit of topic but Team Orion engine are you running.
I've just SOLD my MP9 & Team Orion CRF US Ed engine.
Just got my TKI2 Kit to build but looking at new engine.
I wasnt to sure with the CRF Alpha series or the ABI versions.
What engines is Jared Tebo running at the moment is it the ABI series or the CRF ones?
carlin is offline
Old 08-14-2010, 10:08 AM
  #3613
JG!
JG!'s Avatar
Trader Rating: 25 (100%+)
Tebo is running the CRF 7 port
JG! is offline
Old 08-14-2010, 10:09 AM
  #3614
tony montana's Avatar
Trader Rating: 76 (100%+)
Im not much on one color bodies, but that actually looks pretty slick
tony montana is offline
Old 08-14-2010, 10:27 AM
  #3615
Do you know the model number because the Team Orion website isnt fairly up to date is it?
Seen that there is the new 5port out now
ORI80679 3.5 cm³ CRF 3.5ccm Off-Road Engine (ABC/5 port)
ORI80680 3.5 cm³ CRF 3.5ccm Off-Road Engine (ABC/5 port), set w/ pipe
But cant find any prices anywhere
carlin is offline
