Inferno MP9 thread
#3586
Greetings to all
i am almost done with the build of my SE kit, and i want to try jared tebo's neo09 setup, but i can't find anywhere if the front and rear tread must be set to S, M or L setting ?
thx to all for help, i've read all the 239 pages of this thread, very good info there
Luke....
#3588
Drove an MP9 a couple days ago and got to work on it as well. Absolutely loved it. Trying to get my MBX6 to handle like one.
#3593
Andy
#3594
HARD COAT CHASSIS WITHOUT A DOUBT.
#3596
i got the lunsford screw kit on my mp9 with lipo/life futaba servos and origanally orion motor it was sitting at 32.3gr
its hard to say how much u will lose as it depends on all your running gear
#3598
The lunsford turnbuckles save weight, can't tell you how much, didn't weigh them. You can also use the Kyosho Titanium screw kit, item IFW411.
My car is race ready (without fuel) 3240 gram. I used titanium turnbuckles and screws, no switch (thats 15 gram) and no mudguard on the rear arms and no shockboots. Also a 1700 mah lipo and an Orion engine / pipe.
#3599
i recently purchased the 2mm offset rear hubs. i noticed the instructions said to turn arm insert so hub closer to diff housing. with regular hubs the insert was the opposite way. anyone have any insight on these hubs? i had the previous regular aluminum hubs but bent those rather quickly
#3600
i just put lunsfords tie rods on my mp9 tki last week, they are about a gram less each, so you save some weight. my mp9 with half a tank of fuel is 3400g. thats aka tires and wheels, life battery, and the rest is stock
