Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 07-25-2010, 07:26 AM
  #3496
Trader Rating: 25 (100%+)
Shelf price was around $1250 here in Perth for the TKI 1 plus you get a lot more upgrade parts on the new one.
smelly62 is offline
Old 07-25-2010, 08:31 AM
  #3497
Hi Guys,
Just thought i tell you but i've been told my certain model shop in Japan they now have stock of the MP9 TKI2 now.
Roll on payday & sell my old car then i be ordering
carlin is offline
Old 07-25-2010, 08:32 AM
  #3498
Jammin57's Avatar
Trader Rating: 120 (100%+)
65000 yen is only $742 US so that is cheaper than the tki and isn't a bad price considering what you get when the SE kit is $600
Jammin57 is offline
Old 07-25-2010, 02:13 PM
  #3499
Matthijs's Avatar
Proline Bulldog for the AE fits nice indeed on the MP9! You've got to cut some alternative lines and be carefull around the tank. Also the stock airfilter wil push hard on the roof, need to lower it. I just wanted to see and try this style of bodies, in a month the TKI2 body will be available, can't wait for that one!
Matthijs is offline
Old 07-25-2010, 04:48 PM
  #3500
The bulldog body is bad a$$, I just had a JC rc8b punished body painted but it doesn't cool the engine like the bulldog. The bulldog keeps the engine like 10-15 degrees cooler give or take, I have a painted bulldog but it's getting old so time for a new one, it's at the painter now.
Andy
02maxima18 is offline
Old 07-25-2010, 06:17 PM
  #3501
didrace's Avatar
Guys i have the KH rear aluminium hubs,,
is it worth buying the kyosho ones?
I am very confused with this issues because the kyosho have those two extra whole on the top and i can buy also the 2mm offset..
I dont know if it will help me in any way or if i will just through 70 dollars..
Also what other option parts should i buy?
didrace is offline
Old 07-25-2010, 10:11 PM
  #3502
Suspended
Default Springs
Does anyone know what lenght springs Tebo is using on his setup with the medium towers and shocks. I have heard some talking about using the 95mm rear springs and others talk about the 84mm springs.
zobe75 is offline
Old 07-26-2010, 06:35 AM
  #3503
mp9er's Avatar
Post
i think tebos using the 84mm light blue springs on the rear and short light blue on the front
mp9er is offline
Old 07-26-2010, 07:33 PM
  #3504
rcjunky10's Avatar
Trader Rating: 227 (100%+)
That is correct...here is Tebo's setup:
http://www.infernosonly.com/v/vspfil...Fast_Track.pdf
rcjunky10 is offline
Old 07-26-2010, 07:39 PM
  #3505
rcjunky10's Avatar
Default Setup question!
Guys, I just haven't had the time to read through all 200 plus pages so I started at 183 and read all the way to the last page. So here are my questions and for those of you that are kind enough to respond please do so in a pm as I don't get to check the site that often and don't want to miss your reply.
This is the track I race at on a weekly basis. In race prep it's not nearly this loose, however, it's been very dry down here and we hadn't watered yet:
http://www.capefearraceway.com/
I wanted to ask a few questions as I've just picked up a lightly used MP9 TKI. I am planning to run it with the stock rear shock configuration for the time being, yellow/purple springs, and wanted to know what pistons most guys are running and what option pistons I should be considering? Also, I have the updated front upper arms, bulkheads and aluminum upper arm holder and aluminum rear lower arm holder. It sounds like I need to pick up a few more sets of the upgraded bushings. Is this the correct part number for the bushings:
KYOIF442KG
Are guys still running the 4x10x.05 washer behind the front and rear lower arms? Please make recommendations if there is something that I've forgotten to ask about or simply overlooked!
Thanks guys for your time!
Old 07-26-2010, 08:02 PM
  #3506
Motorman007's Avatar
Trader Rating: 89 (100%+)
INFO I Found.
response 50 of 57: Edit Erase Hide Mark Unseen Jul 26 21:09 EDT 2010
http://translate.googleusercontent.com/translate_c?hl=en&sl=ja&u=http://www.pro-s-futaba.co.jp/home/guide-of-arrival-of-goods/2010-jul/899-goods-guide-20100721.html&prev=/search%3Fq%3Dpro-futaba%26hl%3Den%26client%3Dfirefox-a%26hs%3DHdE%26rls%3Dorg.mozilla:en-USfficial&rurl=translate.google.com&usg=ALkJrhij 7i5BVKQTO1BKaX5khk_0l1aMcA
from japan.
