Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 07-28-2010, 10:23 AM
  #3541
deeje929's Avatar
The representive for the shop in japan told us the towers were harden anodized. I'm not sure who to believe
deeje929 is offline
Old 07-28-2010, 10:43 AM
  #3542
johnnyboy's Avatar
Trader Rating: 28 (97%+)
I hope they are, but the sheet from Kyosho and the press photos say regular. I guess the first guy who opens their new kit can tell us!
johnnyboy is offline
Old 07-28-2010, 11:21 AM
  #3543
Motorman007's Avatar
Trader Rating: 89 (100%+)
This should make you happy
http://www.midwestrc.net/default.aspx?g=posts&m=1545
Upgraded Team Kyosho International version chassis.
Shaft drive 3-differential full-time 4WD chassis.
Chassis partially assembled by expert staff and checked individually by Yuichi Kanai.
Race settings can be fine tuned with adjustments to wheelbase, tread, roll center, caster angle, toe angle and camber.
Features 7075S-grade hard main chassis and hardened shock stays.
Features high heat dissipation brake disk and center diff case with increased capacity.
Mudguards on the rear suspension arms prevent dirt entering the drive shafts and wheels.
Resin front/rear toque rods provide flexible running performance.
Roll center can be adjusted with spacers on lower rear suspension arm.
Maintenance-friendly design.
Smaller front/rear diff unit, thinner cup joints and resin parts realize a lighter weight.
Fuel tank with finger-hook cap delivers stable fuel supply.
Stylish hex bolts hold firm throughout the chassis.
Includes 3 servo horn types for various R/C systems (for SANWA / KO / JR / FUTABA / HiTEC)
New low-height body design generates effective down force and realizes stable posture through the air as well as increasing maximum speed. Newly introduced oval-shaped air cleaner matches body design.
Motorman007 is offline
Old 07-28-2010, 11:35 AM
  #3544
deeje929's Avatar
Where dod you get the features from what site Motorman
deeje929 is offline
Old 07-28-2010, 11:57 AM
  #3545
Trader Rating: 16 (100%+)
Are the shocks hard andodized too? Tebos shocks have different color than the tki2 pic. I hated that the bottom half of the anodizing on the shocks rubbed off so quickly
Zach Phillips is offline
Old 07-28-2010, 12:04 PM
  #3546
johnnyboy's Avatar
Kanai's actual personal race car has the hard anodized stuff, but the other pictures of the actual production car shows the regular darker coating.....The terms "Hard or Hardened" I think refer to the alloy not the anodizing. I hope I am wrong, but it doesn't look like they are coming hard anodized on the TKI2
Tebo had his shocks done up on his own as he didn't like clips and were velvet shocks that were threaded for him and were not production.
  #3547
Old 07-28-2010, 01:25 PM
  #3548
deeje929's Avatar
Thanks, I hope that it comes with harden but if not I know a few shops on ebay that sells them for a nice price. Tebo's posting the the shock he ran is something that his father made for him.
I thought that the hardend anodized with lighter that what Kanai has on his buggy.
It looks lke the one of the 2 kit comes with harden towers
deeje929 is offline
Old 07-28-2010, 08:46 PM
  #3549
S grade! means soft, not hard anodized, chassis, towers etc will not be hard anodized. Here you go right on kyoshos website.
http://www.kyosho.com/eng/fun/specia...al_data02.html
Also thougt I'd like to update some of you guys wanting to just upgrade your current mp9s. The rear offset aluminum hubs from the tki2 are available if414 and in stock along with, the longer front lower king pins and bushings if467, rear alum toe block ifw402, front upper arm holder alum ifw406, the hard rear hub pin that goes through the rear arm and hubs ifw415, also front springs blue if350-714. I know this cuz I ordered that stuff today along with some other stuff for customers. Kyosho has a lot of parts in stock and more to come on the 19th so stock up....maybe even some tki2's.......
Andy
02maxima18 is offline
Old 07-29-2010, 03:53 AM
  #3550
Will these fit the MP9 rear M tower?
http://cgi.ebay.com/NEW-Kyosho-777-I...item4cf0b129bd
Tigergutt is offline
Old 07-29-2010, 05:03 AM
  #3551
didrace's Avatar
Nop.. the m tower uses the front st-rr shocks if am not mistaken .. The shock shafts and the shock body of the shocks on the M tower is different.
If you buy the ftont st-rr shock that will do but they do not have the coating of the mp9 shock so it might look a bit awkard..
I am sure you can find the m shocks complete on ebay..
do not buy them from a shop because it will cost you about double the money..
didrace is offline
Old 07-29-2010, 05:09 AM
  #3552
Ok. Thanks :-)
Old 07-29-2010, 05:34 AM
  #3553
Andy
YOU ARE BETTER OFF buying the TKI from A main. for the cheaper price and upgrade as you need it.
$7__ is a lot better than $9-- or $25 off so $875 from A main.
Things I would get are:
Front Shock Piston SP Type IFW405-138-1.3 $5
Rear Shock Piston SP Type IFW405-148-1.4 $5
Steering King Pin Long Type IF467 $5
Everything else is Candy!!
and you Really don't need these items.
Plus you get the HARD Towers and Chassis.
Sound about right?
As you see the TKI do cost more so Kyosho did cut cost. But did not pass it on to the People.
INFERNO MP9
TEAM KYOSHO INTERNATIONAL
Price (w tax) \ 123,900
INFERNO MP9
TKI 2 / TKI 2 SPEC A
31785 (Kit)/ / 31784 (SpecA)
\92,400 /  /96,600
GET THE TKI GUYS!
Old 07-29-2010, 08:26 PM
  #3554
I know this isn't the electric off road thread, but here is a pick of my TKI 2 with the brushlesss conversion. Not quite done with build yet. Still have shocks to do and some misc items.
Attachment 622945
kobiwan is offline
Old 07-29-2010, 08:38 PM
  #3555
Problem with older TKI's are the not updated hard plastics, updated bushings, front toe plate. I heard they came out with an updated TKI but unsure if it was a rumor or something on released in Japan etc. If it is the older style more likely you gonna spend like $50 in new plastics which isn't bad, and yes you get the hard anodizing. The TKI drives different than the SE I'm personally about 1-2 seconds faster a lap with the SE than the tki.
Andy