Kyosho 31784 MP9 TKI 2(Team Kyosho International 2) SPEC A  1/8 GP 4WD Inferno Sale 31784 MP9 TKI 2 (Team Kyosho International 2) SPEC A 1 / 8 GP 4WD Racing ¥67620 新製品 67 620 New Products
TKI upgraded combat power achieved in semi-finished factory! Yuichi Kanai assembly and checking of staff trained, reliable running!
2008 MP9 Yet participated in the prototype, the design team showed a large activity Kyosho International World Championships in 2008 MP9, but after two years of aging "2" has evolved into. Upgrade based on experience in various parts of many international races. Yet achieved significant cost reduction was a semi-finished products assembly plant by more knowledgeable staff. Chassis on the theme of effective use of traction, and realize Shotosasuamu rear hub attached to the rear suspension newly developed. Nimble feet to stroke, effectively put the race showing traction. The damper can be changed to type fine-tuning adjustment dial from the traditional adjustable spacers. 。 Def damper assembly process is adopted as Yuichi Kanai. The Danpapisuton addition, the previously optional Tepahorutaipu adopted. Pull out the ideal piston speed control, excellent damping characteristics to support race to run for a long time. And the new body design Rohaitoforumutaipu. The exquisite shape of the front parts of less resistance, it demonstrates the strength of attitude stabilization and competed in the air. The former world champion yet, check out one single chassis Yuichi Kanai, who is also the developer of the Inferno. 高い信頼性を約束します。 Ensures high reliability. Performance of the latest racing TKI2 SPEC A, please grab a solid victory.
NONE Kanai playing with it price
Kyosho 31785 MP9 TKI 2(Team Kyosho International 2) 1/8 GP 4WD Inferno Sale 31785 MP9 TKI 2 (Team Kyosho International 2) 1 / 8 GP 4WD Racing ¥64680 64 680 New Products
GP 4WD Racing
¥67620 67 620= $779
NONE -Yuichi Kanai assembly and checking
Kyosho
Racing ¥64680 64 680 = $745
DURRango is $700
http://translate.googleusercontent.c...cezG-rkrwzLqAQ
kendallb
Kendall Bennett
response 54 of 57: Mark Unseen Jul 26 21:26 EDT 2010
For those Kyosho fans, the Team Kyosho International Kits are now up for pre-order!
http://www.amainhobbies.com/product_...Off-Road-Buggy
And for those Kyosho fans with a severe case of sticker shock, Kyosho has re-released the SE edition of the kits as well
We will have stock on both of those by the end of August we expect.
kendallb
Kendall Bennett
response 55 of 57: Mark Unseen Jul 26 21:27 EDT 2010
And we also still have the original TKI kits in stock also, until they are all sold out:
Looks like the SE may be for us Poor guys.
I guess Kendall will be getting my money one of the two. ahahah
will this $900 buggy come with all the bells
New Kyosho cap universal swing shafts
No.IFW419
Cap Universal Swing Shaft
(2pcs/91/MP9/MP9e)
*Optional parts for Inferno MP9 series (for Front)
Available in Aug 2010
No.IFW420
CapUniversal SwingShaft
(2pc/93/MP9/9e)
*Optional parts for Inferno MP9 series (for Rear)
No.IFW421
Cap C-UniversalSwingShaft
(1pc/84/MP9/MP9e)
No.IFW422
CapC-Universal SwingShaft
(1pc/110/MP9/MP9e)
KYOIFW412 Kyosho Inferno MP9 Aluminum Front Hubs
KYOIFW413 Kyosho Inferno MP9 Aluminum Rear Torque Rod
KYOIFW414-01 Kyosho MP9 Aluminum Rear Torque Rod Bushings
Motorman007 is offline
Old 07-26-2010, 09:01 PM
  #3507
I called Kyosho today and the kit will be no cheaper than $825 ANYWHERE, built $850, that's with the hobby shop making like no money on a $800 kit! I love my mp9 but I'd rather take my SE buggy which already has most of the upgrades and get the rest for a couple hundred bucks.
Andy
Old 07-26-2010, 09:34 PM
  #3508
captain america's Avatar
Andy
Not very reassuring. That having been said, the "new lower price" was touted and bandied about whenever the new car was discussed, so I dare to think that there might (hopefully) still be a pleasant surprise for us once it actually hits shelves.
I'm with you though: start off with the SE which is fine, and upgrade to the better parts as the stock ones wear.
captain america is offline
Old 07-26-2010, 10:21 PM
  #3509
Trader Rating: 357 (100%+)
holly cow $900.
jmoneym is offline
Old 07-26-2010, 11:17 PM
  #3510
We are a Kyosho dealer trust me that's the price. A main has a price of $900 for the kit and that's actually pretty decent price seeing how no tax if your out of state. I can backorder the kit if I want to but even dealer cost is VERY pricy.
Andy
